Results 1 to 14 of 14
    Mar 2013
    Lightweight tires!! Oh the choices!!!
    I have spent hours online and on this forum researching tires and I think I am just going in circles now. I am a weekend rider, not a racer, 200lbs and ride a Superfly hardtail. I live in the Mid Atlantic and ride mostly hardpack with a little mud/loose dirt thrown in here and there. Every popular LIGHT tire I look at (Racing Ralph, Rocket Ron, etc) I feel is only seconds away from blowing a sidewall. I came across the Bontrager 29-1 Team Issue that's only 485g but I am concerned as well with traction/durability. Any thoughts on a 500gram XC option that isn't so fragile you need to walk the bike down the trail???
    Ahhh the pain....
    Reputation: Raybum's Avatar
    Assuming you're on a 29r, any reasonably priced, reasonably tough tire is going to be over 650 grams. Conti X-kings w protection, Geax Saguaros, etc....
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    Did you check out Schwalbe tires with the Snakeskin sidewall? They seem to be a little burlier. You can get them in Double Defense for extra tread protection too.
    I'm gonna have to kill ya
    Reputation: roybatty666's Avatar
    I run RoRo snakeskins and they deal with the flint here very well (and it is razor sharp) the tread area still takes the odd cut beyond what the sealant can seal, the Nobby Nics is a thicker carcass and in snakeskin versions has proved immortal on my nasty trails.
    Light tyres are all going to be thinner and prone to puncture
    Reputation: 2002maniac's Avatar
    Nov 2008
    Racing ralphs have been tough enough for me here in the Southern Utah Desert. Lots of rocks and no punctures yet...
    Jan 2009
    Quote Originally Posted by imtheant View Post
    I too live in the mid atlantic and ride a superfly. I also weight 180lbs and race. I dig the 29-1 bonty but I have destroyed two of the non TLR ones this summer. Just installed a set of the TLR- reinforced sidewall ones. They're not uber light at 690g but they are wonderfully indestructible and I can run pressures as low as 20 with no squirm.
    Illuminati
    Reputation: scant's Avatar
    hopefully in time with new technology tyres companies will be able to make robust lightweight (sub 500g) tyres. certainly standard rocket rons that I use for lightweight XC duty arent that robust & would easily rip if I ploughed through the rocks with the same recklass abandon that I do on snakeskin hans dampfs which are 1/2lb heavier per tyre.
    You can have light and you can have tuff. It will
    be hard to get both.
    May 2013
    Quote Originally Posted by John Kuhl View Post
    This is soo true!
    I run Hutchinson Black Mamba on my 29er it has been a great fast tire! No flats or punctures yet and have had them for about 5 months now(I live in Florida though). The sidewalls seem much beefier than on the Conti race kings i had before. You just have to ride less sloppy and more careful with race tires and as with any tire there are pros and cons.
    Don't bother with the Specialized "S-Works" versions of their tires. But, do consider the "Control" version. Same tires, but control has the sidewall protection. Only a slight weight gain.
    My snake skin ralphs have been good but i do find the alot stiffer at the same psi as non protected tires. I plan on some ro ro or ra ra non snake skin for next seasons racing. Been very happy with the traction.
    Mar 2013
    Great advice guys. Thanks. I am hoping to maybe pick up a slightly used set of a lightweight RORO or RARA or similar to see how they hold up.
    I like turtles
    Reputation: TiGeo's Avatar
    The S-Works tires are fine..or at least have been for me as a front tire. I run the control casing in the rear.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Nov 2012
    Sign on mechanic's wall:
    We do 3 kinds of work:
    -Good
    -Fast
    -Cheap
    Pick two.
  1. Best Lightweight 650b Tire choices
    By Triaxtremec in forum 27.5
    Last Post: 12-19-2012, 09:08 AM
  2. Choices for lightweight 140-160mm fork
    By roxtar in forum All Mountain
    Last Post: 12-29-2011, 11:27 AM
  3. 20" tires choices?
    By kuan in forum Wheels and Tires
    Last Post: 09-05-2011, 09:30 AM
  4. Tires, So Many Choices...
    By smokehouse4444 in forum Wheels and Tires
    Last Post: 06-03-2011, 07:38 AM
  5. lightweight tires for my lightweight
    By eyebike66 in forum Wheels and Tires
    Last Post: 05-17-2011, 05:56 PM
