Results 1 to 24 of 24
    Light, strong 30.9 mm seatpost?
    I'm looking for a seatpost for a new bike build - Maverick American ML7. I don't really like the Thomson posts and they are very heavy, but I do trust them. I would prefer to use the USE Alien (Al or Ti) seatpost, but they don't make a 30.9 and I am concerned about strength for the steep seattube angle of the ML7. I weigh about 165 lbs. Would a 27.2 mm post and shim be safe?
    Any other options that may work for this application? I'm really not interested in Extralite since I have not had very good luck with their products although I have never bent or broken a seatpost.
    Quote Originally Posted by B R H
    Maybe Thomson makes a Masterlight in a 30.9.
    I use a Syncros carbon in my 30.9, and I weight 165, but I don't have that steep seattube.
    Scanning the QBP catalog, your choices (just thru them....) are FSA, Kalloy, MaxM, Race Face, Ritchey, Syncros, Thomson, and Titec... all have posts available in that size.
    The lightest of those would be the MaxM which is a carbon post....listed at 220 grams for a 400mm... the Thomson in 410mm is listed at 265 grams... and they have a reputation for being very damn solid. I am about 220 lbs and haven't had any issues with the one on my hardtail.
    Thanks for the replies. I'll probably go with the Thomson because MA recommends it. I'm not sure the MaxM post has enough saddle tilt adjustment to make up for the slack seat tube angle, but I have one lying around somewhere to measure (of course it's the wrong size for the ML7).
    I wouldn't even think of putting a lightweight carbon post on a bike like a Maverick! Look at the angle of your post! Why would you even think of puting a super light carbon post on a full suspension bike with that seatpost angle? Get the biggest toughest burleyest post you can get. Your bike is not a superlight bike, why try to put a superlight post on it?
    Because it all adds up! The bike will be under 24 lbs. MaxM said their post would be fine for this application so I assume the Easton EC70 would work too. If USE made a version of their carbon post in 30.9 mm, I'd get that one.
    Reputation: dyg2001's Avatar
    I just bought a Maverick ML7 and will be using the Thomson post they recommend. I'm kind of with russw19 on this--the ML7 is a frame that puts the seatpost at an extreme rear angle, and the suspension design encourages taking hits while seated, so major stresses will be put on the seatpost. I am not a fan of USE posts. I had a CF one on my roadbike and found clamp adjustment to be cumbersome. The bond between the clamp and shaft failed in a crash, and getting the shaft out of my frame was a major headache. But if you find a light post that works with the ML7, please post a followup review after six months or so. Good luck!
    What are the details on your setup? A 24 lb ML7 sounds like a nice bike. Mine will be heavier but hopefully sturdy:
    Frame: Maverick ML7, black, size L, “Nevus”
    Fork: Maverick DUC32, black
    Headset: FSA Carbon
    Stem: Maverick 90mm
    Bar: Maxm MX-5 carbon riser
    Crankset: Shimano XT Hollowtech
    Shifters: SRAM X.9 Trigger
    Front derailleur: Shimano XT E-type
    Rear derailleur: SRAM X.0
    Cassette: SRAM 9.0 11-34
    Chain: Wipperman Connex stainless
    Shifter cables: Nokon alloy
    Front brakes: Hope Mono M4, 205mm rotor
    Rear brakes: Hope Mono M4, 180mm rotor
    Brake lines: Goodridge braided steel
    Front wheel: Maverick 24mm thru-axle hub, 14/15 spokes, Mavic XM819 rim
    Rear wheel: Hadley 10mm thru-axle hub, 14/15 spokes, Mavic XM819 rim
    Seatpost: Thomson Elite 30.9mm
    Tires: WTB Weirwolf 2.1 UST
    Pedals: Crank Bros Candy
    Grips: ODI Lock-On
    Saddle: WTB Laser V Team DH
    Most of the weight savings over your build comes from using 11-30 8-speed Gripshift and lighter wheels, pedals, & brakes. I don't have all the parts yet, so after I confirm all the weights, I'll post the final weight here. I'm pretty sure it will be just under 24 pounds even with bigger "play" tires.
