Results 1 to 22 of 22
    Ty
    Ty is offline
    Reputation: Ty's Avatar
    Crown Race . . . . Am I going to die a horrible death ! : )
    I was making a lightweight crown race converter, basically a crown race for running a standard 1-1/8" fork in a tapered headset (1-1/8" to 1-1/2")
    I was about to hit the print button for an aluminium print (I'm using Shapeways for 3D printing) . . . but then I had a thought, a crown race for an integrated headset serves little other purpose these days other than to seat the lower bearing - long gone are the days when a crown race was an actual race surface for the lower (non-cartridge) bearings to run on. It's a kind of vestigial remnant in these days of integrated headsets.
    So I was thinking - in the pursuit of pathological weight weenie gram saving - does it really need to be made from aluminium or could it be made from a tough plastic like nylon ?
    If I print it in nylon it would easily beat extralite and Tune with regards to weight - of course the savings are minimal with something as small as a race, but hey, this is the weight weenie forum, a place where people shave their eyebrows for a more efficient face
    Anyhow, if anyone has any input I'd be happy to hear it, otherwise I'm going to take my life in my hands and hit the print button on nylon !!
    Crown Race . . . . Am I going to die a horrible death ! : )-1.jpgCrown Race . . . . Am I going to die a horrible death ! : )-2.jpgCrown Race . . . . Am I going to die a horrible death ! : )-3.jpgCrown Race . . . . Am I going to die a horrible death ! : )-4.jpgCrown Race . . . . Am I going to die a horrible death ! : )-5.jpg
    P.S - if this works out - and I don't die - then I'll leave the 3D file up on Shapeways and anyone is free to print one out for themselves - at your own risk !!
    No opinion on your particular design, but Cane Creek 10 series crown race is polymer.
    Reputation: Mr Pig's Avatar
    Yeah, you can already buy plastic ones. I have the Cane Creek one. Like you say, there is no need for it to be metal. You can also put a split in it so that fitting and removal is easy.
    Reputation: phlegm's Avatar
    Quote Originally Posted by Mr Pig View Post
    The split (on metal CR) is very handy for removal/reinstall, so that's a great idea. Unsure if that adversely affects a nylon one. (?) At least nylon could be cut off easily enough for removal I suppose.
    [Shaving eyebrows as we speak.]
    If you are printing in metal, why not make it hollow with a hexagonal pattern inside as reinforcement? Should be plenty strong and very lightweight.
    2015 Kona Process 111
    2016 Transition TransAM 275
    Ty
    Ty is offline
    Quote Originally Posted by cjsb View Post
    Cheers for the info cjsb !
    Ty
    Ty is offline
    I was going to put a split in the ring, but I've never really had an issue hammering races onto a fork, I just use a tube of some kind and give it a few good solid hits and it's on . . . I also thought that being made from nylon it wouldn't hurt to have the little extra mechanical integrity of being a solid ring.
    Ty
    Ty is offline
    Quote Originally Posted by phlegm View Post
    Yeah, that was my thinking too, a solid ring would lend nylon a little more mechanical integrity and it would be easy enough to cut off if it needed taking off (they aren't expensive to print, so I might order a few to throw into my spares box).
    On the subject of facial hair, I'm working on some quick release eyebrows, so you can simply unclip them before getting on your bike.
    Formerly of Kent
    Reputation: Le Duke's Avatar
    I'd ride a HDPE or similar crown race. No problem.
    Hell, my car has suspension spacers made out of the same stuff. It's an amazing material.
    Let us know how it turns out.
    Sent from my XT1585 using Tapatalk
    Death from Below.
    Ty
    Ty is offline
    Quote Originally Posted by Gilgo View Post
    With certain materials (at least over at Shapeways) there are wall thickness limits, not sure I'd be able to get a good working hex pattern into such a small space, nice idea though !!
    I was also thinking that with a crown race the only surface that actually contacts the lower bearing is the 45 (or occasionally 36) angled surface coloured red in this image . . .
    . . . that is where the bearing sits, it never touches the green or blue surfaces, which makes me think you could lose them . . . hold on back with a new design in a minute or two . . . .
    Ty
    Ty is offline
    Quote Originally Posted by Le Duke View Post
    If I don't make it I'd like to be buried under the tree I hit.
    Formerly of Kent
    Quote Originally Posted by Ty View Post
    I'd actually trust plastic more than aluminum for this application.
    Death from Below.
    Ty
    Ty is offline
    I trimmed off the green area (from the above image in my previous post) - the only downside I can see is that the green area acts as a sort of barrier - keeping dirt and grim off the lower part of the bearing . . . . ?
    I also tapered the top area (blue in the above image in my previous post) down to where it meets the steerer tube (the yellow band).
