    foam grips for big hands
    i have pretty big hands, and need grips with a large diameter. i really like ritchey wcs true grips which are foam, but not really all that light. any other suggestions?
    Reputation: Roadsters's Avatar
    It's going to come down to a trade-off between diameter and weight.
    In addition to foam grips, Grab On sells several sizes of foam tubing.
    Reputation: sfer1's Avatar
    ESI "Extra Chunky" (80 grams)
    Standard Grip Length - 5 1/8"
    Installed Dia. 34mm
    Weight plus or minus 5%
    1 set of Bar Plugs included
    MTB Grips
    The ESI chunky or extra chunky are both heavier than the WCS foam if weight is your concern..I wear XL/XXL gloves, and prefer the ESI chunky over the WCS Foam. I have both on bikes right now, but I'm going to remove the WCS, because I don't care for how the compress vs the ESI which feel more firm.
    Hard to track down in the US, but see if you can find some Extralite foam grips.
