Results 1 to 33 of 33
    Nov 2007
    New question here. How to Make a New Bike Lighter?
    Hi, Weenies,
    I'm thinking about purchasing a new Giant Lust Advanced 2, which would be my first FS bike. I'm getting older and already have a HT, so I thought I'd try a FS. I ride a lot of the rooty, rocky, technical trails here in the Southeast, so I think a FS would be great.
    I test rode the $8,000 racing version of the Lust today and, yeah, it's a great bike, but the lower-priced Lust Advanced 2 is more in my price range (especially with a discount).
    I only weight 120 lbs so, to me, every gram counts on a bike. Being "light" does have its advantages, but bikes can only get so light. It's hard to ride something when it weighs about 20% of your body weight! I have no idea how much this bike weighs in a size small; even the Giant rep couldn't (wouldn't) tell me.
    Anyway, here are the specs for the bike I'm thinking of buying. I don't mind spending a bit of money to lighten up, but I don't want to go too crazy.
    The first thing I'd do is go to a tubeless set up (any advice on tires?). I expect I can run them on 20 psi which is kinda nice.
    I'd replace the stem and handlebars as well. Should I go carbon or just use EA70 or something like that? Is carbon really that much lighter?
    I have a nice Terry seat and a Thomson masterpiece on my HT that I'll probably use on this bike.
    One of the really nice things I liked about the $8,000 demo bike was the 1X11 drive train set up. It uses SRAM XX1 10x42, 11-speed
    cassette and SRAM XX1, 30T crankset. Is there some way I could get a similar set up for the bike I'm looking at? I'd love to go to one chain ring, but I don't think I can just get rid of the one of the chain rings on the bike I'm looking at. Is it possible, without much hassle, to change to a 1X11 set up?
    Do you have a recommendation for good, light, non-carbon rims? That will probably be something I'll want to replace.
    FRAME
    Frame Advanced-grade composite w/ALUXX SL rear triangle, 4" Maestro suspension
    Fork Fox 32 Float CTD Evolution, w/15mm thru-axle, OverDrive 2 steerer, 100mm travel
    Shock Fox Float CTD Evolution
    COMPONENTS
    Handlebar Giant Connect SL, low rise, 31.8mm
    Stem Giant Connect SL, OverDrive 2
    Seatpost Giant Connect, 30.9mm
    Saddle Liv/giant Contact, Forward
    Pedals N/A
    DRIVETRAIN
    Shifters Shimano SLX, Rapid Fire
    Front Derailleur SRAM X7
    Rear Derailleur Shimano Deore XT, Shadow Plus
    Brakes Shimano SLX, hydraulic disc, 160mm
    Brake Levers Shimano SLX
    Cassette Shimano HG81 11x36, 10-speed
    Chain KMC X10 SL
    Crankset SRAM S1000, 22/36
    Bottom Bracket SRAM Press Fit
    WHEELS
    Rims Giant P-XC2, double wall
    Hubs Giant Performance Tracker sealed bearing, [F] 15mm axle, [R] 142x12mm axle
    Spokes Stainless Steel, 14/15g
    Tires Schwalbe Racing Ralph Evo, tubeless ready, 27.5x2.25, folding
    Thanks for your help!
    ups and downs
    SRAM now has a less expensive 1x11 setup than the XX1, the X01 that is only 70-80gms heavier and almost certainly lighter than the 2x10 drivetrain on the Advanced 2.
    X01 | SRAM Mountain | SRAM
    The wheels are the place where you can likely save some serious weight, especially if you're only 120 pounds, as you could ride all those "race day only" wheelsets and not worry about them being flexy.
    ZTR Podium 27.5 / 650b Wheelset
    The carbon cockpit pieces might get you 1/4 pound over the Giant alloy pieces.
    The stock HG81 cassette is a tank and so are the factory wheels. Start with the wheels since you aren't set on 1x11 or 1x10 and may be buying a lighter 10sp cassette for no reason if 11sp is the end result.
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    The Large 27.5 Anthem 3 (men's version of the Lust) weighed 30 lbs and the Anthem 1 near 25 lbs.
    I don't rattle.
    Nov 2007
    Re: How to Make a New Bike Lighter?
    Quote Originally Posted by Berkeley Mike View Post
    Thanks. Are those weights for the carbon versions? If so, I'm guessing the weight of a small, stock Lust Advanced 2 might be close to 25 lbs? I'm going to call a bike shop and see if they'll weigh one for me.
