Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 26 to 50 of 51
  1. #26
    Nov 2008
    Quote Originally Posted by LCW
    S-lite vs Lite... i see that now...
    Good for you
  2. #27
    Nov 2008
    Well, well, well...New update!...A little more weight saved!. Apart from brake levers, I've changed brakes, SD 7's for SD Ti's and regular housings for I-link. I've also covered the I-link housing with heat shrink tube to prevent dust ingress and avoid squeaking which seems to be the main, if not the only one, problem of the system. Greetings.
    Light bike - low cost.:D-1.jpg
    Light bike - low cost.:D-2.jpg
    Light bike - low cost.:D-3.jpg
    Light bike - low cost.:D-4.jpg
    Light bike - low cost.:D-5.jpg
    Light bike - low cost.:D-6.jpg
  3. #28
    "They Call Me Bone'z"
    Reputation: facelessfools's Avatar
    is that one long stretch of heat shrink? where did you pick that up?
    RAH!
  4. #29
    Nov 2008
    Quote Originally Posted by facelessfools View Post
    I bought it at an electronic supplies store. Very cheap
  5. #30
    Sep 2004
    Very nice!
  6. #31
    6x7=Dont Panic!
    Reputation: TheRedMantra's Avatar
    Quote Originally Posted by Rallyator View Post
    How innovative!
    Herro prease
  7. #32
    Nov 2008
    Quote Originally Posted by TheRedMantra View Post
    How innovative!
    Thanks.
    Quote Originally Posted by jtack View Post
    Very nice!
    Thanks.
    New changes soon...
  8. #33
    nice, how does it ride?
  9. #34
    Nov 2008
    Quote Originally Posted by stockegsix View Post
    Thanks, I don't feel different from my old alu frame. You know, it's just a bike, not a space shuttle...
  10. #35
    Nov 2008
    Here is it's new look. Double chainring setup (42-29) and Dura-Ace rear mech. Still using an 11-23 cassette until I shift to an 11-32 (XG-999) one. I hope you like it.
    Light bike - low cost.:D-3bis.jpgLight bike - low cost.:D-2bis.jpg
    Light bike - low cost.:D-1bis.jpg
  11. #36
    May 2012
    Thats a very pretty bike
    Are the mech brakes heavier than good hydros?
  12. #37
    The gears make it look like a road bike with a flat bar!
    RAH!
  13. #38
    Nice build, but how can you do all that Weight Weenie dremeling and still have shift indicators installed? They are totally useless and weigh like 25 grams!
    Take 'em off and put some tape over the holes, easy peasy!
    OH, and pretty clearly you don't do a lot of off-road climbing, so I would definitely recommend going to 1x9 for the drive-train. I have gotten away with it in Oregon on real trails if you pick your gears intelligently enough. You can drop massive weight that way.
  14. #39
    Nov 2008
    Quote Originally Posted by TheYoungConnoisseur View Post
    Tks. I don't know, never used discs.
    It isn't, it's just that I'm strong enough to use them. Take into acount that the cassette is not definitive, I'll keep using it until I get an 11-32 one.
    Quote Originally Posted by ginsu2k View Post
    I think you're right, left OGD will go to the drawer. Well, obviously I'm not climbing nonstop, but I need both chainrings...so far. Tks.
  15. #40
    Reputation: 2002maniac's Avatar
    Nov 2008
    If you ran a 38t front ring with an 11-36 cassette you would have nearly as much range as your current setup.
  16. #41
    MaL*size=
    Reputation: MaLoL's Avatar
    Awesome build. I can already smell the Spanish quality behind it. Way to go!!!
    Im thinking about using those heat shrnk tubes too. Do they avoid the creaking sound of the mini i-link housing after washing it with the pressure gun??? Thank you and best regards.
  17. #42
    Nov 2008
    Quote Originally Posted by MaLoL View Post
    Spanish...who?, me?.. no way..
    After more than a year of use no creacking sound whatsoever. Mine are i-link, not mini's though. Regards from...hmm...Happyland.
  18. #43
    Nov 2008
    Hi!, new update. Damper cartdridge replaced by another air spring assembly...almost 200gr saved. It's the new SID WC Quadra Air
    Light bike - low cost.:D-1tris.jpg
    Light bike - low cost.:D-2tris.jpg
    Light bike - low cost.:D-3tris.jpg
    Light bike - low cost.:D-4tris.jpg
  19. #44
    awesome bike.
  20. #45
    What is this seatpost clamp?
  21. #46
    MaL*size=
    Fork tunning makes little sense. Just leave dual air and the other leg empty, you will get the same bad behaciour and even less weight. I would put the damping back.
    Sent from my Nexus One using Tapatalk 2
  22. #47
    Nov 2008
    Quote Originally Posted by leugene View Post
    A very cheap and light one.
  23. #48
    Nov 2008
    That's too scary for me. Tks anyway.
  24. #49
    MaL*size=
    scary? like scary movie???
  25. #50
    Nov 2008
    Yeah, kind of.
