Results 1 to 6 of 6
    MTBR Tool
    Reputation: Srexy's Avatar
    Burner Build Advice pls
    Medium Turner Burner - here is the build so far. Some parts came from a 2000 Giant NRS,
    I have a few unconfirmed weights due either to my haste or my scale's shortcomings. I couldn't weigh the frame before building it up as my scale has a 5lb limit so I used 5.9lbs as my weight. Other areas that are unconfirmed are the cables (used 100g as a rough estimate which is probably high), and the disk brakes which I installed before weighing.
    I'd like to take another 1/2lb off but have run out of SO blessings so the budget is limited. I don't really want to sacrifice much in the way of durability so I was thinking pedals and brakes - perhaps Candy SL's and some Magura Louise's...
    If anyone has any input please feel free to share.
    Shifters : Deore LX Mega :from NRS 244g
    Disk Brakes :Hayes :from NRS 932g
    Grips :Aireon :Supergo 75g
    Handlebar :Easton Monkey Lite SL Carbon: Supergo 135g
    Stem :Forte 115mm :Performance 152g
    Headset :RaceFace Deus : Supergo 104g
    Cables :Gore Ride-on, generic :Supergo Misc 100g
    Frame :Turner Burner 04 M w/Manitou Swinger SPV 3: Supergo 2567g
    Fork :Noleen Mega Air 100mm :Ebay 1389g
    Crankset : Deore XT Hollowtech m760 w/BB :Supergo 865g
    Fr Derailleur : Deore LX m752 :Nashbar 137g
    R Derailleur : Deore XT m?? :from NRS 255g
    Chain :Sram pc99 : Supergo 294g
    Pedals :Ritchey Comp v3 mtn :Supergo 390g
    Cassette : Deore XT 12-32 :Supergo 264g
    Saddle :Aireon Team :Supergo 173g
    Seatpost :Thomson Elite 420mm x 27.2mm : Supergo 291g
    Wheelset :WTB Laser Disk hubs DT Swiss XR4.1 rims :Oddsandendos 1596g
    Skewers :Speedcific bolt thru :Oddsandendos 65g
    Fr Tire :WTB Mutanoraptor 2.4 :Supergo 595g
    Rr Tire :WTB Velociraptor 2.1 Kevlar :Supergo 660g
    Rim strips : Stans :Stans 110g
    Tubeless :solution: Homebrewed spooge 120g
    Total (g) 11622g
    Total (lbs) 25.62lb
    Pic:
    Reputation: MWWH's Avatar
    a few suggestions
    Nice bike you have there- just the frame I would like. Tires are pretty personal I guess but IRC mythos would save you a bit- they weigh about 450gm for the 1.95s or 550gm for the 2.1s (someone correct me if Im wrong here), and the rear is a bit like the Velociraptor- I like em.
    The Thompson post is nice but seems heavy compared to some of the carbon offerings out there. There are other areas but I guess more expenisive such as XT->XTR 952 r.derailler (only saves about 30 or so g though), and XT->XTR casette.
    As it it is very sweet- you must be happy with a sub 26lb burner. Nice work.
    Quote Originally Posted by Srexy
    Total (g) 11622g
    Total (lbs) 25.62lb
    Pic:
    Just passing through....
    Reputation: DaFireMedic's Avatar
    Very Nice!!!!!
    That is one good looking bike.
    Relatively cheap weight savers:
    Grips: Foam will save 45-50 grams
    The SRAM PC-89r Hollowpin weighs a bit less than the PC-99. Mine weighs 255 grams at 106 links. Costs $27 at JensonUSA. The KMC-10 weighs even less. If you wait till you need to replace your chain anyway, its basically a low or no cost item.
    Cut down your seatpost. I'm 6' 3", and ride an XL. I need about 360 mm of seatpost to get an adequate insertion length into my seat tube. While each bike is a little different on that, you almost certainly don't need 420 mm, especially riding a medium.
    Using Al bolts on all non load bearing parts, shifters, etc can save a surprising amount of weight. Ti is not as cost effective, but should be used (or steel) on load bearing parts such as the stem and seatpost clamp.
    Candy pedals are nice. I picked up a set of the Candy C's (a tad heavier than the SL's but cheaper) on Ebay for $57 brand new including shipping. Mine weigh 314 g's.
    Nice fork by the way.....The Noleen was the best weight/performance enhancing item I bought. You can get Ti brake bosses for them also, saves about 10 grams for $11 or so.
    There are defintely lighter tires, but thats also an area where you wouldn't want to compromise just for weight. If you find a lighter tire that you like, there are some large weight savings to be had there.
    Expensive:
    You could drop quite a bit more weight and still maintain durability, but it'd require a bigger investment. A lightweight 5 bolt compact crankset with a 20t granny ring, combined with a Dura-Ace 12-27 rear cassette/derailleur is a big weight saver, but at a financial cost. Being that you have already invested in a quality crankset, It probably wouldn't be worth it.
    Once again, nice bike. You don't really need to change a thing.
    If you want to play with electricity, more power to ya......
    6x7=Dont Panic!
    Reputation: TheRedMantra's Avatar
    Shifters: Take the pods off and put some carbon patches there like Duckman, or just some tape.
    Grips: Foam of Tape!
    Pedals: Some wife beaters or something lighter...
    Cassette: Consider a road cassette light ultegra or dura ace
    Seatpost: I would keep the Thomson, but that is an area to save some weight by going carbon.
    Herro prease
    MTBR Tool
    Thanks for input
    And thank you for the compliments everyone. It is certainly the best bike I have ever owned (not that I have had a huge inventory or anything). I was turned on to the Noleen by you guys and owe you many thanks for the 2 that I currently have (wish I had bought more!)
    I'm leaning pretty heavily towards the Candies right now. The Ritchey's that are on there are a $25 bin buy from Supergo and have a tendency to stretch the springs every time I hit a rock - I think they're on their last legs. The IRC's are great tires but I haven't had much luck with them here in rocky AZ where the sidewalls are constantly being ripped out.
    I'll have to check on the seatpost length - as you can tell from the photo the Burner has a fairly steep top tube and there's a lot of seatpost exposed - according to the Turner site the seatpost has to extend below the gusset at the top-tube/seat-tube union.
    I will also start hunting down AL and TI bolts for it - what are the ballpark weight savings for a full bolt kit again?
    a complete set of 2004 Louise brakes would run in at 842g (mine weight that). You would save about ΒΌ pounds, and the brakes are great! Very nice feel and power! i still prefer my Martas, but for the price, they are an excellent choice!
    Luego!
    CODMAN MCM#101
    CODMAN MCM#101
  1. Replies: 5
    Last Post: 06-28-2004, 11:30 AM
  2. build advice for joker xc
    By Rabid in forum Ellsworth
    Last Post: 05-28-2004, 09:45 AM
  3. Replies: 12
    Last Post: 04-17-2004, 12:11 AM
  4. Replies: 1
    Last Post: 04-15-2004, 08:52 AM
  5. Need advice on new/used build...
    By kalbo_1 in forum Beginner's Corner
    Last Post: 03-19-2004, 03:56 PM