    Sent from my Z10 using Tapatalk 2
    Nov 2007
    Quote Originally Posted by westin View Post
    Great advice. Thank you.
    Nov 2007
    Quote Originally Posted by rockyuphill View Post
    Thanks. It sounds like the consensus is that I should start with the wheels. The 1x11 felt great on the demo bike. That will just be a future project!
    I just replaced my bar and stem, so will share what I learned.
    I got EC90 SL Riser bars and really like them. $110 on Amazon, 135 grams, super-stiff -- can't feel any flex, and do seem to dampen shock better. It is much warmer on the hands on cold days. I was also attracted to this bar because it was about the length that I had shortened my aluminum bars to. The steering feels a little quicker due to less weight. They installed like regular aluminum bars (recommend using a torque wrench in any case), no carbon paste or anything needed.
    I replaced the stock Bonty lock-on grips (92 grams) with ESI Chunkys (60 grams), so I can't really say how much of the difference in warmness and shock dampening is due to the bars or grips, however.
    Grips are a cheap way to save weight and get more comfort btw. The Chunkys are very plush and are made of a tough silicone spongelike material. You could get lighter and softer grips that won't be as durable, but aren't expensive either.
    I needed to change stem length to fit me. It turned out that it was difficult to save any weight over the stock RXL stem (127g). The LBS loaned me a $25 Eleven81 stem to try for size. It was 130 grams. I couldn't find anything a lot lighter than that. I spent about $15 on titanium screws and saved about 12 grams, still coming in lighter and way cheaper than a new RXL stem, which wasn't available in the size I wanted anyway.
    While I was at it I also replaced the headset cap and screw with a Purely Custom headtube cap and aluminum bolt, $15 and saved 12 g. It is very strong and not "weenie" at all.
    Nov 2007
    Thanks for all the useful comments, everyone.
    Dennis, that sounds like a great set up on the handlebars. I'll definitely check into that.
    Rocky, those Podium wheels look great. I looked around the Stans site at the Crests which are more in my price range. Would you recommend those (not as light as the Podiums, of course). Which tubeless tires would you recommend?
    Now that I'm looking at all this, it seems it would cost about $2,000 to upgrade my bike (new wheels, 1X11 drivetrain, etc.). I could get the same bike with an aluminum frame instead of carbon and save $1,000. I could use the $1,000 toward the upgrades.
    I know carbon will be lighter, but is it significantly lighter? I won't be racing or anything, so maybe an alum frame will be fine for me?
    Thanks again, everyone.
    ups and downs
    A carbon frame could be close to 1 pound lighter than an aluminium frame, but there's no guarantee it would be that much lighter. A carbon frame will almost always be lighter higher up in the frame than alloy, which makes it more nimble feeling.
    It is always cheaper to buy the highest spec bike you can afford as it will always be 30-50% less expensive to buy the lighter factory spec bike than to upgrade a lower spec bike to that same level.
    Now you're at the point where you need to check the real weights of the bikes and set yourself a target weight to determine priorities for spending the money.
    Quote Originally Posted by LucindaInGA View Post
    ijd
    ijd is offline
    I'd be getting a set of Stans Crest or Arch rims. I was looking at a Giant Anthem 29 which had the P-XC2 rims. The 29er version of the rims are over 2kg for the pair (no idea what the 27.5 versions would be)
    A set of 27.5" Stans crest rims are 1520g or the Arch ex are 1685g.
    Reputation: SpeshulEd's Avatar
    Oct 2013
    I'm a bit jealous, I was in love with the Lust I looked at until the bike shop told me it was a woman's bike.
    I think your best bet for making a bike lighter quickly, is replacing the wheelset and the crankset. Those always seem to be the best bang for the buck.
    After that the little things start adding up...cassettes and pedals, bars and stems, seatposts and saddles. Improving all of those cut grams off the bike, but a lot of times, the can get ridiculous just to shave a few grams.
    Hey guys, lets go play bieks!
    Formerly of Kent
    Reputation: Le Duke's Avatar
    I just picked up NIB 1x11 parts on eBay and Amazon for the following prices:
    XO1 RD: $139
    XX1 Shifter: $149
    XX1 Cassette: $305
    All prices included shipping.
    Buy a RaceFace chainring and a chain and you're set.
    Death from Below.
    Jan 2013
    EACP demo days? I was there as well!
    Nov 2007
    Quote Originally Posted by Le Duke View Post
    XO1 RD: $139
    XX1 Shifter: $149
    XX1 Cassette: $305
    Thanks. I knew someone here would know where to find the deals!
