Any success stories, or nightmares for that matter, with folks using this combo? I find comments that the GR2's work well on Easton Carbon bars, but nothing on Raceface.
Are the Race Faces bar end compatible? Is there a max torque for lock on grips from Race Face. I'm running GX2's on Fsa carbon bars that were "bar end compatible" but the handlebar torque spec is less than the Ergon torque spec. i used carbon paste and haven't had the grip slip yet.
Race Face documentation says their carbon risers are not compatible with bar ends, at least their use will void the warranty. No published specs from them as to max torque for lock on grips that I can find.
You will be fine as long as you follow the torque specs of both the bar and grips. Although not 100% needed, add the LS100 bar plug to reinforce the bar if you like.....or if you lack a torque wrench.
