Results 1 to 8 of 8
    Nov 2006
    lightest 27.5 100mm travel fork?
    I am looking to build a weight weenie build starting w/ a 27.5 hardtail frame and am trying to sift through the information and searching for a weight weenie 27.5 100mm travel fork. It doesn't look like RS or DT/Swiss make their lightest forks in a 27.5 size. I also prefer to avoid a lefty. I really want to build a 27.5. Thanks in advance.
    ups and downs
    You're likely looking at a SID XX or the DT Swiss in the 1525gm range in conventional forks. The Fox Float 27.5" is around 1600 with the 15mm axle.
    Not sure why you wouldn't consider a Lefty in the 1350g range.
    Jan 2009
    Magura TS8 R (non electric) 1400g claimed
    Fox Float 26 CTD trail adj (fits 27.5) 1440g claimed
    I have a Formula 33. Mine is straight steerer, but without the axle (50g) and a full, uncut steerer it weighs 1495grams on my scale.
    Maromero
    Reputation: doccoraje's Avatar
    Quote Originally Posted by mtbmitch2 View Post
    With 90 mm of "long travel" it's out of the range of most 650b full sus. I am going for a TS8 Magura 120 mm of travel
    Ole
    Ole is offline
    WR Compositi has one in te 1270g range. They make MX suspension stuff, so supposedly this fork is pretty dialed.
    WR Compositi Federgabel 27,5" | 650B AMT2 Carbon 100 mm Remote QR15 t
  1. Replies: 1
    Last Post: 01-26-2014, 09:28 AM
  2. Lightest 29er 100mm fork in US
    By dortega in forum 29er Bikes
    Last Post: 11-05-2013, 08:23 AM
  3. Lightest 20mm 1 1/8 steerer tube 140mm travel fork?
    By crankpuller in forum Shocks and Suspension
    Last Post: 04-24-2011, 08:54 PM
  4. Still looking for a cheap 100mm travel fork.
    By Britishnate in forum Arizona
    Last Post: 01-25-2011, 12:18 PM
  5. Salsa Cromoto 26" fork to replace 100mm travel fork
    By rth009 in forum Shocks and Suspension
    Last Post: 01-03-2011, 09:51 PM
