Results 1 to 7 of 7
    Looking for a 27.2x450mm carbon seatpost. Need suggestions.
    From what I've found so far it's fairly easy to find carbon posts that are
    27.2x400. However, I can't seem to find a carbon post from a reputable manufacturer that is 27.2x450mm. Even 27.2x425mm would work.
    I have found a number of carbon posts on ebay are 27.2x450mm but there is no information about them, no independent tests or reviews on this site for instance. I am guessing that these cheap Chinese carbon posts are not very compliant, and that strength/durability might be an issue.
    Reputation: phlegm's Avatar
    Those eBay carbon bits are hit and miss. Some could be perfectly fine, while others could hurt you.
    You mention 425mm would work, however I should ask how much post you need exposed of that, i.e. how much is above and below the clamp/binder? MCFK has a 420mm, and quality is excellent, however price is crazy, and I'm unsure how much actual post you need exposed:
    Mcfk - Seatpost
    ...oh, and Schmolke will allow you to select a custom length, and even weight limit:
    Seatpost SL - Schmolke
    ...but again price is er, ah, a bit of an issue.
    Ole
    Ole is offline
    Syntace makes up to 480mm.
    Syntace
    [QUOTE=phlegm;12998947]Those eBay carbon bits are hit and miss. Some could be perfectly fine, while others could hurt you.
    [url=http://www.mcfk.de/en/products/sattelst%C3%BCtze
    I need at least 280-300mm above the seat collar. The bike is a 20" 1993 Kona Explosif,
    I am 6'4".
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by phlegm View Post
    Mcfk - Seatpost
    Yep, proceed with caution. I broke a frame due to too much exposed seatpost.
    I have a couple titanium posts which have been pretty reliable. One's a Dean and the other is from Ti Cycles. Want to try a carbon post to compare the compliance to my titanium posts.
  1. Replies: 0
    Last Post: 01-26-2014, 04:13 PM
  2. Replies: 0
    Last Post: 11-13-2013, 06:25 PM
  3. Replies: 2
    Last Post: 10-04-2013, 03:07 PM
  4. Replies: 1
    Last Post: 09-09-2013, 09:17 PM
  5. Suspension Seatpost Suggestions
    By sbermhb in forum 29er Bikes
    Last Post: 06-17-2011, 05:52 PM
