• 01-18-2013
    phoenixbikes
    Bolt-on rim brake posts for a carbon fork ?
    I have an Origin 8 carbon fork that came with rim brake posts that can be moved up/down, or removed. I ran the bolt-on posts with a 29" wheel initially, and then switched to a disc brake and a 26" front wheel. The fork is obviously designed for a disc brake and there's no question there, but the bolt-on rim brake posts are interesting. I thought about putting them back on so I can run my old (very light) xtr/mavic front wheel. My question is, will I fatigue/stress the carbon blades more with rim brakes than a disc brake ? Origin 8 did include them with the fork, so it can't be a huge issue, but I don't want to have the fork fail.
  • 01-18-2013
    Roadsters
    Is this the fork you have?
  • 01-18-2013
    phoenixbikes
    Yes, that's the one. I removed the rim brake posts but I want to use them if it's safe to do so.
  • 01-19-2013
    Procter
    Carbon has very good fatigue strength, i wouldn't worry about it.
    Also the stress concentration on a fork is usually highest around the crown-steerer joint, and, on a carbon fork, on the interface between the sanctions and the metal crown. Its more likely to fail there first if it ever does.
