Gear cables
Printable View
  • 01-12-2013
    roaringboy
    Gear cables
    I need to replace my gear cables. I have alligator i-links and the sleeve and outers are fine, just need new inners. I've had a look and can't see that you can buy just the i-link inner cable, only the whole set.
    A couple of questions:
    Does anyone know if you can buy just the inner cables anywhere?
    What is a decent alternative - I.e. what do you lot use?
  • 01-12-2013
    doccoraje
    Powercordz, about 1/5 of the weight of regular steel cable.
    Derailleur Cordz Set 1.2mm
    search on ebay for best prices.
  • 01-12-2013
    roaringboy
    Cheers. Assume they shift well? I really liked the alligators.
  • 01-12-2013
    doccoraje
    You can use them with the Alligators or any housing.
    I'm using them with Gore UL, and yes, they shift well.
  • 01-12-2013
    xc71
    Running I-Links with 1.2mm Powercordz and they shift great.
  • 01-13-2013
    roaringboy
    Thanks chaps. Powercordz it is.
