Results 1 to 3 of 3
    espresso lover
    Reputation: Frankie - B's Avatar
    Calling a certain Dane I met in Riva del Garda
    I wondered how the rest of the vacation was and if I can cet some pics of your bikes to look at them in detail (again)
    No cool signature...
    Hi Frank
    That was fun to see your post in here
    As requested, here are some pics of my Carbon Rush. There are some minor diff compared to the TransAlp set-up. The KMC chain on the pictures was changed to an XT and the back gear cable was also changed from I-link to XT.
    All the specs are:
    Brakes Rear: Avid Juicy Ultimates with Aligator rotors 160mm
    Brakes Front: Avid Juicy Ultimates with Aligator rotors 160mm
    Cables / Housing: I-Link
    Cassette: Shimano XTR CS-M970 11-32 9 speed w lockring
    Chain: Shimano XT, '07
    Crankset: ATIK with FRM rings and FRM Ti bolts
    Derailleur Front: Shimano XTR FD-M970 '07 (Bottom pull Top Swing 31.8mm)
    Derailleur Rear: Shimano XTR RD-M971-GS '07 Long cage
    Fork: Lefty Speed Carbon SL, 1240 g
    Frame: Cannondale Rush Carbon
    Grips: Progress
    Handle Bar: FSA K-force flat 31,8 mm, 600 mm, 6 back sweep
    Bar ends: Ritchey WCS
    Headset: 1 1/2" Cannondale HeadShok SI
    Pedals: Crank Brothers Egg Beater 4Ti
    Quick Releases rear: Tune Quick releases
    Rear Shock: Fox Float RP23
    Seat: Fizik Nisene Ti
    Seat Binder: Cannondale
    Seat Post: New Ultimate carbon 27.2/350
    Shifters: Shimano XTR SL-M970 Rapid Fire Shift
    Stem: Cannondale HeadShok Si one piece
    Tire Front: Specialzed Roll X Dual Pro 2,0
    Tire Rear: Schwalbe Nobi Nic 26 x 2.10
    Wheel Set:
    - Rims: Stans ZTR 347 Olympic Disc 32H Black 347g.
    - Rim tape: No-tube
    - Spokes: DT Swiss Revolution, 64 a 4,35g
    - Nipples: DT pro lock aluminum (64 pices) - 20g
    - Hub Front: Cannondale Omega Si lefty -117g
    - Hub Rear: DT Swiss 240s disc brake -273g
    In this set-up the bike is around 10,5 kg.
    I also have a lighter set-up where I ride a Speedneedle (-200g), no bar-ends (-90g) and lighter tires (app -300g). Of cause I would also put the KMC 9SL chain back on (-50g).
    Any comments?
    I will write to a PM with the rest of the holiday story
    I am still interested in upgrade suggestions that will not compromise strength.
    Have anybody tried the Hope Mono Mini Pro?
    And, can the weight (295g) be confirmed ?
