Results 1 to 7 of 7
    Ty
    Ty is offline
    Reputation: Ty's Avatar
    Got a new mini tool today...
    Got a topeak mini 6 tool today,
    Changed the 3mm allen key to a 2.5mm allen key (from an old multi tool) so this tiny tool covers:
    Chain ring bolts
    Brakes
    Stem bolts
    Saddle adjustment (2.5mm for USE alein)
    Peddles
    seat clamp
    Size L x W x H 4.8 x 2.8 x 1.8 cm
    And it weighs 57g!!
    espresso lover
    Reputation: Frankie - B's Avatar
    looks good Ty!
    No cool signature...
    Glad to Be Alive
    Quote Originally Posted by •Ty•
    And it weighs 57g!!
    that is cool
    Reputation: VT Mike's Avatar
    cool
    I went with the Park IB-2. Not so light, but it has a few more tools on it:
    8mm (adapter on the 6mm)
    6mm
    5mm
    4mm
    3mm
    2.5mm
    2mm
    1.5mm
    torx (for rotor bolts)
    flat head screwdriver
    size is 75mm x 38mm x 20mm
    Reputation: JCGrech's Avatar
    Also check out the Specialized EMT Race tool--at 130 grams, the lightest tool I've found with a chain tool.
    Trail rider and racer
    Reputation: Trevor!'s Avatar
    The tool looks so small that I'd be guessing you'd be hard pressed to be able to get much leverage from it when loosening a tight bolt or tightening one.
    Trev!
    Reputation: Mtbric's Avatar
    Yes, the Specialized EMT race tool looks nice...
    http://www.specialized.com/SBCEqProd...egl402m.j27004
    Very light and has the very important chain breaker. I've needed the breaker at least once. I personaly use the 80gm Ritchey CPR 14. The breaker on that works better than the one on my Crank Bros. tool. If I had to get another tool I'd get the EMT. It has ti bolts and mag side plates
  1. King hub service tool? Where to buy?
    By 1speed_Mike in forum General Discussion
    Last Post: 09-23-2004, 11:28 AM
  2. Need Spline Drive nipple tool
    By Circlip in forum Wheels and Tires
    Last Post: 07-06-2004, 07:17 AM
  3. Raceface Deus, what tool did you use to install it with?
    By Ratt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-13-2004, 01:19 AM
  4. Headtube facing tool....on a budget??
    By Lab Worker in forum Tooltime
    Last Post: 03-31-2004, 12:45 PM
  5. Spring ride pics from today at Blankets Creek
    By Duckman in forum Passion
    Last Post: 03-14-2004, 10:05 AM