    Since you chose a large frame, I'm curious how tall you are and what your inseam is? I'm 5' 10.5" with a ~33.5" inseam (measured, not pants size). A large frame with DUC32 and the longest stem Maverick offers (105 mm?), was too short lengthwise and the bike was also too tall. The top tube lengths don't increase much with frame size, but the standover height jumps 2" between the mediium and large. I'm hoping a medium will work out with standard fork and 120 mm stem.
    I like the USE Alien posts and haven't had any problems with them yet. I had a carbon post but gave it to a friend since I needed a shim and that made it almost as heavy as the Ti version I use instead (also silver Ti color looked better).
    I agree that a carbon post may be risky and that is why I asked. MaxM told me their post would be fine. I'll be trying both the Thomson and Easton EC70 carbon, but I think I'll need the carbon to get the cockpit length I want. The EC70 has alot of setback... hopefully not too much. I suppose this will also stress the post even more. I've tried contacting them to see if it will be OK, but their website refers to contacting dealers instead. One dealer, Wrench Science, didn't think it would be a problem if I could find a carbon post that would work (I assume they are worried about getting the seat angle right).
    If it doesn't work out (i.e., it breaks), I'm sure you'll see a post here.
    What about an Extralite the post UL. 30,9 X 36 = 183 gr . I works nice on my Epic.
    Esben
    I am 6' tall with a 32" jeans inseam. I bought a size L frame with the DUC32 fork and 90mm stem. I have not test-ridden the bike. The purchase was a big leap of faith, especially since it will be my first full-suspension bike. I'm sure it will take a lot of getting used to. I used to race a lot--cat 3 road, cyclocross, MTB XC years ago--but now I don't have time to train and want to ride for fun rather than competition. Night riding with my labrador retriever and stuff like that. So a do-everything trail bike like the ML7 really appealed to me. I'm sure my position on the Maverick will be very different than my racy Merlin XLM hardtail (17.5" frame, 13cm stem, flat bar, old SID 60mm fork).
    Unless your arms are abnormally short or you wear pants that are really short , I think you'll be sitting quite upright compared to anything you may have raced. Maybe that's what you're after though. The DUC32 is going to feel like a motocross fork compared to that SID! It's a really tall fork (from an XC perspective at least). Very stiff and light though. I don't think you'll be disappointed with the frame (other than the minor cable routing & front derailleur quirks).
    I can't wait to start getting mine put together this week. Below is my build data. The weights in red are not confirmed, but should be very close.
    PS. Have you actually measured your height or inseam lately? I wear a size 32 pants and was 5' 11.5" tall not too long ago. I need to stop landing on my head!
