Results 1 to 10 of 10
    likes to ride bikes
    Reputation: TunicaTrails's Avatar
    Best long seatpost: 400mm, setback, 27.2mm
    I'm looking for a nice, safe, but light and bump-compliant seatpost in 400mm length. It also needs to have a setback of 25mm or so, and it must be 27.2mm diameter for me.
    Right now I see the carbon fiber Truvativ Noir Team and Noir World Cup posts at about 250g. That's not terribly light and reviews say they're kind of stiff. Is titanium a better material for weight and vibration damping at this length?
    Ericksen Ti is my vote
    I have exactly what your lookin for and very bump compliant. I think from memory it was somewhere in the low 200's for weight. It's on my ridged SS. Beautiful craftsmanship.
    High Ho Sultan, Lets GO
    JmZ
    JmZ is offline
    Reformed Lurker
    Reputation: JmZ's Avatar
    Like the Moots Ti I found at a local swapmeet a while back.
    380mm and came in at about 235g. Has setback, and is 27.2mm.
    Was using a Salsa Shaft at 27.2 X 400, and that came in at 298g.
    JmZ
    JmZ
    From one flat land to another.
    Advocate as if your ride depends on it...
    Reputation: boude's Avatar
    bontrager 400mm * 27.2 25mm = 168grs
    Fueled by Tigerblood
    Reputation: mtnbikecrazy55's Avatar
    + one for the eriksen Sweetpost, Kent is the MAN!!!
    likes to ride bikes
    The Kent Eriksen is a sweetpost for sure, alas:
    "Our seatpost hardware fits traditional, round style, 7 mm diameter saddle rails. This accommodates about 90% of the saddles on the market. Please note, some rails are tighter to mount into the hardware than others."
    My Selle Italia Flite XC Gel flow saddle has fat rails, 9mm I believe. I'm going over the seatposts I found very carefully to see which will be compatible with it.
    I thought Kent had the option to supply the seatpost with larger rail clamp? I'd call him and ask. You are not going to a more perfect choice.
    Yes, he has hardware to accommodate oversized/ovalized rails.
    I have a selle Italia flite with oversized rails and it works great!!
    Just call and talk to him, you won't be disappointed!
    2011 ERIKSEN XX BUILD IN PROGRESS HERE: http://forums.mtbr.com/showthread.php?t=698673
    Reputation: Steel29er's Avatar
    +10 for Eriksen
    anything Steel
