Results 1 to 6 of 6
    Grease or no grease
    Its been a while since I've wrenched on bikes and I just picked up some Al crank fixing bolts which I'll be threading into a Ti bottom bracket. I also got some Al brake posts with which I'll be securing the brake arms with Ti bolts. Should I use grease or Ti prep in either of these applications?
    Thanks.Grease or no grease-0714131448-00.jpgGrease or no grease-0714131449-00.jpgGrease or no grease-0714131518-00.jpg
    ups and downs
    Ti prep anti=seize for sure - which could be an issue for a situation where a thread locking compound might normally be used. And it may affect the torque reading on the crank bolts, as it has a lube base, so be careful with tightening the crank bolts.
    Grease or no grease
    Quote Originally Posted by rockyuphill View Post
    I thought loctite was antiseize too? Couldn't you just use some blue loctite and solve all your problems?
    From the loctite website: "It protects threads from rust and corrosion and prevents loosening from shock and vibration."
    I like turtles
    Reputation: TiGeo's Avatar
    Ti-prep for Ti.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Thanks for the responses! I used Blue Locktite #243 on the Al brake stud threads into the frame and fork as per Extralite instructions and Copper anti seize on the Ti connections. The Locktite I found in a Auto parts store and I can't remember where I got the Copper anti seize, most likely the same place.
    I saved 38 grams over the original steel bits at a cost of $1.96 per g.
    Thanks to Fairwheel Bikes for including these hard to find parts in there Extralite order.
    ups and downs
    No guarantee that Loctite will prevent galvanic corrosion from dissimilar metals, with fasteners of the same metal and conventional water generated corrosion it can help with. Ti anti-seize has the conductive copper paste in it to "short circuit" the interface between dissimilar metals.
  1. What Type of Grease for Grease Ports?
    By B-Line in forum Santa Cruz
    Last Post: 10-28-2012, 05:06 PM
  2. Grease gun and grease recommendation
    By wonny in forum Intense
    Last Post: 10-17-2012, 11:35 PM
  3. To grease or not to grease......
    By OutThere in forum Bike and Frame discussion
    Last Post: 04-25-2012, 01:39 AM
  4. Grease Gun?
    By linadog in forum Banshee Bikes
    Last Post: 08-14-2011, 09:51 PM
  5. Which Grease?
    By TheDoc46 in forum Beginner's Corner
    Last Post: 05-17-2011, 02:56 PM
