Results 1 to 8 of 8
    Nov 2012
    Looking for a 400 mm, 27.2 mm, 25 mm offset seat post, sub 200g
    Hi fellow MTBR Weight Weenies, I'm looking for a 400 mm, 27.2 mm, 25 mm offset seat post for my new 2013 Trek Superfly Elite SL, SUB 200 grams if possible... and Tune speed needle compatibility... Cheers!
    ups and downs
    Don't know about the saddle rail compatibility but...
    ENVE Road Bike & Mountain Bike Seat Post / Carbon Fiber Seat Post
    Nov 2012
    This was the first post I've found, yet its not super light, Its quite expensive and the rail system isn't reliable...
    Reputation: phlegm's Avatar
    I think the 400mm requirement is going to hamper you. If you can go shorter, it may open up some options.
    Reputation: olowe's Avatar
    Jan 2009
    I use a KCNC post right now, it uses the same type of clamp that Tune, Schmolke, Extralight etc. use. So your carbon rails should fit and best of all there about 100$ on ebay, the 27.2 is about 165-170 grams at 400mm. On a side note I weigh about 180-190 and I've been using my post for 3 years and have had zero problems other than seat creaking after adjustments (due to me not setting the clamps correctly. KCNC Ti Pro Lite Seatpost : Fairwheel Bikes, Cycling Boutique and a review Grams Light Bikes - Mountain Bike and Gear Reviews, and News: KCNC Ti Pro Lite Seatpost Review
    Nov 2012
    400mm or more, it's not a option, my weight isn't a issue, I'm only 130 lbs...
    Reputation: Smart Sam's Avatar
    Keith Bontrager once said, "Light, Cheap, Strong - Pick two."
    KCNC is probably your best bet. Thomsons are upgradable (Ti bolts, carbon cradels) and are worth a look.
    "The best carbon hardtail frame is custom made for you from titanium." - Curmy
    Jan 2009
    I totally missed that you wanted a 25mm ofset post, that changes things a bit
  1. Replies: 68
    Last Post: 10-01-2013, 06:31 AM
  2. Best sub-200g seatpost for sub-$100?
    By Peruvian in forum Weight Weenies
    Last Post: 08-30-2011, 03:05 PM
  3. 2011 Scalpel seat post/ seat clamp issue
    By scalpel226 in forum Cannondale
    Last Post: 08-01-2011, 09:19 PM
  4. Thomson seat post base on an Easton seat post?
    By steveccnv in forum General Discussion
    Last Post: 06-23-2011, 06:51 PM
  5. Giant Reign 2010 Seat Tube Seat Post
    By cjsett in forum All Mountain
    Last Post: 01-16-2011, 07:07 AM