    <TABLE cellSpacing=0 cols=6 rules=groups border=1 frame=void><COLGROUP><COL width=156><COL width=34><COL width=192><COL width=47><COL width=34><COL width=351></COLGROUP><TBODY><TR><TD align=left width=156 height=14>Component</TD><TD align=left width=34 SDNUM="1033;0;#">Year</TD><TD align=left width=192>Model</TD><TD align=middle width=47 SDNUM="1033;0;0.0">Weight</TD><TD align=middle width=34 SDNUM="1033;0;0.0">Units</TD><TD align=left width=351 SDNUM="1033;0;@">Notes</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">bar</TD><TD align=left SDNUM="1033;0;#">2002</TD><TD align=left SDNUM="1033;0;@">Easton EC70</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="125">125.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">580 mm x 3 degree sweep, no rise, carbon fiber.</TD></TR><TR><TD align=left height=14>bar ends</TD><TD align=left SDNUM="1033;0;#">2003</TD><TD align=left>Extralite UltraEnds</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="54">54.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Black.</TD></TR><TR><TD align=left height=14>bottle cage bolts</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left>Maverick American</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="6">6.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">(4) M5 x 16 mm, alloy.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">bottom bracket</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left SDNUM="1033;0;@">Race Face Dues XC</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="111">111.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">X-type, includes L, R, sleeve.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">brake (F)</TD><TD align=left SDNUM="1033;0;#">2003</TD><TD align=left SDNUM="1033;0;@">Formula B4SL+</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="228">228.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Pump (Al), caliper (Al), line (cut), bolts (Al), pads, oil.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">brake (R)</TD><TD align=left SDNUM="1033;0;#">2003</TD><TD align=left SDNUM="1033;0;@">Formula B4SL+</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="240">240.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Pump (Al), caliper (Al), line (cut), bolts (Al), pads, oil.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">brake rotor (F)</TD><TD align=left SDNUM="1033;0;#">2003</TD><TD align=left SDNUM="1033;0;@">Formula B4SL</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="123">123.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">160 mm steel rotor, (6) steel bolts.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">brake rotor (R)</TD><TD align=left SDNUM="1033;0;#">2003</TD><TD align=left SDNUM="1033;0;@">Formula B4SL</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="97">97.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">140 mm steel rotor, (6) steel bolts.</TD></TR><TR><TD align=left height=14>cassette</TD><TD align=left SDNUM="1033;0;#">2002</TD><TD align=left>Shimano XTR CS-M950</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="210">210.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">8 speed ak (11-13-15-17-20-23-26-30), including lockring.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">chain</TD><TD align=left SDNUM="1033;0;#">2003</TD><TD align=left SDNUM="1033;0;@">SRAM PC89R Hollow Pin</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="250">250.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">104 links, including masterlink, lubed.</TD></TR><TR><TD align=left height=14>chainring (large)</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left SDNUM="1033;0;@">Race Face Deus XC</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="89">89.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">4 bolt @ 104 mm, 44 teeth, ramped & pinned, aluminum.</TD></TR><TR><TD align=left height=14>chainring (middle)</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left SDNUM="1033;0;@">Race Face Deus XC</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="45">45.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">4 bolt @ 104 mm, 32 teeth, ramped & pinned, aluminum.</TD></TR><TR><TD align=left height=14>chainring (small)</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left SDNUM="1033;0;@">Race Face Deus XC</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="23">23.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">4 bolt @ 64 mm, 22 teeth, aluminum.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">chainring bolts (inner)</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left SDNUM="1033;0;@">Race Face</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="4">4.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">(4) 8 mm, alloy.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">chainring bolts (outer)</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left SDNUM="1033;0;@">Race Face</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="8">8.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">(4) 8 mm with nuts, alloy.</TD></TR><TR><TD align=left height=14>chainstay protector</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left>Maverick American</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="0">0.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Included in frame.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">computer</TD><TD align=left SDNUM="1033;0;#">2003</TD><TD align=left SDNUM="1033;0;@">Sigma BC800</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="33">33.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Computer (w/battery), sensor (wired), Shimano spoke magnet.