Results 1 to 45 of 45
    Jun 2013
    Carbonfan.com Skyweight 30/24 mm carbon wheelset
    Given the internal dimension, assume this qualifies as weight weenie. New T800 mix. 1290 grams on my uncalibrated scale. 30mm outer/24mm inner (verified with my digital caliper), DT240s XD driver, 54 poe, 28 spoke 3x Pillar bladed spokes straightpull. I don't have a tensionometer but feel very equal and threw them on my truing stand and they are trued very well. Have a 2.25/2.35 Racing Ralph set that mounted up quick and easy. Finish on the rims is fantastic. Only one ride in, but they're nicely stiff and snappy. Coming from a lightweight aluminum rimset that lost significant tension just inflating the tires and needing constant truing on the rear I'm looking forward to all the benefits of carbon.
    Carbonfan.com Skyweight 30/24 mm carbon wheelset-carbonfanfullbike.jpgCarbonfan.com Skyweight 30/24 mm carbon wheelset-carbonfantotalwheel.jpgCarbonfan.com Skyweight 30/24 mm carbon wheelset-carbonfanfront.jpgCarbonfan.com Skyweight 30/24 mm carbon wheelset-carbonfanrear.jpg
    Reputation: phlegm's Avatar
    Nice!!!!
    Reputation: wightweenie26er's Avatar
    Sep 2017
    what rigid fork is that please?
    Jun 2013
    It's a Specialized Chisel fork. Specialized has them in their closeout section on their website for $185. Cool feature is it comes with a bonded on aluminum crown race which saves weight. Bad feature is it's only good for QR or the 9mm DT RWS Thru I use. No 15mm option.
    Reputation: sfer1's Avatar
    I find these way more interesting than the LB Flyweight rims.
    * $74 cheaper
    * Asymmetric
    * 24mm inner width
    * Anti-burp bump
    29" 30/24mm 28H UD matte
    Carbonfan.com Skyweight 30/24 mm carbon wheelset-llanta-carbono-1.jpg
    Carbonfan.com Skyweight 30/24 mm carbon wheelset-llanta-carbono-2.jpg
    Merendon Junkie
    Reputation: abelfonseca's Avatar
    Dec 2011
    Can someone post a link to these?
    Abel
    Jun 2013
    Quote Originally Posted by abelfonseca View Post
    Abel
    https://www.carbonfan.com/ Skyweight models. I've been riding mine for a couple months now and they are stellar. Weights on my scale are exactly as promised. I had the full wheelset made up with DT240 and Pilar spokes and build is top notch as well. Highly recommended.
    Quote Originally Posted by rumblytumbly View Post
    How long did it take to get your wheelset in?
    Sent from my SM-G920V using Tapatalk
    Jun 2013
    Took about a week for the build, with great communication. I probably added a day or 2 to that since I had lack of familiarity with the DT series hubs and build options so had some questions. Questions always answered within 12 hours though. Once they're shipped it's typical EMS to local carrier so that's 8-9 days to your door. I didn't pay for any expedited shipping.
    Interesting! I had a quick look at the wheelset options, what do they mean as spoke drilling:
    External nipple 4.5mm & UST No expternal Hole - did you actually order this way so tubeless tape no longer required?
    thanks
    flyMTBfish
    Jun 2013
    Quote Originally Posted by Ausable View Post
    thanks
    That was one of the questions I had. You can order them with no internal holes, no tape required. Not recommended. Too many downsides from what I researched on other brands that offered/offer this. Requires special nipples, building/truing a hassle, nipples get loose inside and people spend hours shaking them out, technically heavier than a strip of tape. Looks like this was seen as one of the advantages of carbon rims in the early days (no tape), but industry quickly moved on to normal eyelets due to overall hassle factor. That's what the internet tells me anyway. Unless you'll use the glue on tubular sew up tires which is a different rim structure altogether and mostly for roadies.
    Thanks for the input rumblytumbly, I fully agree.
    flyMTBfish
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Is anyone out there making a symmetrical "skyweight" or similar 26mm ID rim?
    The Carbonfan 26mm ID rim looks great but I'd like to be able to re-use the spokes I already have from a previous build. The ERD is within a millimeter but the offset just won't work for me, unfortunately.
