Results 1 to 9 of 9
    Ergon GP1 Leichtbau Grips slipping on carbon handlebar
    anyone had this problem. one of my grips continues to slip over the course of a ride. should I try using some of the carbon paste?
    i didn't know where to post this so I figured this would be the best place since these are WW parts.
    Giddy Up!
    Reputation: caak's Avatar
    Oct 2007
    put a some hair spray on the bar before you install the grip as well..
    are you using a good torque wrench to tighten to the correct amount?
    CAAK
    --------- __o
    ------- _`\<,_
    Use golf grip tape.
    You won't even need the screws anymore.
    Reputation: amillmtb's Avatar
    Jun 2005
    I would put a little carbon assembly compound on the bar and then use a torque wrench to make sure you have proper torque spec. Did you trim your bars down at all?
    Ergon Bike
    Reputation: ERGON's Avatar
    Nov 2006
    Quote Originally Posted by Jrkimbrough
    This is an issue with a select few carbon bars. Please read this blog post we did a few months back.
    http://ergonbike.wordpress.com/2009/...rips-slipping/
    If you still have issues or question, please PM me.
    Jeff K
    Ergon USA
    Yea, my Ergons slip like crazy on my Syntace bars (GX2 LB grips). I put some assembly paste on there and it helped a bit. Mine still slip from time to time, despite having them torqued a bit higher than Ergon specs, in an attempt to prevent the slipping.
    Ergon Bike
    Nov 2006
    Quote Originally Posted by briscoelab
    Pay close attention that the gold ring is installed properly. This is super important. GX2 slipping issues have not been reported...and those that have usually result from a gold ring that is not installed 100% correctly. Double check to make sure.
    Jeff K
    Ergon USA
    Sanded the end of the bars, still slipping. Guess I'm gonna have to try hairspray or the paste.
    Carbon assembly paste for sure.
    It should be on all points of carbon contact, including your stem.
    www.mtbiker.ca
    My Rides:
    FSR XC -R7 Platinum - SRAM X7 (26.5lbs)
    Cervelo SLC - SRAM Rival - Reynolds DV46T (16.25 lbs)
