Results 1 to 6 of 6
    Reputation: mtrbiker's Avatar
    help finding lightweight brake cable
    Besides Jagwire Ripcord is there anything else for good quality lightweight brake cable housing kit. Should I go with alligator I-link or Gatorbrake G4 sleek. Anything else? Or am I confusing the brand names I can't remember what they are? And how much money is an installation kit? I see anywhere from $27 to 65 dollars on eBay.
    I tried to do a search but this just way too much info coming up about all sorts of other things that must of used those terms lightest brake cable housing.
    Tia
    ups and downs
    V-brakes I assume? Prime MTB System, Ultralight
    Reputation: roaringboy's Avatar
    Re: help finding lightweight brake cable
    I use i-link (gears not v-brake). Very impressed with the system as a whole.
    Sent from my XT890 using Tapatalk 2
    thanks for the link rockyuphill, I may purchase that.
    roaringboy, I wonder if you are referring to the I-link "shift" cable (for gears) aka mini I-link cable and using that for the v-brake?
    So then, the alligator I link cable which cost more than the Gator brake G4 cable implies that the alligator I link is higher quality? Kind of like you get what you pay for?
    yes essentially this is for a V-brake system.
    Since you're in the WW forum:
    Mountain Brake Cordz System Classic
    I personally found them difficult to work with (pinched at the clamp) and not worth the few grams, but maybe they're better now...?
    Edit: looks like they have a new collar to protect the cable from the clamp. I haven't tried it so no idea if it works...
    Power Cordz Grommet Clasps: New, Powerful Protection
    whatever...
    Quote Originally Posted by mtrbiker View Post
    No I mean I have i-links but for my gears - or gear to be precise as I only have rear. What I was getting at was that i-links are good quality and light.
  1. I need some help with finding a replacement rear brake.
    By YUNOrideBike in forum Downhill - Freeride
    Last Post: 07-22-2012, 06:37 PM
  2. Need a lightweight brake recommendation
    By JeffL in forum Singlespeed
    Last Post: 03-21-2012, 11:52 AM
  3. Replies: 1
    Last Post: 10-22-2011, 05:22 AM
  4. Which Fork w/ V-brake, lightweight?
    By Gingerkid in forum Beginner's Corner
    Last Post: 06-10-2011, 10:42 AM
  5. Lightweight XC fork (100mm) with V Brake?
    By hardwarz in forum Beginner's Corner
    Last Post: 05-07-2011, 08:07 PM
