Results 1 to 25 of 25
    Reputation: phlegm's Avatar
    Carbon headset top cap - Reality Check Plz
    Quick, but strange question. Based on the photo, I'm assuming there's some sort of snap-in cover on the bolt head, covering the hex?
    ups and downs
    A plug or cap sounds about right...
    There's also these. Purely Custom Online Store - 1 1/8" Carbon Threadless Headset Caps - Custom Bicycle Accessories
    I've got these on two bikes, simple and light and no problems at all.
    Single Speed Junkie
    Reputation: crux's Avatar
    Quote Originally Posted by rockyuphill View Post
    Cool carbon caps.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    It's a rubber plug.
    Great - cheaper and nicer than what I was looking for. Thx for the link!
    Quote Originally Posted by Saul Lumikko View Post
    It's a rubber plug.
    Thanks Saul, figured it had to be. Cheers.
    Reputation: roaringboy's Avatar
    As an alternative - these are nice caps - i have a couple:
    http://www.carboncycles.cc/?s=0&t=2&c=70&p=635&
    Come on, dare me!
    Reputation: Jerome's Avatar
    If you really want to go light...
    Go with these : Top Cap
    I got one and they're insanely light and hold on well. Expensive but that's the price of passion!
    Reputation: DRILLINDK's Avatar
    Mar 2012
    Quote Originally Posted by Jerome View Post
    This is cool! Thnx
    bike rider
    Reputation: mattkock's Avatar
    The Purely Custom ones are the Tits!!!
    My Bikes Kick Ass!!!
    Those Purely Custom ones are lovely - postage is a bit of an issue to England though!
    I always polish the decals off the CC ones and add an alu bolt:
    ballbuster
    Reputation: pimpbot's Avatar
    I'm surprised anybody here is running a top cap. I like to use a compression nut cap while setting the headset, and just take the whole thing out. No ill effects, and I'm 210 pounds. I'm looking down a hollow tube at the top of my tire.
    Heh... I'm the last guy on the planet who should be concerned with shaving weight, but I love a light bike (within reason).
    Reputation: GhostRing's Avatar
    Feb 2012
    cool, but sheesh - uglier than a prison tat given by a blind inmate. O.o
    Time wounds all heels...
    Re: Carbon headset top cap - Reality Check Plz
    Quote Originally Posted by pimpbot View Post
    You won't find it so cool when that top tube punches a hole through your sternum in a crash.
    Sent from my XT890 using Tapatalk 2
    +17 points for correct use of the word "sternum".
    Reputation: bholwell's Avatar
    Oct 2007
    If you're running an FSA headset, this carbon top cap matches nicely. No ugly plug, either.
    FSA Carbon Top Cap > Components > Headsets and Spacers > Headsets | Jenson USA Online Bike Shop
    Tire Design & Development Engineer. The opinions expressed in this forum are solely my own.
    Don't be hasty.
    Quote Originally Posted by roaringboy View Post
    ...Yeah pretty sure the stem will be in the way of that.
    Thumper
    Reputation: WickedLite's Avatar
    Compress your stem and align bearings, steer tube and spacers using another stronger cap with your star and bolt.
    Set your stem.
    You can now remove star nut bolt and cap since their purpose is done.
    You can go with a crazy 3g Fibre-Lyte to keep the dirt out.
    Quote Originally Posted by WickedLite View Post
    Set your stem.
    While you are technically right (the stem holds the system together after the preload is set with the nut & cap), I'm not sure I'd want to ditch them to save a handful of grams. I like the idea of the safeguard it provides.
    ups and downs
    If you crash hard enough you can spin the stem on the steer tube no matter how tight the steerer clamp bolts are, and without the star nut and top cap you're screwched for getting it realigned with the proper headset preload.
    +1
    Sent from my SM-N900T using Tapatalk
    bike rider
    Here are the ones that I run but those Extralite Hypercaps are SEX!
    Bit of a dated thread, but I've been using a Cane Creek AER headset since last season. This is technically a road headset as the original "bearing" doesn't amount to much more than a a washer. Pretty amazing.
    I've substituted that bearing with a 40 series from Cane Creek which works nicely, and is recommended for mtn use.
    The cap is a bored out ALU, and while I haven't weighed it, I'll guess 3 gms max. (Also, the headset assembly itself has bored out "windows" to save weight. Don't think you'll find lighter in an XC platform.)
    Reputation: Acko's Avatar
    Feb 2014
    Top cap
    mmmmmmm
    Took an old chris king 9.5 gram top cap and shaved it down on the lathe
    to 4.6 grams. Including an aluminum top cap bolt, weighs 6.02 grams on my scale.
    Quote Originally Posted by mtbmitch2 View Post
    Sweet one. Very well made.
