A friend has trouble with the eclipse stem leaking at the rim. He is using the Eclipse kit.
The appearance is the rubber washer should go on the inside of the rim, not the outside. According to him the outside placement is what the kit says to do.
What is the most effective way to install the Eclipse rubber washer?
