Results 1 to 27 of 27
    Reputation: Steve77's Avatar
    Feb 2010
    Lightest All Mountain (i.e. 150mm+ travel) 26" frame
    What's the lightest All Mountain (i.e. 150mm+ travel) 26" frame out there? I'm looking for something with:
    150-160mm travel
    Frame weight with shock closer to 5lbs than 6lbs
    26" wheels
    67 degree HA or lower
    Preferably ISCG tabs and a bolt through rear axle
    No reputation for cracking easily
    Is there anything lighter than the stumpjumper evo? Have been looking at:
    Stumpjumper Evo Carbon
    Trek Remedy Carbon
    Intense Carbine
    Anything obvious I'm missing?
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    I understand wanting lightweight parts and all but for a bike like that, isn't suspension design and geometry and whatnot more important than 1lb of frame weight?
    I say this because there are a lot of great 6" frames that come in right around 6lbs that I wouldn't rule out. Yeti SB-66, SC Nomadc, Ibis HDR to name a few.
    Feb 2010
    True, but you can make that argument about all the components too and then end up with a 30lb+ bike. I'm trying to build something a lot lighter than my current bike so need to go with the light option in every area
    Reputation: Vespasianus's Avatar
    Scott bikes are generally very light and come in 150-170 varieties. However, a super-lightweight 160mm bike is going to ride worse than a heavy 140mm bike.
    On MTBR, the reputation is infamous.
    Feb 2010
    Thanks, the old 26" Scott Genius LT frame could be on the list but I'm not so keen on the twinlock system and shock position (although I've never ridden it). The new one looks better but I don't want to move to 27.5" as I have various 26" wheels/tires already
    A super-lightweight 160mm bike will be less reliable than a heavy 140mm one, but on the other hand it'll be much quicker. Whether it 'rides worse' though is subjective, but I personally happen to like light bikes
    Big Gulps, Alright!
    Quote Originally Posted by Steve77 View Post
    If weight is the ONLY criterion, then sure. But that being said, it sounds like you'e building a race bike more than a long travel trail bike.
    Reputation: crank1979's Avatar
    Feb 2006
    How about a Liteville 301?
    Isn't the ibis mojo slr around that weight? They claim its 5.2lbs but its 140mm. I also know ibis has had problems with the mojo sl, I assume they fixed them with the slr.
    6x7=Dont Panic!
    Reputation: TheRedMantra's Avatar
    Quote Originally Posted by litany View Post
    I did not weight my SL-R frame when I built it over a year and a half ago, however at the time many were claiming that the bikes were 8oz over the claimed weight (give or take). Before I started riding the Mojo I came from a rigid singlespeed aluminum XC bike. I had been riding rigid SS for 7yrs or so.
    I have owned two full suspension rigs before I went SS and have tried quite a few designs over the years. The Mojo is an amazing AM bike. 140mm of travel has been enough for me and some people do run 150mm on the front.
    I have ridden the bike in Bend, OR, Flagstaff, AZ, Miami, FL, Moab, UT, and predominately in Colorado Springs, CO. The bike is a more than capable XC bike handling the techiest trails with ease and inspiring confidence on the downhills and on trails I wouldn't dream about riding an XC hardtail on.
    My setup is just over 26lbs with some sturdy Saint bits, formula the one 180/160, 20mm front axle, and flat pedals. I just put some XC trail pedals on it last week and it has been a really fun change. The bike is robust and capable. It is stiff. It climbs very well. It tracks fantastically.
    In my experience ibis is an amazing company with excellent customer service. The bike can be used as a platform for an extremely lightweight AM bike. It does not have iscg mounts but I have been running mine as a 1x9 with a saint m810 short cage rear and an MRP guide in the front and have only lost my chain a few times in the gnarliest of conditions. I plan to upgrade to a 1x10 Saint M820 setup next spring and hope the shadow+ will help prevent any future chain issues.
    Good luck with your decision! I hope my input was of some use to you.
    Herro prease
    vto
    vto is offline
    I would look into pivot Mach 5.7 carbon. All your boxes are checked off with this frame.
    Quote Originally Posted by vto View Post
    Except its 6lbs.
    vto
    vto is offline
    Yeti ASR5 carbon.
    My Large Mach 5.7C frame weights 5.7lbs. I rode it at 24.4lb all summer with Lev post, 1x10, Revelation WC fork and Nobby Nic Evo 2.35 tires. It now sits at 25.8 with the Pike fork and the Hans Dampfs.
    bike rider
    Reputation: Lelandjt's Avatar
    And frames aren't usually weighed with thru-axle and seat collar so subtract those. It doesn't look like a small, probably a medium so no cheating there. Pretty sick weight on a known good handling frame. I wonder what the production variation is and how many frames they weighed before picking that one for display.
    Keep the Country country.
    Reputation: BDozer's Avatar
    Mar 2012
    Thanks, the old 26" Scott Genius LT frame could be on the list but I'm not so keen on the twinlock system and shock position (although I've never ridden it). The new one looks better but I don't want to move to 27.5" as I have various 26" wheels/tires already.
    My buddy had a Scott XC bike with the twinlock and it works great. I wish my bike had it. His has 3 choices - full travel, fully locked and one setting inbetween. He said he only locks it out when on pavement and out of the saddle. For climbs on rougher terrain he puts in in the middle position and it don't bob much and the rear tire stays on the ground. I've spent plenty of time following up climbs and it sure seems to work good.
