Results 1 to 2 of 2
    Brake system weight Avid mech VS XT Hydro.
    Ok what's the weight difference between
    Avid 203 front (converted from 165mm) with adapter and 165 rear,both full length jagwire housing with Avid SD Mag levers
    VS
    Shimano XT M755 Levers with M755 four piston calipers in 160mm for front and rear. Average house length for a FS med size frame.
    I was trying to figure this out and came out with some pretty close number, now I just need an outside opinion.
    Thanx
    Jm.
    Jm. is offline
    Reputation: Jm.'s Avatar
    Shimano M755 165mm rotors front and rear = ~930g
    Avid mag levers ~160g + Avid rear caliper + rotor and hardware ~360g + front caliper + bolts and 203mm rotor ~400g + ~2m of brake housing which is about ~80g + ~30g for two cables = 1031
    So about 100g or so, however I'd bet if you weighed those particular setups on your own bike you may find even more difference. To put it simply, avid cable discs are fairly heavy. The calipers and rotors alone weigh what other complete F or R systems do. Those Shimano disc brakes are not exceptionally light, but they come out significantly lighter than the avids.
    I know in my heart that Ellsworth bikes are more durable by as much as double. AND they are all lighter...Tony Ellsworth
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. Hydro vs. Avid mech
    By spacoli in forum Brake Time
    Last Post: 07-26-2004, 09:11 AM
  3. Run a mech disk brake off XT dual levers?
    By mtnkiwi in forum Brake Time
    Last Post: 06-29-2004, 08:38 AM
  4. XT disk brake weight
    By TeXe in forum Weight Weenies
    Last Post: 04-06-2004, 06:55 AM
  5. AVID mech disc brake question, on a SS....
    By hu-man in forum Singlespeed
    Last Post: 03-07-2004, 10:48 PM
