Results 1 to 23 of 23
    Oct 2013
    New Raceface Next SL Crankset weights
    Hi all. Just recieved my new 2014 Next SL crankset. Looks nice and the modular idea is a no brainer. I will be using it as a single speed over winter and switching to geared during the racing season.
    Here are the individual weights.
    Crankarms/spindle/lockring: 394g
    104/64 spider and bolts: 67g
    36T: 63g
    24T: 21g
    single speed spiderless 32T: 68g
    So, 36/24 setup is 545g
    and ss 32T is 462g
    Reputation: thickfog's Avatar
    Oct 2010
    Nice!
    CRAMBA Chairman
    Oct 2013
    What type of bb are you using? When I placed my order, my LBS didn't know exactly which bb would be compatible. It's a 30mm spindle, from my understanding.
    Oct 2013
    The cranks are actually compatible with most BB types. I think they may just use smaller bearings to allow the 30mm.
    I use a pressfit 92 (Pivot Les), but my LBS ordered the wrong one, so I have to wait for the correct one.
    What is msrp (polite way of not asking what you actually paid) on the new SL crank?
    Weight vs XTR 985 is what I should google next...
    Oct 2013
    Weight of 985 ranges from 630-650g depending on rings.
    MSRP in US is posted on RaceFace website. I live in Canada so different pricing.
    Tells you various weights as well with different combos. My weights were measure on my scale.
    I'm running XTR 985 Race with single ring. Wondering if the weight difference is even 80 grams. But on one bike I'm running a 150g Praxis Conversion bb which adds to the weight weenie issue.
    Nice weights, though about 30g heavier than the Sworks cranks. Can you tell us how much the spindle weighs - curious to compare to a Hollowgram one since the RF is supposedly some new miracle alloy.
    Oct 2013
    It's around 100g. I haven't removed it yet though.
    Reputation: RaceFace-suit's Avatar
    Quote Originally Posted by musanoadsaba View Post
    The bearings in the BB92 are the same size as in a standard 24mm setup (and there are more of them). We didn't undersize them like some manufacturers have done.
    Quote Originally Posted by dwaharvey View Post
    Can you tell us how much the spindle weighs...[].. since the RF is supposedly some new miracle alloy.
    83g for 134mm length with no strength decrease - miracle indeed...
    Here are a few scale pics and builds from Pro Bike supply
    https://www.facebook.com/media/set/?...8044919&type=3
    https://www.facebook.com/media/set/?...4919&type=1%29
    Thanks for the info. I'm wondering if part of the reason for the lower weight than the hollowgram spindles is the fact that you are designing for a much better (wider) bearing placement, whereas the hollowgrams cantilever a decent distance... Anyway, nice to see someone (you) making a well thought-out crank that'll work with any frame!
    On a related note, are the splines on 30mm cranks generally the same across different manufacturers? The RF splines look by eye to be identical to Cannondale, or even the SRAM BB30 crank end (admittedly the other end is fixed in the arm). Could someone use one of your spindles with an existing hollowgram crankset and your BB? (q factor would increase by 2mm of course and chainline by 1mm due to 134mm vs 132mm)
    Our splines are very similar to Cannondales. I can't go as far as to call them compatible because we cannot know what tolerances they allow in their system.
    Other manufacturers who use a similar looking spline are actually very different from our system.
    I hope that helps.
    Thanks for riding Race Face!
    Reputation: global's Avatar
    Can I run a single speed spiderless 30 t ring on my 2012 next sl cranks?
    Quote Originally Posted by global View Post
    I'm afraid not. Only the 2014 model will take a spiderless ring.
    Reputation: NoShirt's Avatar
    I'm waiting on a set that I ordered a couple months ago direct to Race Face through my local shop. Sounds like people are getting them, should I assume mine are on the way to the shop or are there any further delays on the 32t direct mount setup?
    Have a nice ride!
    Quote Originally Posted by NoShirt View Post
    E-mail us at components@raceface.com and we should be able to look into it.
    Reputation: kdiff's Avatar
    Quote Originally Posted by RaceFace-suit View Post
    I emailed you guys on 2/3 about my cranks that have been on backorder since 12/14 and I haven't heard anything...
    Quote Originally Posted by kdiff View Post
    Inside guys are overwhelmed, so takes a couple days.
    PM me the shop name you ordered them from and I'll check right now for you.
    PM sent. Thank you for the help.
    Aug 2015
    Has anyone tried and compared the Next SL to the G4? The small weight savings doesn't seem to worth the extra costs and the extra stiffness is hard to quantify on paper without a demo. Perhaps it's too new for reviews?
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by jacksonlui View Post
    All my online sources say it becomes available May 12 - 15. So yes, a bit early yet.
    Nor­wegr
    Reputation: Vegard's Avatar
    Afaik the savings is only 16-ish grams so I'm not going to be replacing my regular next sl anytime soon
    For a product as good as the next sl is, a 20% stronger pedal insert and a 13% stiffer chainring sounds a bit moot for the average consumer. If buying new I'd ofcourse get the G4, but replacing something fully functional, not really.
    Cranks have come to a point where they suffer from the same issue as phones and tablets, neglible improvements and better longevity means replacement happens less often.
    Aug 2015
    The price diff is about $100. Even for someone buying new, wouldn't it make sense to go with last year's model?
  1. RaceFace/ Yeti Sixc crankset
    By bpnic in forum Yeti
    Last Post: 11-04-2014, 06:10 PM
  2. Crankset weights (XT / XTR / XX / XO
    By chainringX2 in forum Weight Weenies
    Last Post: 05-20-2012, 02:23 AM
  3. Replies: 1
    Last Post: 01-22-2012, 06:08 PM
  4. Raceface Dues XC CRANKSET W/ BB thoughts?
    By HighLife420 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-27-2011, 09:59 AM
  5. TruvatIv Noir crankset + Raceface 10 speed rings
    By CasinoKiD in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-18-2011, 10:10 PM