    Death from Below.
    Jun 2013
    Quote Originally Posted by Le Duke View Post
    It looks like on this page https://www.carbonfan.com/t800-tubel...28mm-33mm-35mm I'm able to choose a 30mm/25mm symmetrical T800 skyweight version. Maybe send an email to info@carbonfan.com and ask specifics for availability. The only Lightbicycle one I see is the narrower 22mm.
    Formerly of Kent
    I saw those. But, looking at the cross section diagrams for each, I'm a bit concerned.
    The 25mm ID one has a depth of 25mm, and an ERD of 583mm.
    The 26mm ID rim has a depth of 30mm, and an ERD of...583mm.
    One of those measurements (or both) is incorrect.
    Death from Below.
    Nov 2017
    How much weight margin is reasonable with these rims? In full kit I weigh about 85 kg, ride mostly XC/trail and never seem to bend my Al rims. I see the ultralight rims from Carbonfan and others have 100 kg. weight limits. Is that cutting it too close at my weight?
    In for ride reports, Those look great and very well priced too!
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    Quote Originally Posted by wayold View Post
    From my interaction with Arthur it seems that the T800 flyweight are not engineered for AM use. Only for XC. Whatever that means.
    I have some on the way.... I'll be posting a review.
    Formerly of Kent
    Quote Originally Posted by sfer1 View Post
Name:	Llanta Carbono 1.jpg
Name:	Llanta Carbono 2.jpg
    What was the actual, measured ERD on those?
    Sent from my XT1585 using Tapatalk
    Death from Below.
    Edited. The actual ERD is 591mm, not 595mm I originally stated.
    Nov 2013
    Ordered some carbonfan 650b 275gm rims yesterday for a gravel wheelset.
    Just have to purchase the spokes now.
    Predicting around an 1180gm build.
    Jan 2002
    Still on the fence about getting a skyweight 29er set, either the 25.5mm internal or 29mm internal, 32h. Cant decide if they'll be strong enough for my main wheelset... going on a turner Czar, I weigh 165lbs/75kg, ride hard rocky east coast xc, with a few cat1 races a year..
    -- Any new/more feedback on these skyweights ?? --
    Reputation: Noclutch's Avatar
    Jun 2010
    Quote Originally Posted by hiss2 View Post
    No real world feedback yet, but my plan is to use the 25.5 rear and 29 up front.
    I like the idea of 4mm bead walls in the rear, and more support being wider up front.
    Sent from my iFern using Tapatalk while not riding, dammit!
    Sep 2016
    Quote Originally Posted by tangerineowl View Post
    Did your rims arrive yet? I ordered the same ones, and now I'm getting nervous because I also ordered spokes based on the 552 ERD published by CarbonFan. I hope it's accurate.
    Jan 2002
    Quote Originally Posted by Noclutch View Post
    Never thought of that for some reason but like that idea.. I typically run a wider tire up front anyway..
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    Nov 2013
    Quote Originally Posted by smitty39 View Post
    Not expecting them to arrive for another couple weeks.
    Yeah, I'm wanting the wheels built up asap once the rims arrive, but in the end decided to wait to measure the ERD myself before ordering spokes.
    so is CarbonFan better to get as my first carbon rim instead of Light Bicycle?
    will be doing non aggressive riding, just normal trails
    Jun 2013
    For sure, great rims and I was impressed with the build. Even spoke tension,etc. nothing to have to worry about just put on and ride.
    Nov 2013
    Rims came in today. That was quick!
    These are my first carbon rims. They look pretty good. Weights 277gm and 280gsm.
    Will measure the ERD this Sat.
    Sep 2016
    Excellent - thank you! I'll stay tuned for the ERD measurements.
    bikes don't have motors
    Reputation: life behind bars's Avatar
    May 2014
    Pics?
    Quote Originally Posted by me;
    Of all the paths you take in life, make sure that most of them are dirt.