</TD></TR><TR><TD align=left height=14>crank arms</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left>Race Face Dues XC</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="523">523.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">175 mm, 4 bolt 104/64 mm.</TD></TR><TR><TD align=left height=14>crank bolts</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left SDNUM="1033;0;@">Race Face Deus XC</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="21">21.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Drive side bolt (aluminum), washer (steel), cover (aluminum).</TD></TR><TR><TD align=left height=14>derailleur (F)</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left>Shimano Dura Ace</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="103">103.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Triple, braze-on, model 7703.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">derailleur (R)</TD><TD align=left SDNUM="1033;0;#">2002</TD><TD align=left SDNUM="1033;0;@">SRAM X.0</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="207">207.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Medium cage.</TD></TR><TR><TD align=left height=14>derailleur hanger</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left>Maverick American</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="0">0.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Included in frame.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">fork</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left SDNUM="1033;0;@">Fox Float 100 RLT OE</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="1612">1612.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">100 mm, disc-only, 194 mm steerer.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">frame</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left SDNUM="1033;0;@">Maverick American ML-7</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="2502.5">2502.5</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Size medium, anodized black.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">grips</TD><TD align=left SDNUM="1033;0;#"></TD><TD align=left SDNUM="1033;0;@">Schwinn Stinger ATB</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="53">53.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Clear, cut down, includes bar end plugs (generic).</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">headset</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left SDNUM="1033;0;@">FSA Orbit CF Carbon</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="62">62.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Includes cap & bolt.</TD></TR><TR><TD align=left height=14>hub (F)</TD><TD align=left SDNUM="1033;0;#">2003</TD><TD align=left>Chris King ISO Disc</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="165">165.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">32 holes, silver.</TD></TR><TR><TD align=left height=14>hub (R)</TD><TD align=left SDNUM="1033;0;#">2003</TD><TD align=left>Chris King ISO Disc</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="306">306.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">32 holes, silver.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">hub skewer (F)</TD><TD align=left SDNUM="1033;0;#">2002</TD><TD align=left SDNUM="1033;0;@">Nashbar</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="30">30.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Bolt-on (steel, black).</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">hub skewer (R)</TD><TD align=left SDNUM="1033;0;#">2002</TD><TD align=left SDNUM="1033;0;@">Nashbar</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="35">35.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Bolt-on (steel, black).</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">miscellaneous</TD><TD align=left SDNUM="1033;0;#"></TD><TD align=left SDNUM="1033;0;@"></TD><TD align=right SDNUM="1033;0;0.0" SDVAL="5">5.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Zip ties, grease.</TD></TR><TR><TD align=left height=14>pedals</TD><TD align=left SDNUM="1033;0;#">2003</TD><TD align=left>Crank Brothers Eggbeater S</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="270">270.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@"></TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">rim (F)</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left SDNUM="1033;0;@">Stan's ZTR 355</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="368">368.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">559 x 24 mm, 32 holes, black.</TD></TR><TR><TD align=left height=14>rim (R)</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left SDNUM="1033;0;@">Stan's ZTR 355</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="369">369.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">559 x 24 mm, 32 holes, black.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">saddle</TD><TD align=left SDNUM="1033;0;#">2002</TD><TD align=left SDNUM="1033;0;@">Selle Italia SLR</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="140">140.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Ti rails, black leather cover.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">seatpost</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left SDNUM="1033;0;@">Easton EC70</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="215">215.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">30.9 mm x 400 mm, carbon fiber.</TD></TR><TR><TD align=left height=14>seatpost clamp</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left>Maverick American</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="0">0.