Results 1 to 9 of 9
    Reputation: MrEconomics's Avatar
    Dropping Granny and Outter Ring, What Ring To Get?
    I want to TRY going to a 38t on the front but don't even know where to start. I want something cheap so if I don't like it, I'm not out a significant amount of coin. I run Shimano XT. Could someone point in me the right direction. Thanks.
    I'm using a Race Face 38T ring on one of my bikes. I don't recall how much it was, or even where I got it, but any LBS should be able to get it from QBP. It doesn't have ramps, so that's a plus. Surly makes some nice stainless rings, but I think they only go up to 36T.
    ups and downs
    Vuelta makes a cheap flat ring with no ramps or pins.
    Reputation: jeffh's Avatar
    You might look at the Salsa chainrings they have 32,34,36,42,46,44 (but no 38).
    The 36t Salsa 4 on 104 Chainring weight is 50g
    They do not have ramps and pins for shifting, and that should help keep the chain on for your 1 X 9 set up. Also look at a front chain guide to help keep the chain on, I have had great luck with the Rohloff Chain guide
    The XT cranks should have a 4 on 104mm bolt circle. You will need some shorter chainring bolts for the single chainring also.
    Salsa Chainrings
    http://www.speedgoat.com/product.asp...t=50&brand=216
    Rohloff Chain Guide
    http://www.speedgoat.com/product.asp...=310&brand=212
    I put my 38 in place of the middle ring (behind the spider) on some old LX cranks and did not need shorter bolts.
    ^Genius. Thanks. Finding an inexpensive 38t is proving difficult, especailly in 64/104. Wonder if I should goto a 36t instead.
    Reputation: Polk's Avatar
    Shimano makes a 38t Saint ring. They are listed in the BTI catalog; they are probably in other catalogs, too, but I have seen it in BTI. It might not be inexpensive, but it is one possibility.
    lurkio
    We went, earth, sky, earth sky, earth skyambulance
    Mine is a Race Face DH ring - about $40 through your LBS or online.
