    STS
    STS is offline
    Reputation: STS's Avatar
    lightest 20mm through axle front hub?
    I know it's a litle bit contradictory
    But I want to mount a light Enduro bike with that kind of front fork/hub
    The lightest 20mm hub I've found is the Tune King MK, around 163g
    Is there any other option lighter?
    Hope Bulb is around 180g
    Any rumour about American Classic light 20mm hub?
    Bump for a great question I need to build a new all-mountain front wheel with a 20mm hub and want to keep it as light as possible without getting into fragile territory.
    Any issue with the Tune 20mm front hub?
    Max
    Max is offline
    Velodramatic
    Reputation: Max's Avatar
    the new Hope Pro2 Thru-axle hub is also very leightweight. check them out at hopetech.com (me thinks the 20 mm weight must be listed somewhere; the normal one weighs a bit more at a mere 190 g)
    Skinny guys fight 'til they're burger
    beer is good
    Reputation: Nels's Avatar
    The Hope Bulb is 185, the Pro2, 20m is 174. Also the DT Swiss spoke calc. lists a 20mm
    thru axle 240s at 163gr. Maybe they have something in the works?
    Steve
    "looking California, feeling Minnesota"