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Included in frame.</TD></TR><TR><TD align=left height=14>shift cables</TD><TD align=left SDNUM="1033;0;#">2002</TD><TD align=left>Gore RideOn Ultralight</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="75">75.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@"></TD></TR><TR><TD align=left height=14>shifters</TD><TD align=left SDNUM="1033;0;#">2002</TD><TD align=left>SRAM 9.0 Shorty</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="167">167.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">8 speed, w/Amy grips.</TD></TR><TR><TD align=left height=14>shock</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left>Maverick American</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="0">0.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Included in frame.</TD></TR><TR><TD align=left height=14>shock bolts</TD><TD align=left SDNUM="1033;0;#">2004</TD><TD align=left>Maverick American</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="0">0.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Included in frame.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">spokes (F)</TD><TD align=left SDNUM="1033;0;#">2003</TD><TD align=left SDNUM="1033;0;@">Sapim CX-Ray</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="139.555555555556">139.6</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">(16) 258 & (16) 260 x 2.3/0.9 mm, stainless steel, black & silver.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">spokes (R)</TD><TD align=left SDNUM="1033;0;#">2003</TD><TD align=left SDNUM="1033;0;@">Sapim CX-Ray</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="139.555555555556">139.6</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">(16) 258 & (16) 260 x 2.3/0.9 mm, stainless steel, black & silver.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">spoke nipples (F)</TD><TD align=left SDNUM="1033;0;#">2003</TD><TD align=left SDNUM="1033;0;@">Sapim Polyax</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="11.1074380165289">11.1</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">(32) 2.0 x 14 mm, aluminum, black & silver.</TD></TR><TR><TD align=left height=14>spoke nipples (R)</TD><TD align=left SDNUM="1033;0;#">2003</TD><TD align=left SDNUM="1033;0;@">Sapim Polyax</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="11.1074380165289">11.1</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">(32) 2.0 x 14 mm, aluminum, black & silver.</TD></TR><TR><TD align=left height=14>star-fangled nut</TD><TD align=left SDNUM="1033;0;#"></TD><TD align=left SDNUM="1033;0;@"></TD><TD align=right SDNUM="1033;0;0.0" SDVAL="11">11.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Steel.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">stem</TD><TD align=left SDNUM="1033;0;#">2003</TD><TD align=left>Syntace F99</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="101">101.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">120 mm x 6 degrees, including titanium bolts.</TD></TR><TR><TD align=left height=14>stem spacers</TD><TD align=left SDNUM="1033;0;#"></TD><TD align=left></TD><TD align=right SDNUM="1033;0;0.0" SDVAL="4">4.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">(2) 5 mm x 1.125”, carbon fiber.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">tire (F)</TD><TD align=left SDNUM="1033;0;@">2003</TD><TD align=left SDNUM="1033;0;@">Panaracer Fire XC Pro</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="557">557.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">26" x 2.10", folding, blackwall.</TD></TR><TR><TD align=left height=14 SDNUM="1033;0;@">tire (R)</TD><TD align=left SDNUM="1033;0;#">2003</TD><TD align=left SDNUM="1033;0;@">WTB WeirWolf 2.3 (52/58)</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="744">744.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@"></TD></TR><TR><TD align=left height=14>tire seal system (F)</TD><TD align=left SDNUM="1033;0;#">2003</TD><TD align=left SDNUM="1033;0;@">Eclipse A126U</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="125">125.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Rimstrip, valve, tape, 75 grams sealant, air.</TD></TR><TR><TD align=left height=14>tire seal system (R)</TD><TD align=left SDNUM="1033;0;#">2003</TD><TD align=left SDNUM="1033;0;@">Eclipse A126U</TD><TD align=right SDNUM="1033;0;0.0" SDVAL="125">125.0</TD><TD align=left SDNUM="1033;0;0.0">g</TD><TD align=left SDNUM="1033;0;@">Rimstrip, valve, tape, 75 grams sealant, air.</TD></TR><TR><TD align=middle colSpan=3 height=14>TOTAL</TD><TD align=right SDNUM="1033;0;0.00" SDVAL="10.8428259871442">10.84</TD><TD align=left SDNUM="1033;0;@">kg</TD><TD align=left>
    </TD></TR><TR><TD align=middle colSpan=3 height=14>TOTAL</TD><TD align=right SDNUM="1033;0;0.00" SDVAL="23.8542171717172">23.85</TD><TD align=left SDNUM="1033;0;@">lbs</TD><TD align=left>
    </TD></TR></TBODY></TABLE>
    [QUOTE=B R H]QUOTE]
    Wow, you have really done your homework! Very impressive. There is not much room for losing weight on your planned bike without compromising durability/safety or really driving up costs. I think an XTR crankset might be lighter, and the triple-Ti version of your pedals would shave some grams, but that's about it without really changing things.
    Have you used the Eclipse tubeless system? Is it better than Stan's? I haven't used either. Do you prefer converted normal tires to UST?
    Anyways, good luck with the build. Hopefully both of us will be on the trail within a couple weeks on our new dream bikes.