    Nov 2007
    Quote Originally Posted by musikron View Post
    Yes! That was so much fun. I came up from Atlanta. The locals are so lucky to have a great bike shop like Sunshine.
    I love the Lust Advanced. It was so fast for me it was almost scary. I love the 1x11 set up. I love 27.5 as well.
    light-bicycle carbon rims are the same weight as crest rims and no flex. Much wider also.
    Wheels and tyres are the most important place to save weight as long as you don't get flex and loose your pedaling effort.
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    If you want to drop weight without spending a ton of money on 11 speed drivetrain, you can just get a Narrow-wide Chainring (race face, wolftooth, etc) and go to a 1x10 drivetrain setup. That should drop about 1lb off the bike.
    These parts are pretty dang heavy compared to what you can find. I would guess you could drop a pound easily here. And it would cost less than a XX1 cassette.
    The wheels on that bike are actually pretty light as far as oem wheels go. Carbon wheels would be a good upgrade. So would going tubeless (especially at your weight). The racing ralph tires are really light.
    Hopefully this helps.
    Nov 2007
    Quote Originally Posted by moefosho View Post
    HandlebarGiant Connect SL, low rise, 31.8mm
    StemGiant Connect SL, OverDrive 2
    SeatpostGiant Connect, 30.9mm
    SaddleLiv/giant Contact, Forward
    Yes, thank you. Where did you find the weights for the Giant components?
    I ride bikes
    Apr 2013
    Giants website.
    Handlebar:
    31.8mm 690mm 9° 5° 19mm 225g
    31.8mm 730mm 9° 5° 19mm 250g
    Stem:
    CLAMP LENGTH ANGLE STEERER WEIGHT
    31.8mm 60mm +/- 8° 1-1/8" 145g
    31.8mm 70mm +/- 8° 1-1/8" 150g
    31.8mm 80mm +/- 8° 1-1/8" 155g
    31.8mm 90mm +/- 8° 1-1/8" 160g
    Seatpost:
    DIAMETER LENGTH OFFSET WEIGHT
    30.9mm 375mm 12mm 325g
    Saddle:
    - Weight: 310g
    I would assume they are pretty accurate.
    Jan 2013
    I saw several ladies on that Lust, what time were you there?
    Yes Jimmy and Sunshine are great. I have bought two bikes from him in the last year, gotten tons of free advice, and a very fair price on accessories. Tonight my wife is going to Liv/Giant ladies night at Sunshine Cycles, which I believe is hosted by Jimmys wife, if you have the time its at 6pm.
    Jan 2013
    I have also found his employees to be generally awesome guys as well.
    Nov 2007
    I was the first one on the Lust. I got there just after they set up. The loop was fun but a bit crowded! Yes, jimmy invited me to the ladies night which sounds fun, but I'm an hour and 15 minutes away and work until 6. I'm sure everyone will have fun tonight.
    Jan 2013
    Ha, I saw you getting ready to go out then, I was there early on the Trance Advanced 27.5
    Nov 2007
    Cool. How did you like it? What else did you try?
    I was trying to concentrate on what was going on. I was at a disadvantage on the trail. It seemed everyone else was local and knew all the trails. I jumped off on some gravel roads and things at one point.
    Yeah, Athens is a great bike town -- all of your major brands with dealers all close to each other. Wife and I rode the new trail at EACP for the first time last week.
    On carbon vs aluminum, I was facing the same decision when I got my "good" bike a couple years ago. I decided to go for Trek's best aluminum frame and spend the difference on good wheels eventually. I wasn't sold on carbon -- I tend to crash a lot and was concerned about durability.
    However, don't say you won't ever race . Last year I decided to try a race at Yargo for the heck of it, and had a really good time. I am not good at it or serious about it, but definitely something I will be doing more of. I did Yargo, Conyers, and Unicoi this year, and managed to place tenth at Unicoi. I am practicing diligently at Yargo and hope to get top 5 this year. Try it once. It will definitely make you a better rider.
    Anyway, back to carbon vs aluminum. It's not just weight, but stiffness and comfort. I own a Trek Superfly AL Elite. I rode their Superfly SL Elite (carbon) at SE Bike Expo this year. NICE bike. The wheels were way better than mine, true, but STIFF, oh man. No flex at all that I could tell. Sub-900 grams on the frame.
    It depends on the quality and design of the aluminum frame and the carbon frame too. My son has a X-Caliber, same geometry and all, but it has the "gold" series frame, and the Superfly is "platinum" series. The Superfly is noticeably stiffer and lighter. I rode another brand carbon a couple years ago and was not impressed.
