Results 1 to 51 of 51
    Nov 2008
    Light bike - low cost.:D
    Hi there. I present you my new bike from overseas (Spain).
    Chinese frame and old components from another bike which broke down some months ago. It weights around 9kg (19,82lbs) and I'm planning to reach 8,5kg (18,70lbs) with minor changes along this year. Well, that's it so far, I hope you like it. Bye. Enjoy the pics.
    Light bike - low cost.:D-1.jpg
    Light bike - low cost.:D-2.jpg
    Light bike - low cost.:D-3.jpg
    Light bike - low cost.:D-4.jpg
    Light bike - low cost.:D-5.jpg
    Light bike - low cost.:D-7.jpg
    Light bike - low cost.:D-6.jpg
    Light bike - low cost.:D-_mg_50362.jpg
    Light bike - low cost.:D-tot.jpg
    monster member
    Reputation: Wheelspeed's Avatar
    Wow! That's gorgeous!
    Have fun!
    Nov 2008
    Thanks for posting Wheelspeed.
    Nice bike!
    What brand are those chainrings?
    Nov 2008
    Quote Originally Posted by frenk
    Nice bike!
    Thanks. They're TA Specialities Chinook 44-34-22.
    Link: click here
    Reputation: indian fire trail's Avatar
    Nov 2007
    Pon cubiertas normales con lquido No Tubes, saca los visores de marchas de los pulsadores y ponle una tapita de carbono, tornillos de titanio para la biela izquierda, etc...
    Muy bonita. El kit de ti para los puentes de freno es de TorontoCycles?
    PD: Sorry for writing in spanish, guys...
    Nov 2008
    Thanks for the tips, pal. Id like to keep using tubeless tyres and the ogd on the shifters; Ti-al bolts already spread all over the bike; and yes, ti springs and brakes kit are from Toronto Cycles.
    I guess it's a 80 mm sid fork.
    Nov 2008
    Quote Originally Posted by rondelalune
    Yeap!, a repainted '04 SID WC.
    Light bike - low cost.:D-5a.jpg
    Light bike - low cost.:D-6a.jpg
    Light bike - low cost.:D-7a.jpg
    Village Dirtbag
    Reputation: @dam's Avatar
    WTF happened to that fork? And you mentioned low cost. How expensive was it?
    Nov 2008
    Quote Originally Posted by @dam
    , the fork was re-painted by me and added some decals. I said "low-cost" because everything but the seatpost was in another bike before, and the frame is really inexpensive. Did you read the first post?
    Aug 2005
    Amazing, especiall for a "left-over"-bike!
    Feb 2010
    Great job.
    What primer did you use on the fork? I have heard you need to use a special primer to get the paint to properly stick.
    Nov 2008
    Quote Originally Posted by yellowbook
    Thanks?
    Nov 2008
    Quote Originally Posted by TigWorld
    Great job.
    That's right, I used a water based primer; "Bruguer" is the brand but i supose there must be hundreds of similar products out there. Then two coats of white paint and added some decals and stickers.
    Quote Originally Posted by Rallyator
    Is the special primer used because of the magnesium lowers?
    Nov 2008
    No, it was a "regular" one. It can be used in many metals and other materials too.
    monster member
    Doesn't seem that cheap...
    After your first post, I did a search for that frame because most of the low-price CF chinese frames aren't painted. The only thing I found was about $600.00 from a Spanish bike shop.
    Have fun!
    I have the same frame, black version, paid 550 eur which I consider a great price for a Tomac/Nosaint clone.
    The only drawback is the low bb height which I corrected using a 100mm fork-
    Rallyator I also have the same RCZ seatpost clamp (10g, 9 eur) , but never had the balls to use it for fear of failure. It is the ony clamp I know that uses a tiny M3 ti bolt. Designed for road bikes I guess.
    Do you have some miles on it?
    flyMTBfish
    Nov 2008
    Quote Originally Posted by Wheelspeed
    You're right, they're no longer available at fizzbikes.com, don't know why . This seems to be the same frame but the price isn't .
    Nov 2008
    Quote Originally Posted by Ausable
    I've riden this bike setup for over 5500km and no issues so far. No heavy trails though
    Nov 2008
    Here's my new update, I hope you like it.
    Before, dremelized Xt's:
    Light bike - low cost.:D-_mg_5339.jpg
    After, Ultralevers':
    Light bike - low cost.:D-_mg_5337.jpg
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    wasn't that hard to find... 5 sec google search...
    http://www.rczbikeshop.com/default/b...-size-17.html#
    colours are flip flopped... but same frame...
