Results 1 to 59 of 59
    Reputation: WolfTooth's Avatar
    Lighten up that XX1 Crankset
    Just in at Wolftooth, SRAM direct mount Drop Stop Chainrings
    We were happy to see them come in with a 28 gram weight savings over XX (and cheaper to replace):
    Lighten up that XX1 Crankset-sram-32-spider-wgt.jpgLighten up that XX1 Crankset-dm32-wgt.jpg
    more pics are available along w/ near term arrivals of other rings are on our facebook page....
    wolftoothcomponents.com
    lamer
    Reputation: llamma's Avatar
    Any plans to produce a Specialized/Lightning crank direct-mount chainring?
    Formerly of Kent
    Reputation: Le Duke's Avatar
    120mm 34t and 36t! Please!
    Death from Below.
    Reputation: phlegm's Avatar
    Very nice, but shouldn't you be adding 4 bolts to the second weight?
    I <3 dirt
    Reputation: Ilikemtb999's Avatar
    Oct 2010
    Quote Originally Posted by phlegm View Post
    Those are there to mount up an optional bash guard. No bash = no bolts
    Ah, I see - and I assume they're captured in the XX1 ring, i.e. not removable?
    I <3 dirt
    Oct 2010
    What?
    Sep 2004
    He is stating in the pictures the SRAM chainring has the bash guard bolts installed - the Wolf Tooth does not.
    What do the bolts weigh? Can you remove them from the SRAM if you are not running a bash guard?
    This would give you a more accurate weight difference.
    I <3 dirt
    Oct 2010
    Quote Originally Posted by cmanser View Post
    The sram one is a spider and ring that bolts together with an odd BCD. The wolftooth one is a one piece spiderless design with holes to mount an optional guard.
    If you removed the bolts from the sram one it wouldn't work. The pictures and weights are 100% comparable as is.
    Got it - I reversed your post #5. With the SRAM, the idea is that you can swap out the ring on-the-fly, correct (without removing the whole assembly)? There's an obvious weight penalty to pay for that.
    I <3 dirt
    Oct 2010
    Ah you thought I meant the sram. Gotcha.
    It's the axle
    Reputation: Gregg K's Avatar
    Excellent. One piece of metal.
    Also, I like the minimal flashiness.
    Note to self: 85% of FTP for 20 min.
    Reputation: 7HVN's Avatar
    ETA on the 28 tooth?
    @7HVN - Probably Late May at the earliest. I will update the date/week when I get that pinned down. I promise they are coming though. Note that the 32 and 34 will share a bash guard and the 28 and 30 will share a bashguard.
    SUBLIM8er
    Reputation: Axis II's Avatar
    Quote Originally Posted by llamma View Post
    +1 on this request.
    Every man has inside himself a parasitic being who is acting not at all to his advantage.
    William S. Burroughs
    Can you guys enlighten us (because we non of us follow Specialized as closely) on which bikes from Specialized come with the Lightning direct mount? Is is just SWORKs?
    SUBLIM8er
    Quote Originally Posted by WolfTooth View Post
    Yes, I think this is true. SWORKS components are only spec'd on the SWORKS bikes. Lightning sells a lot of their cranksets in addition to what Specialized produces so, I would think there would be a demand for a direct mount option. FWIW, I asked Lighning directly before I bought my last crankset from them if they had any plans for such an option and they did not.
    lamer
    Yes, the S-works cranks come stock on S-works bikes, but you can also purchase them separately. Info is here:
    http://www.specialized.com/us/en/ftb...mtn-crank-arms
    I'm not really sure why they're not more popular considering they're relatively inexpesive, stiff, and super light. I've got a set on my Niner Jet 9 RDO with the Lightning spider. These cranks are based on Lightning's design here:
    http://www.lightningbikes.com/cranks/index.html
    You can see how the two mate here:
    I got s works cranks & I would definitely buy this product if produced! Come on Wolftooth, make it happen!
    Nope, those bolts are for if you want add a bash guard. If no bash guard, this beauty mounts right on your crank arms+spindle.
    Of note is that we don't feel the Enduro crowd has been very vocal. Maybe they have and we don't know it, but could there be a better application for Drop Stop rings than enduro? Our epic adventures in Moab/Fruita on our 104BCD 30 tooth would say no=)
    Jan 2011
    Do these play well with BB30 cranks? fit and chain-line?
    Hey Ardmoregor,
    These are only for the GXP right now. The bb30 has a different mounting spline.
    BB30 a potential future product for us, but right now most of the demand is on GXP.
    @Armdmoregor,
    I mis-typed the above (it was early sorry! =).
    The mounting spline is the same, but the current DM Ring offset would put the ring at the inner or granny gear position on a BB30. So, the current Sram DM would physically mount ok, but the chainline would not be good for the small cogs on your cassette.
    Thanks for the clarification. Looking forward to having the bash option for BB30. Would have been nice if it used a standard BCD though.
    When we make the BB30 DM they will have a bash option.
