Results 1 to 5 of 5
    Reputation: Strong Ti's Avatar
    Jun 2005
    Extralite Freehead 2
    Arrived a couple of days ago, thanks Dirtboy! It comes in at 74gms on my scales. I'm not sure why the top bearing shell is not black though, but I'm not particularly worried.
    The Freehead will replace my Chris King set it will save a bit of weight but will also lower my bar height by about 10mm. It'll be the first time in over 10 years I've not run a King headset, hopefully the Freehead proves to be atleast 1/2 as durable as a King!
    SUBLIM8er
    Reputation: Axis II's Avatar
    It's a solid HS for the weight. A bit hard to get the adjustment just right but mine is still going strong after a season+ of rigid fork duty.
    Every man has inside himself a parasitic being who is acting not at all to his advantage.
    William S. Burroughs
    Maromero
    Reputation: doccoraje's Avatar
    Lucky guy, you received a light one,
    Mine replaced a CK as well, one year and still running as new.
    Jun 2005
    Thanks guys
    good to know the headset holds up.
    Interesting you both went for the Freehead rather than The Head. My rational was a bit more durability and I also run my bike with a rigid fork around 1/2 the time.
    Weight Weenie Shop Owner
    Reputation: DIRT BOY's Avatar
    Aug 2002
    Quote Originally Posted by Strong Ti
    The Regular The head 2 upper bearings are very tinly. Even Sergio @ Extralite says to use those more for road bikes.
    The FH won't last as long as a KING HS, but it's much ligheter an not desgined to. You SHOULD get 2-3 yrs of normal XC riding/racing on them.
    I am glad you like it!
    DIRT BOY
    Light-Bikes.com
    The Largest Site Dedicated to Light Weight Bikes and Sales
    Twitter: @lightbikes_com
  1. extralite chainrings
    By Jesseg in forum Weight Weenies
    Last Post: 03-22-2006, 08:15 PM
  2. Extralite Aliens 2
    By DIRT BOY in forum Weight Weenies
    Last Post: 08-02-2005, 09:04 AM
  3. ExtraLite Stuff
    By MTB-] in forum Weight Weenies
    Last Post: 03-18-2005, 03:54 PM
  4. very light extralite UL2
    By $eboss the frenchy in forum Weight Weenies
    Last Post: 03-09-2005, 11:50 PM
  5. Extralite cranks - what's available right now
    By Motivated in forum Weight Weenies
    Last Post: 01-18-2005, 02:25 PM
