Results 1 to 7 of 7
    viva la v-brakes!
    Reputation: FishMan473's Avatar
    Jan 2003
    do Ti bolts effect stem stiffness?
    Will swapping to Ti bolts on a stem (or other parts) decrease the stiffness of the stem, since Titanium flexes more than steel?
    I have a car. I made a choice. I ride my bike.
    Reputation: phlegm's Avatar
    The flex in the stem itself would not be affected by bolt choice. However, the shear limit would indeed be affected by the bolt choice.
    I run a Ritchey stem with Ti bolts without issue for XC use.
    viva la v-brakes!
    Jan 2003
    Regarding shear limit, isn't it the aluminum threads in the stem itself which is most likely to strip?
    I have recently upgrade to wider/stiffer bars and have noticed a significant improvement in handling. I thought I would see if a stiffer stem (than my Ritchey WCS 4-Axis) would continue improving things. To save weight I'd like to keep using my Ti bolts as long as it won't reduce the improvements i am seeking.
    ups and downs
    As many stem manufacturers point out, not all Ti bolts are rated the same and not all are designed for the torque for a stem face plate. Some stem manufacturers provide expensive Ti bolts on some stems like FSA and Ritchey, but other companies like Race Face warn against replacing the high strength steel (that tend to get a film of surface rust) with Ti bolts, as the cheaper Ti bolts are more inclined to shear where the threads are cut instead of rolled.
    Reputation: Gripshift's Avatar
    Do you really think you would even notice?
    What am I going to do with forty subscriptions to Vibe?
    viva la v-brakes!
    Jan 2003
    That's kind of what I'm asking.
    Rock and/or Roll
    Reputation: turbogrover's Avatar
    Dec 2005
    Quote Originally Posted by Gripshift View Post
    The answer is no. At least in my own experience. The strength of four screws is so much greater than the force exerted on them. You could probably crack the stem faceplate by overtorquing them, before they would fail.
  1. Does stem length effect the seat position?
    By CT3 in forum Beginner's Corner
    Last Post: 05-03-2012, 12:17 PM
  2. Thoracic spine stiffness and stem rise
    By BeaverTail in forum Beginner's Corner
    Last Post: 02-20-2012, 10:27 PM
  3. Stem bolts sizes
    By bank5 in forum Tooltime
    Last Post: 12-31-2011, 12:43 PM
  4. replacement stem bolts
    By TheBigV in forum General Discussion
    Last Post: 09-01-2011, 07:47 AM
  5. How much do spokes effect wheel stiffness?
    By manamana in forum Wheels and Tires
    Last Post: 07-09-2011, 07:59 PM