    Speaking of Bash Guards for our DM chainrings, this just in: https://www.facebook.com/pages/Wolf-...55112457987558
    The bash guards weigh 50 grams...
    Reputation: Epic_Dude's Avatar
    May 2010
    With the SRAM XX1 1x11 drivetrain you get 3 main advantages, 1) Chain stays on the chain ring, 2) No chain slap because of the clutch derailleur, 3) a nice big 42T rear cog.
    If Wolftooth Components made the XX1 style chain ring for a 104 BCD for a Shimano crank, I would have gone that route and paired it up with an XT Type 2 1x10 rear derailleur. I'd only be losing the 42T rear cog but I'd get the other two advantages of the XX1 system and save about $500.
    Hey Epic,
    We do make the 104BCD rings for the XT shadow plus setup=) 104 BCD chainrings
    Reputation: friz's Avatar
    Dec 2012
    Quote Originally Posted by Epic_Dude View Post
    I just put together an SLX setup with the Wolftooth ring. SLX crank, SLX shadow plus derailleur. Havn't had a chance to ride it, but I expect it will be fine.
    Reputation: roaringboy's Avatar
    Quote Originally Posted by Ilikemtb999 View Post
    I was going to say the bolts are in completely different positions on the two rings - i assume they have no part in securing the ring then - just the splined part in the middle?
    I <3 dirt
    Oct 2010
    Quote Originally Posted by roaringboy View Post
    Yep. On the back side of sram cranks there are 3 bolts securing the spider on to the splines.
    xx1 for s works crank
    Hi,
    How much is it ? Id like to use my sworks crank arm forXX1 groupset.
    Thanks.
Name:	SRAM 32 with spider wgt.jpg
ID:	789733Click image for larger version.
    Quote Originally Posted by friz View Post
    Think you could give us a weight?
    Addicted
    I've been riding one of the Wolf Tooth 104bcd 30t Narrow-Wide rings for a few months now in a 1x10 setup.
    I've run Zee, XT and SLX clutch derailleurs with it. I originally started out with an MRP direct mount guide on my Pivot 5.7c and after tons of frustration with the guide bending constantly I gave up and dumped it. The chainring keeps the chain on(my previous RaceFace did not). I'd love to grab a 36t for my DH bike. And if it were possible to have a 28t made with the XTR spline pattern I'd gladly buy a pair of them for my 29er and dj bike.
    2 local guys have since picked up 30t Wolftooth rings for their bikes and are loving them as well.
    Keep up the good work guys!
    Hey Epic,
    What size bolts for the bash guard? Thanks!!
    If you are using a bash guard w/ the anything but the 30 tooth, you can use 8 or 10mm bolts (standard length on most cranksets). If you use the 30t with a bash guard, we recommend 12mm bolts to assure enough threads are engaged (30t rings are threaded and offset)
    -WTC
    On your left.
    Do the Sworks cranks work with BB92 frames?
    Is there any other 180mm crank for BB92 that can run 28t XX1 ring - seems with wolf tooth components the limit is 30t for all except SRAM (means no 180mm cranks).
    M
    lamer
    Quote Originally Posted by Motivated View Post
    The Sworks cranks are BB30 only. They fit the PF30 BB on my Niner JET 9 RDO, but with a Lightning reversible 64/104 BCD spider there is no room for a small chainring up front. That's obviously not a problem for anyone wanting to do 1x, and it provides a nice chainline for the middle ring position. The Sworks cranks are a licensed copy of the Lightning cranks, and they are available for both BB91 and BB95. I don't really know what the differences are between BB91 and BB92. Unfortunately, the Sworks cranks are $300 while the Lightning MTB cranks are $740.
    XTR M985. It was mentioned in the other thread that a 28T 88BCD ring might be a future offering from WolfTooth.
    On your left.
    OK, found the other thread. With 30t on M985 (88BCD), looks awesome, but there is very little space from bottom of the tooth relief to the spider. Is a 28t even possible? WTC?
    In addition to what I know from years of riding, I've been doing some gearing calcs including power, cadence, speed and gradient. I'm convinced I need the 28t with XX1 cassette for climbing and OK giving up 1 gear at top end. Currently I run 24t granny to 36t cassette (same as 28x42) and use it lots - even sometimes wishing for something slightly lower.
    M
    Yep, 28t is possible on the 88BCD and we will be making them. It will be a late summer product at the earliest, as there have been limited requests. If we saw more requests, we would probably bump the priority.
    Wanted to give some kudos to the Wolftooth folks. I had to return a chainring (I ordered the wrong one), and they got back to me very quickly. Great customer service - thx!
    The spiderless rings would work on an XO1 crankset as well correct?
    I know the BCD is different on the XX1 vs XO1 but if you aren't using the spider it shouldn't matter correct?
    '14 Yeti SB95c--Pike'd
    Thumper
    Reputation: WickedLite's Avatar
    Guess your rings are compatible now WolfTooth. Lightning accepts the XX1 ring and that means yours too. Now they just need to make 170/190mm spindles for fatbikes!
    Attachment 853874
    @WolfTooth, can you guys do ano colors on the rings??
