Results 1 to 10 of 10
    My new Orbea Scape
    Pic's of my new hardtail project 1391 grams w/ derailluer hanger built it up quick yesterday @ 21.30 lbs with a Heavy XT/Mavis 717 front wheel (862 grams) so I have a wheel set coming from Larry a few Tune parts (quick releases and bar ends) it should get down under 21 lbs!
    Trail rider and racer
    Reputation: Trevor!'s Avatar
    Great - Cant wait to see the finished product!
    Trev!
    Reputation: top_ring's Avatar
    Very nice. I almost bought this frame myself but opted for the Kula Primo - same weight but cheaper. Let us know how she rides.
    Reputation: Slobberdoggy's Avatar
    Yup, I considered this frame as well. Very cool frame. Just out of curiosity how much do you weigh and how tall are you? The frame is fine no matter what just wondering about the how the rest of the build will be. V-brakes I presume?
    Build Info
    Quote Originally Posted by Slobberdoggy
    I'm 5' 11" 190# The frame is a 20" with a 610mm top tube after coming from a Rocky Mountain Element Tsc Full Suspension I was really impressed so far with this frame ( only one ride)
    I think the scadium along with the s curved seat stays take some of the edge off !
    Here's the build as of today !!
    2005 Orbea Scape 20" 1391g
    Brake Bosses 18g
    05 Rock Shox Reba Team w/ star nut 1605g
    Poploc 50g
    FSA Orbitz Z 91g
    Stem Ritchey WCS V3 110mm w/ Ti Bolts 101g
    Easton CT2 Flat 580mm w/ alum Plugs 134g
    Ritchey WCS Bar Ends 98g
    Grips ESI Silicone 44g
    Brake Levers
    Rear Avid 04 SL 76g
    Brakes
    Avid 04 SL 167g
    Juciy 7 carbon 294g
    Juicy 7 Rotor 116g
    Rotor Bolts qty. 6 13g
    Rock Shox Adapter 14g
    Adapter Bolts Ti 6g
    Gore Shifter Cables 100g
    XTR Rear Brake w/ Full Housing 70g
    XTR Shifter 254g
    Chain Shimano CN-7700 XTR 273g
    Pedals Crank Bros. Triple Ti Short Spindles 179g
    Cranksets Race Face Deus w / Race face rings 825g
    Derailluers
    XTR Rear Derailluer M-960 203g
    XTR Front Derailluer M-961 w/ Ti clamp bolt 147g
    XTR Cassette M-960 8 speed 12-34 233g
    Wheels
    Mavic 717 / XT Disc 853g
    Stan's ZTR 355 Hugi 240 DT 14/17 756g
    Rim Tape
    Stans rim Tape 2 g
    Front Rim Strip Nylon 15g
    Skewers
    Shimano XT 60g
    Bontrager Ti 46g
    Tires
    Specialized Roll X Pro WSD 530g
    Kenda Blue groove Lite 470g
    Tubes
    Stan's Rim strips 57g
    Stan's sealent 30-35 grams per Oz. 60g
    Torelli Extra Lite 125g
    Saddle San Marco Aspide "Night Train" 150g
    Seat Post Thomsom Master Piece 27.2 X 330 190g
    Seat Binders Orbea w / Ti Bolt 15g
    Misc.
    Specialized Rib Cage Pro w/Ti Bolts 36g
    Zip ties 2g
    9874g
    21.77 lbs.
    *** It weighed 9870g / 21.75 on my Alpine Hanging scale *****
    These are the parts that I have on the way;
    Stan's olympic disc / DT240 center lock/ sapim CX Ray
    Tune Bar Ends
    Tune Skewers
    Stan's Rotor
    Syntace 90mm stem w/ Ti Bolts
    This will bring it down to 20.85 lbs until I put the rear disc on ! I was not to happy about the weight of the Juicy 7 carbons Total with the adapter was 443 gram but with a 116 gram rotor!
    Quote Originally Posted by Spin Cycle
    Brake Bosses 18g
    Poploc 50g
    FSA Orbitz Z 91g
    Brake Levers
    Rear Avid 04 SL 76g
    Brakes
    Avid 04 SL 167g
    Juciy 7 carbon 294g
    Juicy 7 Rotor 116g
    Adapter Bolts Ti 6g
    XTR Shifter 254g
    Derailluers
    Wheels
    Rim Tape
    Stans rim Tape 2 g
    Skewers
    Shimano XT 60g
    Bontrager Ti 46g
    Tires
    Tubes
    Misc.
    Zip ties 2g
    9874g
    21.77 lbs.
    Tune Bar Ends
    Tune Skewers
    Stan's Rotor
    Nice stuff indeed, it will be a great build when its finished, and for that size frame the overall weight is good indeed.
    Trev!
    I'm just curious about how the Tune Skewers will perform. I was recommended not to use them at my 190-200# weight but I might get them later. They look beautiful and are light!
    Tune skewers
    Two weeks and no problems as good as the bontrager Ti and shimano XT in the front can't tell any difference !
    Dope dude! That gets me tempted to drop some more doe$ on those.
    Gives me one more thing to start looking into. If they are good for you on the front then they are probably good on the back too?
    set !
    I have then on both the front and rear I'm 200 # plus gear so they are performing the same as the Bonti Ti in the rear and the old stand by of shimano on the front . they are tapered so the threads are the same as the other but taper in the center 4.9 mm @ threads and 3.9mm center!! actual weights !!!!
    Front ; 26 grams Rear : 28grams saved 42 grams over Bontrager Ti rear and Shimano XT front !!!
