2004 Hope Mono Minis (160/140mm):
1 - Front brake (lever, full-length line, fluid, caliper, bolts, pads) = 270g
2 - Front 160mm rotor with bolts = 118g
3 - Rear brake (lever, full-length line, fluid, caliper, bolts, pads) = 282g
4 - Rear 140mm rotor with bolts = 100g
Total = 770g/set
My previous Minis were
2002 Hope Mono Minis (165/145mm):
1 - Front brake (lever, full-length line, fluid, caliper, bolts, pads) = 271g
2 - Front 165mm rotor with bolts = 147g
3 - Rear brake (lever, full-length line, fluid, caliper, bolts, pads) = 287g
4 - Rear 145mm rotor with bolts = 118g
Total = 823g/set (~53g/set heavier than the Monos)
You'll notice that the weight difference between the Monos and the Minis is nearly entirely in the rotors. There is a neglible difference in the levers, line and calipers.
Total = 770g/set