    Crown Race . . . . Am I going to die a horrible death ! : )-screen-shot-2017-12-16-22.06.37.pngCrown Race . . . . Am I going to die a horrible death ! : )-screen-shot-2017-12-16-22.06.29.jpgCrown Race . . . . Am I going to die a horrible death ! : )-screen-shot-2017-12-16-22.06.06.pngCrown Race . . . . Am I going to die a horrible death ! : )-screen-shot-2017-12-16-22.05.45.pngCrown Race . . . . Am I going to die a horrible death ! : )-screen-shot-2017-12-16-22.05.29.pngCrown Race . . . . Am I going to die a horrible death ! : )-screen-shot-2017-12-16-22.05.07.png
    But you're going to put holes in it?
    The ring is in compression and is prevented from expanding outward by the inner lip that protrudes up into the recess on the bearing. A split in the ring will make no difference to the performance at all.
    Drilling away so much of the material on the other hand, might. And for what gain? A weight saving of literally a few grams?
    Plastic ones already do the job perfectly at little cost. This part does not need to be reinvented.
    Ty
    Ty is offline
    Correct ! Welcome to weight weenies !
    Cycologist
    Reputation: chazpat's Avatar
    Yes and the 10 series is their "economy" model. It came on my bike. The plastic crown race busted up and the whole thing imploded into the headtube. Ended up having to push my bike out and call my wife to come pick me up (I had ridden to the trail from my house). Replaced it with a 40 series with a steel race. I'll take the extra weight.
    There are two types of people in this world:
    1) Those who can extrapolate from incomplete data
    Ty
    Ty is offline
    I was thinking I might get the race printed in nylon, aluminium and steel (weirdly steel is much cheaper to print than aluminium?), I expect even when printed in steel it will be as light or even lighter than a standard aluminium (conversion) race . . . . this is really just a weight weenie experiment so it might be useful to see how all three materials turn out.
    Cycologist
    Well, obviously I didn't die a horrible death! Took me awhile to figure out why the bike was feeling so strange. As in I finally stopped to check it out. I don't like stopping.
    There has to be thousands of 10-series headsets out there in the wild at this point. I'm not aware of a recall, and that series isn't new (unless the polymer portion is a recent change). Do you have any other details about the failure? Was it over-torqued somehow? Are you literally saying it was in pieces? I'm wondering if low temperatures were a factor.
    I'm not defending, nor criticizing anything here, but you'd think fear of litigation alone would ensure that the polymer used in this case was deemed "safe". (?)
    [Sorry for overuse of question marks in this post.]
    Cycologist
    I don't think it was over-torqued, it hadn't been touched and the bike is a 2014 model and it happened this summer so it wasn't cold either. I don't recall if it was in several pieces or if it split and collapsed in, I just recall it being down inside the head tube. I think it probably split and then as I rode, it worked itself inward until it fell in as the bike was feeling a little odd and that increased to wtf is going on. Yes, I should have stopped and did a complete inspection but I was trying to figure it out from how the bike was handling at first.
    I did a little googling and found a few reviews where people had problems with the plastic but in their cases, it did sound like poor installation.
    Since the 40 is basically the same as the 10 but more expensive with the steel race, I'd say the plastic of the 10 is about saving cost, not weight. But you're right, haven't seen a recall and I don't see a lot of reports of failure. I'm not a real hard rider so I wouldn't think that I bashed the fork hard to possibly cause damage.
    with plastic 10 series it was/is easy to install it upside down. i think it is easy to install wrong because all you do is place it there by hand and you are good to go and the sides have a similar look.
    Reputation: consa's Avatar
    Dec 2017
ID:	1172671Click image for larger version.
ID:	1172672Click image for larger version.
ID:	1172673Click image for larger version.
ID:	1172674Click image for larger version.
    6 polygonal hollow design will be lighter, more uniform force
  1. Tight crown race - Possible damage to crown/steerer press-fit?
    By Pableras in forum Shocks and Suspension
    Last Post: 06-12-2014, 02:15 PM
  2. space in between bottom of crown race & top of fork crown
    By TheeSuperUberV in forum Beginner's Corner
    Last Post: 09-15-2013, 06:35 PM
  3. Stupid Sunday Rant Inaugural ed.: Die butthurt die
    By Slow Danger in forum Off Camber (off topic)
    Last Post: 01-07-2013, 04:52 PM
  4. Pros/Cons of single crown and dual crown
    By cicatrix in forum Downhill - Freeride
    Last Post: 03-30-2011, 04:09 PM
  5. Replies: 6
    Last Post: 08-10-2010, 06:43 AM
Members who have read this thread: 107