    Jan 2002
    Given the internal dimension, assume this qualifies as weight weenie. [COLOR=#333333]New T800 mix. 1290 grams on my uncalibrated scale. 30mm outer/24mm inner (verified with my digital caliper), DT240s XD driver, 54 poe, 28 spoke 3x Pillar bladed spokes straightpull. I don't have a tensionometer but feel very equal and threw them on my truing stand and they are trued very well. Have a 2.25/2.35 Racing Ralph set that mounted up quick and easy. Finish on the rims is fantastic. Only one ride in, but they're nicely stiff and snappy. Coming from a lightweight aluminum rimset that lost significant tension just inflating the tires and needing constant truing on the rear I'm looking forward to all the benefits of carbon.
    Any follow-up review / ride report on these yet? Still holding up well? Any hard hits/Rim strikes yet? Thanks
    Reputation: Davide's Avatar
    Quote Originally Posted by zinedrei View Post
    Not sure how one can answer that ... my Light bicycle look great and are holding up fine. Weight was 1170 for 650b.
    Carbonfan.com Skyweight 30/24 mm carbon wheelset-img_0706.jpg
    Nov 2013
    I've decided to hand over the rims and hubs to a wheelbuilder I met with on Fri.
    Anyhow, these were the 27.5 22mmInner 25mmDeep 28mmOuter 280gm rims.
    I measured the ERD a few times around each rim. 551 each time.
    Sep 2016
    Thanks - appreciate the ERD info. Waiting on mine to arrive and it sounds like the spokes I got should be okay.
    The ERD that I measured was incorrect. My spokes ended up being about 2mm too long. So the actual ERD should be 591mm, as listed on their website.
    It's the first time I screw up measuring an ERD. I don't know what the hell went wrong. Sorry for the mix-up. I hope I didn't cause any trouble for anyone.
    Formerly of Kent
    Thanks! Very good to know. I haven’t ordered anything just yet, but this helps.
    I might be able to re-lace some CX-Rays I have on a twice-used set of wheels.
    Death from Below.
    Nov 2013
    No pics at the moment I'm afraid, however I mounted 650x42 tyres (wheels are for my gravel/road bike) today while I wait for some new rotors and other bits.
    Was planning to use CX-Ray spokes, but in the end I decided on D-Lights as they are a bit cheaper and the weight is still pretty good. Wheelsmith 12mm brass nipples. Carbon-ti hubs.
    1206gm without tape or tubeless valves.
    That will do me fine!
    Sep 2016
    Very nice build! Still waiting for my rims to arrive. It seemed to take a long time for them to ship, and so far 2+ weeks in-transit (as expected from China).
    Sep 2016
    While I did not get the same wheels as the OP, I wanted to post a positive review of Carbonfan rims. I got a pair of 650b's that weighed-in as-advertised and the ERD was as-advertised. With budget hubs, my build weighted-in at 1290g.
    My only gripe would be they took 3 weeks to ship. Once shipped, they arrived in about 2 weeks.
    Any long term reports on the wheels? I'm ready to pull the trigger on a pair and wondering how they hold up. Ive had it with my crest mk3, always coming loose, flex amd loose a lot of tension when tire seats. Then the nipples eventually start to pull and bulge around the nipples.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by machine4321 View Post
    I just built up similar ones from Oxive, 290g 28mm asymmetricals. I went out and rode them hard yesterday, but the real test will be during the XC race series. I plan to use them for the XC races, but the bigger endurance stuff will probably see my slightly heavier Nextie setup. I don't plan to go "trail ride" them on big long rocky rides.
  1. New Carbonfan Wheels
    By driven916 in forum Wheels and Tires
    Last Post: 2 Weeks Ago, 06:46 AM
  2. New CarbonFan wheelset review
    By yohyat in forum Wheels and Tires
    Last Post: 03-22-2018, 08:47 AM
  3. Carbonfan Carbon rims & wheels
    By Shoao in forum Wheels and Tires
    Last Post: 01-21-2018, 06:06 PM
  4. SPECIALIZED Roubaix SL4 + Carbonfan rim video from Belgium
    By Shoao in forum Custom Builders & Other Manufacturers
    Last Post: 04-15-2017, 04:17 PM
  5. Replies: 6
    Last Post: 08-20-2014, 07:36 PM
Members who have read this thread: 237
