I want to drop some weight from my SLX crankset. I have a standard 44-32-22 setup and that the middle and inner rings are rather heavy. Can someone steer me in the right direction to replace these with some lighter ones
Your weight savings going from 3x9 to 2x9 by dropping the big ring are at the most the weight of the big ring and the weight of the longer crank bolts over the shorter crank bolts. You normally gain a little weight on your remaining chainrings because they end up being bigger. ie 22t -> 26t, 32t -> 36/38/39t.trembljo said:...You'll save close to 100gr...
FYI for the original poster, my weight is the entire crankset incuding the non drive side arm. the weights above are only the drive side.trembljo said:i just did a XT m760 2006 crank. You replace the small ring by a 26T and the midle one by a 38 or 39T, no big ring. 28/42 is also a good setup. You need shorter bolt to clamp the midle ring. This setup work with any 64 / 104mm crank. You'll save close to 100gr. The only other option to drop crank weight is to change it! Kforce light crank (no ring) is 520gr vs 594gr for XT. I just bought a Race face next SL for someone and weight only 625Gr with 3 rings and bolts.
Original:
crank 594 Gr
22t: 22 Gr
32t: 45 Gr
44T: 81 Gr
+ bolts
2x9:
Crank: 594 gr
specialitee TA 26T: 28gr
Specialitee TA 38T: 54Gr
+ shorter bolt
The rings:
http://www.dulight.fr/catalog/product_info.php?cPath=91_63_149&products_id=1463
there is also 26t/36T Driveline chainring available on ebay from the same seller. However this seller don't have bigger one.
http://cgi.ebay.ca/New-Driveline-ch...Cycling_Parts_Accessories&hash=item45f92c66fe
the bolts:
http://www.dulight.fr/catalog/product_info.php?cPath=155_156_163&products_id=1280
CRC also have short bolts
http://www.chainreactioncycles.com/Models.aspx?ModelID=19227
i wish this will help you.
If you want, i can send you pictures a 2x9 XT crank
trembljo