    My concern isn't the weight of the MaxM post, it's that it is a carbon post on the angle that a Maverick frame will put it on. Carbon posts are designed to be strong in the vertical plane based on the lay up of the carbon. With a post in a normal frame, it's not a big issue because the post is fairly close to vertical. But in that Maverick frame your post is going to be closer to a 45 degree angle, which now means there will be as much stress on the post in the vertical as well as the horizontal plane. That carbon post wasn't designed to be stressed like that. And of course MaxM is going to tell you it will be fine, they are trying to sell you a post. I, on the other hand, am not. So you don't have to take my advice, but if you really needed to save 45 grams and put a suspect post on, I would suggest you picked the wrong frame for your needs. Besides, how much do you weigh yourself? You said 165 and you are trying to get your bike to under 24, right? OK so let's look at the exact difference you will be making by picking the MaxM over a Thomson that Maverick actually recommends for their frame. *And remember, they are recommending it independent of their own interests because they don't have a financial interest in Thomson posts.*
    So you plus bike equals 189 pounds. 189 pounds is 85.806 kgs. Drop 45 grams from that. So 85.761/85.806 means that you are saving 0.0524% by using the MaxM post. For the strength concerns that you will give up, I don't think you are doing yourself any favors by choosing the MaxM post. It's also about $40 more expensive than the Thomson. By the way, the 367mm Thomson post is only 10 grams heavier than the MaxM (which is now a 10th of a percent difference)
    It's your bike and I am not trying to tell you what to buy or how to spend your money, but too many bike and component companies are bombarding consumers with this silly notion that lighter is better and lightweight carbon seatposts will make your bike better. It's a gigantic self serving lie. I am just trying to put things into perspective so that you make a smart choice based on something more than a few grams. I would choose a stronger post over a superlight carbon post based on that frame design and the post's angle. But again, it's your bike, not mine...
    Many of the parts are from my previous bike or are leftovers. According to the WW website, XTR would indeed be about 30 grams or so lighter than the Deus setup, but I got the Deus as a warranty replacement for my cracked Next LP. I've been considering trying one of these new external bearing cranksets since I've had no luck with ISIS, but the plan was to wait until the bugs were worked out while I went thru one more set of chainrings I had already purchased for the Next LP. I've been drooling over the triple Ti pedals ever since they came out, but I just can't get myself to spend that much on pedals. Maybe for the more race-oriented hardtail I hope to put together before spring.
    I've been using Eclipse rimstrips for quite a while now (maybe 2 years?). They are a much nicer system. It doesn't rely on the compression of rubber and glue factor of the sealant to hold the bead. The rimstrip has ridges that make an inner beadlock to prevent tire burping. They are also about half the weight and the sealant doesn't stick to them. I've had zero flats due to punctures since I went tubeless (over 2 years now), but have certainly had my share due to cuts. Take that back. I had a 16 d nail skewer my tire in a race this summer. If I could have got the nail out fast enough, it may have sealed. You also only need to remove the valve with Eclipse (vs. the entire rimstrip with Stan's) to put a tube in (which is still a mess with either system but at least you don't have to pack up a slimy dripping rimstrip!). I still prefer Stan's sealant by a longshot though. I've never tried UST tires.
    I can't wait to put it together... hopefully riding next weekend! Hope yours works out well for you too!
    Even standard seat tube angles place a substantial bending load on a post. I seriously doubt fiber orientation is as important as you assert considering the loads a post is designed to carry to begin with. I am a relatively light rider compared to someone over 200 lbs and I haven't seen any weight limit on carbon posts. I think the clamp bond to the quill would be the most likely failure point, but that's just a wild guess. It may very well turn out that the carbon post doesn't work out for other reasons like setback or seat angle adjustment. Since nobody can offer any direct experience, if it does fit, I guess I'm the guinea pig! Hopefully I won't end up bleeding like a stuck pig! That thought sort of gives new meaning to the phrase "a poke in the eye with a sharp stick!"
    PS. I doubt MaxM would take such a risk to sell 1 seatpost. That's just silly. Have you seen any broken carbon seatposts? That would be much more useful information to share.