    So ideally, try the al version if you can, then decide.
    Carbon has gotten lighter, stronger, and cheaper here lately. I'm not planning on getting a carbon frame at this point, but if buying now, I would definitely consider it.
    BTW, how tall are you? My wife is a 5'-even Oriental gal who is currently riding an old 14" Trek 4300 WSD 26er that weighs way more than mine. The only thing we could find in 29" at the bike expo that would fit was the Trek Cali. The Niner rep even brought his 12-y-o daughter's bike for her to try, and no go. We like Trek fine, but it would be nice to have a choice you know.
    We live between Harbins and Yargo. If you ever see a guy in his fifties on a white Trek hardtail, say "hi". I belong to Gwinnett Area Trail Riders, and we have great night group rides at Harbins and Tribble Mill.
    Your X01 rear D for $139 went through? Everyone else had the error/it was a trigger for sale cancellation. Lucky you!
    As for the OP, I purchased my XX1 trigger for 106 delivered, the XX1 cassette for 275 and the rear D for $199. There's an X01 cassette for $260 on eBay and the X01 shifter was on sale 20% off 138 at artscyclery.com a few days ago. Identical to XX1 shifter.
    XO1 RD: $139
    XX1 Shifter: $149
    XX1 Cassette: $305
    Indeed. My aluminum Anthem X frame was only about 140 grams heavier than my Anthem X SL0 frame carbon, but the carbon frame was night and day stiffer. Giant's alloy frames can be super freaky light yet strong.
    Nov 2007
    Quote Originally Posted by DennisF View Post
    Great! I'll look out for you guys. I am sorta burned out on competitions in general. I was doing a lot of trail and road running racing and bouldering comps for a while. Now I feel like I just want to chill and not feel like I have to be training for something. Still, races are fun just for the social vibe. I do miss them. You're lucky to live near some trails. My closest trail is Yellow River and it's 30 minutes away. I have a couple of one-mile loops I can do in the heart of Atlanta, but those are for emergencies only .
    I'm 5'4". Your wife isn't interested in a 27.5? I'm so happy Giant is offering these in WSD.
    Formerly of Kent
    Yeah. I was charged, and I have confirmed shipment via Amazon, and UPS. Hasn't arrived yet, so we'll see.
    Death from Below.
    LucindaInGA: Yeah, if competitions aren't going to make cycling fun for you, don't do it! Me, I sort of enjoy doing something where it doesn't matter if I fail
    Ok on the bouldering -- we lived in S Cal and climbed at Joshua Tree several times. Been to Yona here and that's about it.
    Having the trails nearby IS nice. I can be riding at Harbins in 10 minutes and Yargo in 15. I got into mountain biking because I just needed a way to get in shape (an associate met my wife and accused me of robbing the cradle -- she's 2 years younger ). I knew there were a lot of trails near here that people travel hours to get to. It turns out I really enjoy it.
    Giant seems to be going all-in on 27.5 -- great option for FS, not so sure it is a good idea for hardtails though -- I've never ridden one, however. But no, she isn't married to 29". There wasn't much available in 27.5 until now. She's never tried FS either, and I guess she should.
    Thanks.
    Found this thread with links to what are apparently good light stems:
    Cheap Chinese Alloy Stems
    I ordered one of these. I am using a 80mm 17-deg now, so this 70mm should come out to about the same place if I put another spacer under it.
    Bi King Uno ?6? Lightweight MTB Road 31 8x70mm Stem 91g White LT79H | eBay
    Nov 2007
    Cool. Thanks. I haven't worked on the stem yet. I took all my new bike parts in to Jimmy so he can put them on my bike when it comes in. Won't be too long now!
    I have been hitting Harbins and Yellow River trying to get back into shape.
  1. How can I make my bike lighter?
    By casebutler in forum 29er Bikes
    Last Post: 04-10-2014, 10:15 PM
  2. Newbie - How do I make this thing lighter?
    By Ostate23 in forum 29er Bikes
    Last Post: 10-29-2013, 12:51 PM
  3. Help me make my FSR 29 Comp lighter
    By Duggerfam in forum Specialized
    Last Post: 09-12-2013, 12:00 PM
  4. Suggestions to make my x-caliber lighter!!
    By LilLiz in forum 29er Bikes
    Last Post: 09-06-2012, 08:20 PM
  5. Cheap way to make bike lighter
    By L3ONNOEL in forum Weight Weenies
    Last Post: 08-02-2012, 01:05 AM
