Results 1 to 10 of 10
    Reputation: nathanbal's Avatar
    light 27.2 carbon seatpost, 25mm setback and at least 400mm length?
    anyone know options? most of the usual ones I know of max out at 350mm and I need the extra length. thanks.
    SUBLIM8er
    Reputation: Axis II's Avatar
    25mm of setback is more then what you will find on "light" post options from what I have been able to discover. This topic comes up again and again here. Someone needs to make one soon. I'm going to try the KCNC Sc ProLite in 400mm with less setback and crank the saddle all the way back on the rails and hope for the best.
    Every man has inside himself a parasitic being who is acting not at all to his advantage.
    William S. Burroughs
    No longer 26
    Reputation: G-Live's Avatar
    bontrager xxx?
    You can't depend on honest answers from dependant hands...
    i went onto the bontrager website and looks as though its only made in 350mm?
    No longer 26
    thought they did 400's too, maybe at one time but no longer? does easton make one? FSA?
    G
    Feb 2010
    Woodman carbo DX. The weight of the 31,6x350 is 149g.
    I think the weight of the 27,2x400 is similar.
    decided to stick with a thomson elite 410mm with a setback. thanks for all the feedback.
    Weight Weenie Addict!
    Edge Carbon....available in 400 mm with setback
    PRO XCR at biketiresdirect.com
    185grams
    59.99
    400mm
    Very nice just picked up 2 of em.
    What is the offset on this seatpost?
    Also bikesdirect specs for this says its 225g?
    Quote Originally Posted by ddkn99
    185grams
    59.99
    400mm