    On mine I have on-off only and have to reach down to activate it which means I almost never do.
    So, I'd put having twinlock in the plus column.
    Dec 2008
    Ibis Mojo SL,medium = 4.93 lbs. I have this built to 21.5 lbs with a 150mm fork, 2x9 gearing, riser bar & real MTB tires.
    Attached Thumbnails Attached Thumbnails Lightest All Mountain (i.e. 150mm+ travel) 26" frame-img_0597_1.jpg
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Re: Lightest All Mountain (i.e. 150mm+ travel) 26" frame
    It just depends on how light vs how all mountain you wanna go. Agree on checking out the Yeti asr5 carbon. 4.75lb frame single pivot 140mm. I have mine @26.2 lb with haven carbon wheels, haven carbon bars, a Joplin dropper, 2.4 inch am tires and a talas 32. Its a decent all mountain setup that will take 3-4ft drops and still climb like a Himalayan yak. But there's stuff i won't do with it because its a super light carbon frame and i don't wanna push my luck.
    > /dev/null 2&>1
    Feb 2012
    Quote Originally Posted by xc71 View Post
    Wow 21.5 is incredibly light - can you post how it adds up?
    How much do the enve's weigh? How about the dt fork?
    Dec 2008
    Quote Originally Posted by ddprocter View Post
    The DT fork isn't the lightest at 1700 grams, but I really like its performance, especially over the two Fox forks I tried on this bike before the DT.
    I haven't gotten around to doing a full build sheet yet but here are few weights.
    Wheelset = 1169 grams. Extralite hubs, CX-Ray spokes, Enve XC.
    Schmolke TLO riser, 685 mm = 100 grams.
    Ibis stem with Ti bolts = 91 grams.
    New Ultimate seatpost = 125 grams.
    Tune Speedneedle = 89 grams.This has been great on all day rides as it has alot of flex to the saddle shell along with the very plush DW-Link suspension. The Carbon DT shock helps alot here as well. Fox was terrible. RS Monarch was decent but DT was the best for my weight riding alot of wet roots/rocks.
    Extralite foam grips = 19 grams.
    S-Works carbon cranks, Lightening spider, Extralite 32/22 rings = 467 grams. You would think the wheelset was the most noticable parts on here, but I'm really lovin this set-up. Cranks are so stiff with zero issues & the rings shift great. Approx. 200 grams lighter than the XTR set-up I took off.
    For a rear tire I usually run a Conti Race King Supersonic 2.2, I've been lucky to find several in the 445 grams range. Running tubeless with Stan's.
    Tuned XTR rear derailleur, carbon cage, Alum. bolts, KCNC wheels. 162 grams.
    XTR rear cassette with Yumeya 17/20 Tooth Ti cogs.
    In the summer I run XTR pedals with Ward Ind. Ti spindles.
    Aligator I-Links with Powercordz cables.
    All bolts are Ti, Alum., Carbon or Nylon.
    Reputation: veritechy's Avatar
    Wow. That is superlight for that type of capability. Nice!
    Reputation: CrozCountry's Avatar
    Mar 2011
    Does not exactly fit your spec, but Blur LT Carbon is a great frame. Its also massively strong according to Santa Cruz. It has no fork limit and comes with 5 years warranty. They used to be on sale for a while, maybe you can still find one at a sick price.
    Reputation: MSU Alum's Avatar
    Except its 6lbs.
    Mine was pretty close to 5 pounds.
    Yeah that's probably my bad, I forgot I weighed mine with bb skewer and headset cups
    Formerly of Kent
    Reputation: Le Duke's Avatar
    My Blur LTC should be ~23lbs when complete. XX components, XT brakes, DT Swiss EXM 150mm 15QR fork, light-bicycles rims laced to AC hubs, Nobby Nics.
    Death from Below.
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    A weight weenie Ibis Mojo. Now I have seen it all. I bet that thing is a blast to ride. Do you race it at all?
    Dec 2008
    Smile
    Quote Originally Posted by moefosho View Post
    I don't race this bike as I have an 18.5 lbs. Scott Spark RC, XC bike. I do spend most of my time on the Mojo SL as it is so much fun to ride. I often ride with much younger riders in their 20's and this bike def. helps even things out for me. Here in the Canadian Rockies we ride some monster climbs up into the high Alpine and this bike is majic on the really steep rooty/rocky climbs. Its awesome on the way down the mountain as well.
  1. Lightest Trail/All mountain Wheelset 26"
    By bboyuseless in forum Wheels and Tires
    Last Post: 04-09-2013, 07:56 AM
  2. Replies: 27
    Last Post: 09-15-2012, 09:40 AM
  3. Lightest chromoly / steel 29" frame?
    By esku in forum 29er Bikes
    Last Post: 04-26-2012, 11:44 PM
  4. A DJ frame with 1.5" headtube, and 150mm rear axle spacing?
    By Scarier in forum Bike and Frame discussion
    Last Post: 10-25-2011, 09:00 PM
  5. Can I use 180mm Fork for 150mm Frame Travel?
    By spoonmarvs in forum All Mountain
    Last Post: 07-31-2011, 10:27 PM
Members who have read this thread: 4
