Results 1 to 15 of 15
    Jan 2005
    Light weight bashguard?
    I like using bashguards instead of my large chainring for going over logs, roots, and occasional rocks. I'm not a downhiller; I'm more of an All-Mountain/Light Freerider. The most important thing is that I don't want to add any weight to my bike. Is this possible? I just purchased a TruVativ plastic bashguard but it weights 264 grams, which seems too heavy to me. Any ideas on how I can replace my large chainring with a bashguard and not add a bunch of weight.
    jbf
    jbf is offline
    Reputation: jbf's Avatar
    Corerat - 86 grams
    too bad they do not make it in 4-bolt anymore ...
    Quote Originally Posted by Beach710
    If I recall both the Tuvativ rockguard http://www.jensonusa.com/store/product.aspx?i=CG707C00 and the RaceFace bash ring http://www.pricepoint.com/detail/112...Bash-Ring-.htm are in the 130-140 gram range. Both can be found for around $25-30 and are made of 5mm thick aluminum. I have a few friends with RF, and they've held up well and are give better clearance than the e-thirteen charger I have (210 gr). Also, I've heard good things about the salsa guard.
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    learn how to use the search function...
    http://forums.mtbr.com/weight-weenies/bash-ring-doesnt-weigh-ton-6253.html#post48718
    Jan 2005
    Quote Originally Posted by mtb_biker
    http://forums.mtbr.com/showthread.php?p=48718
    I know how to use the search function. This just adds more weight becasue it does not replace the large chainring, it mounts over existing large chainring.
    The Race Face Bash Ring at 140 grams sounds like the best option, so far.
    Maybe I should just grind down the teeth on my large chainring and use that as a light weight bashguard???
    Bad idea...
    I'd be willing to bet it'll bend the first time you whack something with it. Unless you've got a thick downhill ring, it's going to be pretty thin aluminum. My stock Truvativ 44t ring weighed 29 grams when I took it off and was about 1-2mm thick, not to sturdy. Oh yeah, and it kept getting all bent up when I'd hit something.
    Reputation: GearHead's Avatar
    Dec 2004
    I am doing the same thing as you right now, looking for a light chainring guard. When you search for bash guards you find heavy FR/DH ones, chain guards seems to find light weight XC ones. So far the lightest looking ones are Spot chainring guard and Sals chainring guard. Both look very minimalist.
    Dec 2004
    I am doing the same thing as you right now, looking for a light chainring guard. When you search for bash guards you find heavy FR/DH ones, chain guards seems to find light weight XC ones. So far the lightest looking ones are Spot chainring guard and Salsa chainring guard. Both look very minimalist.
    FSA bashring is only 98 grams, not too bad.
    Te mortuo heres tibi sim?
    Spot Brand makes what you want......
    http://webcyclery.com/product.php?pr...&cat=21&page=1
    it's not super beefy, but will take a little abuse. i've got one on my SS, which only gets once in a while bashes.
    my much beefier geared ride uses one of these:
    -> SickLines.com <-
    Um that link i posted has just about all the bash guards in it that are light.
    Spot etc.,
    Using the big ring as a bash guard woudl be ok for a day or so, but after it folds over you're screwed. Especially if it folds over into the chain rings.
    With all those bash rings you can remove/replace you big chainring without a problem... Unless i'm missing something that post is exactly what you wanted...
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    Envy makes some light bash rings that replace the big ring, around 100grams.
    I don't post to generate business for myself or make like I'm better than sliced bread
    Recovering couch patato
    Reputation: Cloxxki's Avatar
    OT, but for riding logs (which I don't), is round even a smart shape for a bashguard? I take one keeps the pedals level when grinding over the long, why not make a bashring that is slightly "hollow" or just square rather than round?
    Klok - XC - Skate - Ski
    Jan 2005
    Spot etc.,
    Your right, I see them now. Your link brought me to a specific thread with only 1 bash guard. When I went up a level to the main discussion I then saw all of bash guards. That's exaclty what I was looking for, thanks.
    Quote Originally Posted by Cloxxki
    The round guards "slide" over logs,etc. Some of the brands make them with smail "teeth", kinda like a super dull saw blade, that bite into the log so you can pedal over.
    YES, you should just grind down the teeth on a large chainring. It works great! After 3 years of using one (in Colorado, where there are tons of rocks to bash into), it's still doing just fine and isn't bent at all.
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. Plans of building a light weight FLUX?
    By roy harley in forum Turner
    Last Post: 10-22-2004, 08:45 AM
  3. Clydes and light weight ?
    By redxj in forum Clydesdales/Tall Riders
    Last Post: 10-17-2004, 11:20 AM
  4. The Official Weight Weenies F.A.Q
    By Trevor! in forum Weight Weenies
    Last Post: 02-25-2004, 01:31 PM