    Reputation: zaxxon's Avatar
    Wrench Science post recommendations
    I wouldn't get any posts that have Offset, which is one of the major reasons Maverick suggests the Thomson. We have used carbon and haven't had any failures, yet. USE's clamp is so ***** I wouldn't even think about using that. Easton is coming out with a new NO-offset carbon, Bontrager has a Triple XXX in carbon, but I haven't researched if they make them in 30.9, yet. I do have to agree that getting a carbon post may shave 20 grams, and yes if all added togetther you can trim so weight, but you also have to have some sense about putting the right parts on the bike for weight vs. durability. Form over fashion.
    Thanks for the info on the new Easton carbon post! I may give that a try when it comes out. I hope it has a single bolt design similar to the current one, although I don't know how they could pull that off. Another post that caught my eye was the Syncros carbon but I haven't been able to determine if it will have enough angle adjustment.
    It turns out that the current EC70 comes up just a little short with the saddle angle adjustment. Another 5 degrees and it would be fine. The additional setback is too much at my saddle height. There was no way for me to know for sure until I tried it on the bike. I did some measuring on an ML7 I rented, but there were too many differences to be sure.
    I like the Alien clamp but they don't offer a 30.9 and I wouldn't want to use a shim. I'm not sure if the clamp to post interface would be strong enough with the Alien though. I don't like the Thomson clamp at all. I'm usually not coordinated enough to get the saddle in there without taking it completely apart and then those 2 round nuts just roll all over the place. I trust the Thomson and it looks good even though I dislike the clamp and the fact that it is a tank.
    PS. I'm not sure why people seem to think the ML7 fits a different need than any other light full suspension frame. It's almost 1/4 pound lighter than my Truth frame and almost certainly more durable too!
    Reply from Answer regarding their carbon seatpost:
    "We have tested our Carbon seatpost from angles starting at 55deg to 75deg. This seatpost will be totally safe to be used in your frame."
    FSA makes a headset that light???
    2004 FSA Orbit CF Carbon 62.0 g
    oh its an integrated one huh
    Yup, integrated.
    Smooth as butter and couldn't be more simple to install, but time will tell if these things hold up. It is the headset Maverick recommends for their 6" dual crown fork though, so I suspect they are pretty durable!
    Cabon may not have weight limits but...
    I have watched a 200 lb rider snap a carbon post before, not too pretty. Thomson is nice becasue of two bolts, durability etc. I don't think the Thomson is that heavy, if even 150 grams makes that much of a difference pour out 6 ounces of water. Don't think you'll notice the difference. But kudos on the bike build though, nice.
    I just don't like the Thomson clamp. The rear bolt is at it's max to get the saddle level with this frame. I can't even see if there are 2 threads engaged into the top nut! Those stupid round top nuts roll all over the place when trying to put it all together. I'm usually not coordinated enough to be able to get the saddle rails into that clamp without taking it all apart. Total pain in the butt in my opinion. The nice thing is that it's not something you do very often.
    Regarding the weight, I'll be installing a new saddle tonite that is 100 grams heavier! Ouch! The SLRs just don't last more than 6 months before the padding deteriorates and then my butt soon follows!
    I'm VERY happy with the bike so far otherwise with the exception of the fork.
  1. Lights for night riding
    By Jeff_FLG in forum Lights DIY - Do It Yourself
    Last Post: 07-03-2004, 05:15 PM
  2. Replies: 7
    Last Post: 06-03-2004, 06:54 PM
  3. Need a deal on a 30.9 seatpost
    By seely in forum Where are the Best Deals?
    Last Post: 04-14-2004, 05:05 PM
  4. Help! Need a 31.2 mm seatpost
    By toothpuller in forum General Discussion
    Last Post: 03-08-2004, 01:38 PM
  5. Need a 31.2 mm seatpost
    By toothpuller in forum Passion
    Last Post: 03-08-2004, 11:57 AM