    Santa Cruz Hightower LT
    EVIL Following
    Nov 2008
    Quote Originally Posted by LCW
    Nope, they look alike but they're not the same, mine is cheaper but heavier .
    LCW
    LCW is offline
    S-lite vs Lite... i see that now...
    EVIL Following
    Nov 2008
    Good for you
    Nov 2008
    Well, well, well...New update!...A little more weight saved!. Apart from brake levers, I've changed brakes, SD 7's for SD Ti's and regular housings for I-link. I've also covered the I-link housing with heat shrink tube to prevent dust ingress and avoid squeaking which seems to be the main, if not the only one, problem of the system. Greetings.
    "They Call Me Bone'z"
    Reputation: facelessfools's Avatar
    is that one long stretch of heat shrink? where did you pick that up?
    RAH!
    Nov 2008
    Quote Originally Posted by facelessfools View Post
    I bought it at an electronic supplies store. Very cheap
    Sep 2004
    Very nice!
    6x7=Dont Panic!
    Reputation: TheRedMantra's Avatar
    Quote Originally Posted by Rallyator View Post
    How innovative!
    Herro prease
    Nov 2008
    Quote Originally Posted by TheRedMantra View Post
    How innovative!
    Thanks.
    Quote Originally Posted by jtack View Post
    Very nice!
    Thanks.
    New changes soon...
    nice, how does it ride?
    Nov 2008
    Quote Originally Posted by stockegsix View Post
    Thanks, I don't feel different from my old alu frame. You know, it's just a bike, not a space shuttle...
    Nov 2008
    Here is it's new look. Double chainring setup (42-29) and Dura-Ace rear mech. Still using an 11-23 cassette until I shift to an 11-32 (XG-999) one. I hope you like it.
    Light bike - low cost.:D-3bis.jpgLight bike - low cost.:D-2bis.jpg
    Light bike - low cost.:D-1bis.jpg
    May 2012
    Thats a very pretty bike
    Are the mech brakes heavier than good hydros?
    The gears make it look like a road bike with a flat bar!
    RAH!
    Nice build, but how can you do all that Weight Weenie dremeling and still have shift indicators installed? They are totally useless and weigh like 25 grams!
    Take 'em off and put some tape over the holes, easy peasy!
    OH, and pretty clearly you don't do a lot of off-road climbing, so I would definitely recommend going to 1x9 for the drive-train. I have gotten away with it in Oregon on real trails if you pick your gears intelligently enough. You can drop massive weight that way.
    Nov 2008
    Quote Originally Posted by TheYoungConnoisseur View Post
    Tks. I don't know, never used discs.
    It isn't, it's just that I'm strong enough to use them. Take into acount that the cassette is not definitive, I'll keep using it until I get an 11-32 one.
    Quote Originally Posted by ginsu2k View Post
    I think you're right, left OGD will go to the drawer. Well, obviously I'm not climbing nonstop, but I need both chainrings...so far. Tks.
    Reputation: 2002maniac's Avatar
    Nov 2008
    If you ran a 38t front ring with an 11-36 cassette you would have nearly as much range as your current setup.
    MaL*size=
    Reputation: MaLoL's Avatar
    Awesome build. I can already smell the Spanish quality behind it. Way to go!!!
    Im thinking about using those heat shrnk tubes too. Do they avoid the creaking sound of the mini i-link housing after washing it with the pressure gun??? Thank you and best regards.
    Nov 2008
    Quote Originally Posted by MaLoL View Post
    Spanish...who?, me?.. no way..
    After more than a year of use no creacking sound whatsoever. Mine are i-link, not mini's though. Regards from...hmm...Happyland.
    Nov 2008
    Hi!, new update. Damper cartdridge replaced by another air spring assembly...almost 200gr saved. It's the new SID WC Quadra Air
    Light bike - low cost.:D-1tris.jpg
    Light bike - low cost.:D-2tris.jpg
    Light bike - low cost.:D-3tris.jpg
    Light bike - low cost.:D-4tris.jpg
    awesome bike.
    What is this seatpost clamp?
    MaL*size=
    Fork tunning makes little sense. Just leave dual air and the other leg empty, you will get the same bad behaciour and even less weight. I would put the damping back.
    Sent from my Nexus One using Tapatalk 2
    Nov 2008
    Quote Originally Posted by leugene View Post
    A very cheap and light one.
    Nov 2008
    That's too scary for me. Tks anyway.
    MaL*size=
    scary? like scary movie???
    Nov 2008
    Yeah, kind of.
    Sep 2012
    Sweet
    Sweet man. How much did that cost?
    Any reccomendations on super cheap carbon xc bars , seat post and stem?
