Results 1 to 2 of 2
    Beep, Beep...
    Reputation: vizcaino's Avatar
    Best way to save some weight in this bike....
    Hi,
    I have just bought a cannondale rush 1000. I would appreciate your advice and comments about the best way to save some weight.
    Thanks,
    Fidel Vizcaino.
    These are the rush 1000 specs
    Frame Rush, 110 mm
    Fork Lefty Speed Bonded DLR2, 110 mm
    Rear Shock FOX Float RP3
    Rims Mavic CrossLand UST
    Hubs Mavic CrossLand UST
    Spokes N/A
    Tires Maxxis CROSSMARK XC UST, 26 x 2.1"
    Pedals CrankBrothers Egg Beater
    Crank FSA Afterburner MegaExo, 22/32/44
    Chain Shimano 9-speed
    Rear Cogs SRAM PG-970, 11-34
    Bottom Bracket FSA Afterburner MegaExo
    Front Derailleur Shimano LX
    Rear Derailleur SRAM X-9
    Shifters SRAM X-7 Trigger
    Handlebars FSA XC-281AOS, 25 mm rise
    Stem Cannondale XC3 HeadShok, 31.8 mm
    Headset Cannondale HeadShok Si
    Brakeset Avid Juicy7
    Brakelevers Avid Juicy7
    Saddle Fi'zi:k Nisene II Sport
    Seat Post FSA FR-270
    mechmann_mtb
    Guest
    you can drop a couple hundred grams by using non-ust tires. that should be cheap and easy.