    Also, any experience using an 11speed non xx-1 chain, e.g. KMC x11?
    Quote Originally Posted by sickspeed16
    Your not all mountain unless your runnin' crushed dew cans..
    '12 Scalpel 29er Carbon 1
    '13 SuperSix EVO Red Racing
    Nov 2006
    Any plans for a hollowgram direct mount compatible chainring?
    Nov 2012
    @Slim83 I don't know about Wolftooth but I know that AbsoluteBlack will be making some in January, they said so on their FB page.
    @RVM - we haven't used any 11 spd non xx1 chains on mountain systems. I would suggest checking with KMC. I wouldn't be surprised if they are not compatible due to cog spacing on road 11 spd.
    @Slim -we may do them in the spring. However, so far the demand seems pretty low for these.
    scribed so that if there is an update for BB30 DM Wolftooth 32 tooth please
    Wolftooth: I don't know what your economies of scale are but demand might be higher than you think - I think it's fair to assume that many Hollowgram MTB folk (perhaps even the majority) would 1) be going XX1 1x11 eventually for weight / performance reasons and 2) would go for your chainrings over SRAM for the 28g weight saving as well as cost....
    Apart from the weight, When you factor in the need for a "special" Hollowgram XX1 spider ($145 for the Cannondale one at Cannondale Experts!), Sram XX1 chainring and bolts, your option would work out MUCH cheaper.
    You're also doing away with another interface (Chainrings bolts), which is another place for creaks and things to come loose. I'd guess mud-shedding is better with spiderless too...
    Wanted to add some info for S-Works/Lightning crank users. I just moved from a 32T Wolftooth 104 BCD ring (with the original spider) to the Wolftooth spiderless ring. Net savings are 32g, and it looks a lot cleaner.
    A note on installation: to remove the spider, or more specifically to remove the spider lockring, you'll want to find a shop that has the (expensive ~$300) Specialized lockring removal tool - see this thread:
    Spider removal tool
    Don't let a shop tell you "sure, we can remove the lockring" without confirming first that they aren't hoping to use the Park tool. That tool doesn't have a wide enough opening to slide over the crank cylinder. Two friggin shops did this to me.
    Also note that Quarq, the power meter makers sell a tool for $40 that could be a much cheaper alternative, should you feel the need to do it yourself:
    https://www.quarq.com/store/item/1714/
    You can also find others on the Bay, and another one here:
    Specialized S-Works crank spider lockring tool | Strada Wheels
    lamer
    Lightning also sells an inexpensive lockring tool that works for S-works/Lightning cranks. It's been a while, but I remember it being something like $35. You just call them and order it. The tool will not attach to a wrench. You'll need a vise to remove and re-install the lockring, like so:
    Spyder installation
    Thx for the tip. The shop installed mine via the Specialized tool and a vice in the same manner. So much for exact torque specs.
    Reputation: Bullit_cn's Avatar
    @Armdmoregor,
    Hope I read it earlier. learned it while installing my 34T on my XX1 arm.
    When are you guys making a direct mount ring for XX1?
    Looking forward to it...
    When trails gets tougher, Just stand up and deliver.
    Hey Bullit,
    We have them now for XX1=)
    You just need to figure out which ring type you need. If you have GXP crankset, get the SDM for GXP ring. If you have a BB30 crankset, the 3rd picture on the GXP or BB30 Short Spindle product pages will show you how to determine which you need.
    Direct Mount for SRAM GXP Cranks ? wolftoothcomponents.com
    Direct Mount for SRAM BB30 Short Spindle Cranks ? wolftoothcomponents.com
    Hey Bullit,
    Great!
    I would be needing a PF30 short spindle ring then.
    Thank you,
    Nov 2006
    @ wolftooth
    Have you guys reconsidered a hollowgram direct mount ring? I would buy one in a 36 and 34 and I am sure there are quite a few others that would like one.
    Hey Slim,
    I will just say it is "high" on our list for next products when we get that some time to get the designs done. Yes, you can expect this product from us=) We hope it is this summer yet.
    Cheers!
    Brendan
    Lactic Acid is my friend.
    Reputation: split's Avatar
    Any special tool needed to remove the spider from XX1 cranks and install the wolftooth?
    I <3 dirt
    Oct 2010
    Its 3 T25 bolts
  1. Can I lighten up?
    By shockfinder in forum 29er Bikes
    Last Post: 11-25-2012, 08:36 AM
  2. Please Help Lighten My Rip 9
    By coke in forum Weight Weenies
    Last Post: 08-10-2012, 05:42 AM
  3. Tryin to lighten up my HD, need help!
    By manchvegas in forum Ibis
    Last Post: 02-28-2012, 07:28 AM
  4. trying to lighten up my mojo HD... HELP..
    By manchvegas in forum Weight Weenies
    Last Post: 02-23-2012, 01:04 PM
  5. how to lighten my rumblefish one
    By TwoNin9r in forum 29er Bikes
    Last Post: 08-08-2011, 08:46 AM
Members who have read this thread: 7
