Results 1 to 17 of 17
    Maromero
    Reputation: doccoraje's Avatar
    Garbaruk cassette
    Changing my XTR 10 sp cassette for a Garbaruk, almost the same weight for the shimano 11-36 as the 11-42 (lockring missing), also finally got the Schwalbe aerothan tube.
    Attached Thumbnails Attached Thumbnails Garbaruk cassette-cassete-xtr-980.jpg
    Mar 2015
    Hi. Have you used the tube or is it just for emergencies?
    Maromero
    Quote Originally Posted by fxrextreme View Post
    Just for emergencies!!! Carrying just half the weight of the regular "light" tube on my jersey or backpack
    Nov 2007
    Where did you get the tube? I was keen on it a while back, then it disappeared from the market.
    Maromero
    Quote Originally Posted by PlanB View Post
    Ebay a while ago, from seller arif583, seems like he ran out of most sizes as I can only see 26er
    Mar 2015
    Has anyone actually used these tubes? I'm interested in how puncture resistant they are.
    Kes
    Reputation: RS VR6's Avatar
    How does the Garbaruk shift? I think you're the first person I've seen get a 10sp.
    Maromero
    Quote Originally Posted by RS VR6 View Post
    Still don't know, I was going to change cassette, chain and chainring when noticed all the bushings of my Flux were toasted, don't have the replacement here, so I'm hoping they will be here soon thanks to Bobby at Turner
    Reputation: Davide's Avatar
    I have an eleven speed 1048 with Shimano XTR. Shifts as well as the SRAM 1042 I had mounted before. Weight is 310.
    Reputation: octanejake's Avatar
    Oct 2010
    Did you also get the derailleur cage to go with it?
    Interested to know how this setup works.
    Quote Originally Posted by octanejake View Post
    I did just to be on the safe side, but the XTR medium cage works perfect and I did not install it.
    Illuminati
    Reputation: scant's Avatar
    I'm using 11 speed shimano with stock medium cage on sunrace 11-50 cassette & it shifts fine. chain length is as critical as b-tension, but it wasnt difficult to set up. I'd love the 1/2lb saving on a gabaruk cassette, just have trouble spending that much on a consumable part
    Oct 2010
    Thanks for the replies. I should have specified I'm using a 10-speed XT which wasn't originally designed for the extended range cassettes, which is the reason for inquiring.
    Maromero
    I'm using an XTR RD medium cage, the cassette included a derraileur cage, which was the same lenght as the one I have, so, I kept the original.
    Oct 2010
    Quote Originally Posted by doccoraje View Post
    Thank you.
    Mar 2015
    AFAIK the replacement cage is for changing the position of the top jockey wheel,not the length of it
    Maromero
    Well, after a while I'm able to give first impressions of the performance, no problem with backward pedaling in any cog (I used a longer B tension bolt) most shifts are smooth, but...going from 20 to 17 is difficult, must go down to 15 and then back to 17, I'll try to fine tune it. Used the same medium xtr cage, same top jockey position.
  1. Garbaruk 11 speed cassettes
    By J_Westy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 1 Day Ago, 04:26 PM
  2. Garbaruk Oval vs Race Face: Chain Line
    By Davide in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-17-2016, 11:13 PM
  3. Garbaruk Cassette Xtender
    By dledinger in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-14-2016, 04:09 PM
  4. Garbaruk SRAM derailleur cage
    By RS VR6 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-12-2015, 06:49 PM
  5. Why use a 10 speed cassette over a 9 speed cassette?
    By Gary H in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-06-2011, 07:22 PM
Members who have read this thread: 133
