Found these stems on ebay going for $30. Claims to have ti bolts and weigh less than 100g. Has anyone tried them and do you thing they would be good for a 140lb rider with a carbon steerer on a rigid singlespped? Also do you think the logo could be removed?
Another option for cheap ultralite stems are the Uno stems. Bi King Uno ?6? Lightweight MTB Road 31 8x70mm Stem 91g Black LT58H | eBay
You can purchase 6 Ti bolts for approx. $15.00 to give you Extralite stem like weights.
I have a couple of friends as well as my son and daughter running these with no issues.
Thanks for the info XC71. I got my Uno stem in today. The same seller has a white model which I chose. 85 g with my ti bolts. I am impressed with the construction -- larger diameter and thinner wall than my other stems, very rugged. Great quality casting.
I got the 70mm 7-degree like XC71. It replaced an 80mm 17-deg. I put another 10mm spacer under it and it feels very close to what I had, maybe a little higher.
Sorry, I didn't weigh it before replacing the screws, but my screw records say I saved about 10 or 11 grams. My scale only reads to 1 gram, and the actual weight with ti screws was actually trending towards 84 grams as it flashed back and forth. So 95 grams would be very close to the actual weight.
If you are looking for something of a more typical length, he has this 90mm that should still sneak by under 100g with ti bolts.
Thanks for the info. I'm using this in a 90/-7 and weight has been around 110g for mine: Forté Pro Oversize Stem -
Often on sale for $24 and we have local PB store which allows me to take the tiny gram scale and make sure I don't get a pig heavy one, ha. Being a Weight Weenie means I should go for anything that saves 10 grams, but the PB stem is often free from Team Performance points.
Thanks! So 94g for a 70mm. Guesstimating a 90mm would be around 105. The WW within would swap my Forte Oversized 90mm/110g for a 95g 90mm Uno, but at the guesstimated weight it's not worth it for me.
They are claimed 101g (probably 110g real) and look way better than these UNO stems (I find the UNO soooo ugly IMO). Plus the graphics aren't as bad and they seem to have a way nicer body.
I'm 120 with gear, and this is going on a XC bike.
I hope I'm in the right place here. I'm a newb. Just wanted to let you know that I recently purchased a Chinese mtb stem (I was going to post the brand and price but realized that might get me banned as a spammer, oops)! Anyway they come in a variety of colors and the thing is freakn gorgeous! I got the blue anodized. The milling and tolerances are fantastic. And it was on of the few I could find in a 35mm bar bore (w/ the included shims can be used w/ 32.5mm or wtevr that is). Anyway about a fifth the price of a Hope or one of the name brands. Haven't thrown any hard riding at it yet. I'll let you know how/if it holds up. Sure turns heads tho. Wish I knew how to post photo?
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
