Page 1 of 3 123 LastLast
Results 1 to 100 of 268
    ~Reformed Mechanic~
    Reputation: Ace5high's Avatar
    Jan 2011
    Best Lightweight Crank?
    Im thinking of finally getting a proper lightweight Crankset to shave some Grams. Im now running the Truvativ Stylo Oct 3.3 converted to a 2x10 with lightweight Bash guard.
    The listed weight on the Stylo Oct are 845g with GPX BB mine is probably close to 800grams without the large chainring and light Bash.
    What are the Top lightweight Cranks in the $300-400 range. The XX has good reviews but is 754g and the XTR's are even heavier...
    Are there any cranks in the 650-700gram range that are still strong and reliable or should I just stick with the Stylo Oct?
    Noir
    I'm running the Truvativ Noir, its a strong light crank. I recommend it, and a good deal can be found.
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by keithv70 View Post
    Ive heard Good things about the Noir. The SRAM website only lists a difference of 45grams between the Noir and Stylo Oct... Thats not nearly enough for me to make a switch
    Dec 2008
    2011 S-works carbon cranks, 175mm = $300.00
    Lightning spider & lock ring. Double chainring & bashguard or turn it around & its configed for triple chain ring.= $60.00
    Extralite 22/32 chainrings.
    BBG superlite chain guide = $12.00
    These are US prices.
    Attached Thumbnails Attached Thumbnails Best Lightweight Crank?-img_0586_2.jpg
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by xc71 View Post
    Nice! Do you notice any flex with it? Also, where can the s-work cranks be purchased online?
    Dec 2008
    I don't notice any flex - super stiff as there is no weight limit on these cranks.I'm 150 lbs.
    These are the stock cranks on every S-Works bike sold.
    To purchase:
    Specialized.com
    lightningbike.com
    Extralite chainrings = fairwheelbikes.com
    bbgbashguard.com
    Note: The Lightning spider & lockring is 22 grams lighter than the Specialized spider/lock ring.
    The Lightning lock ring tool was $20.00.
    Dec 2008
    Ace, S-Works cranks don't work on every BB. eg. 92 PF, 73mm threaded.
    I rigged these up to work on a 68mm threaded BB with Hive cups.
    Hollowgram SL
    These are amongst the lightest,stiffest and sexiest cranks on the market however it will set you a little more than your budget.
    yes they are extremely stiff
    ~Reformed Mechanic~
    Jan 2011
    Yeah, I forgot there was a reason I wasn't looking at these as an option... What did you BB setup end up weighing?
    Reputation: sfer1's Avatar
    Get the new Race Face Next SL 2x10 crankset. It's light (610g including BB) and compatible with every bottom bracket standard (*), and costs half as much as the Hollowgram SL. I haven't tried it yet, but my Next SL triple is also very stiff and shifts as well as the XTR crankset it replaced.
    BSA -> Race Face Turbine X-Type (included with the crankset)
    Press-Fit BB92 -> Race Face ∅41mm Press-Fit (BB92) → X-Type (sold separately)
    BB30 -> Race Face BB30 → X-Type Adapter (sold separately)
    Press-Fit BB30 -> RESET PF24
    Reputation: Crankout's Avatar
    Jun 2010
    Double dong on the Noir. Light and stiff.
    Go with a colored one if that's your game.
    Stick around if you're housebroken...
    Dec 2008
    Quote Originally Posted by Ace5high View Post
    The Hive cups I believe were 95 grams.
    Reputation: madsedan's Avatar
    Aug 2010
    I wwill be hunting for Noir myself, occasionally a 3.3 set without BB will show up new on fleabay for about $210, thats almost as low as what a Stylo OCT with BB cost. I'd like the Noir but can't afford to spend $100 premium for it over the Stylo for only 50 grams of what so when the time comes I may end up with another Stylo OCT, I'll be looking for $150 deals online soon.
    Hardrock 29er, Niner EMD9, Cannondale F29, Camber Expert, 650b Nickel all gone.
    2014 Giant Anthem 27.5 here.
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by Crankout View Post
    Noir just doesnt offer any real weight savings over the Oct...
    Hack Racer
    Reputation: Cheers!'s Avatar
    xc71,
    Are the specialized crankset the same as the lighting crankset? If so can you not just run the lighting bottom bracket cups? Especially for standard 68mm threaded bottom bracket frames...
    Dec 2008
    Quote Originally Posted by Cheers! View Post
    xc71,
    The Lightning are the same with the exception of the axle.Lightning offers different length axles for diff. BB. The S-Works axle is only 90.7mm.
    ~Reformed Mechanic~
    Jan 2011
    I have anorther question thats related, I started another thread in Cranks but not a single response...
    I am also wondering what some of the lightest Aluminmuim Crank arms are on the market right now?
    Hack Racer
    Xtr.
    ~Reformed Mechanic~
    Jan 2011
    Xtr.
    Yeah, I just wish they sold their crank arms only so I could set it up the way I want...
    Hack Racer
    ebay for XTR arms. Or try the MTBR classifieds.
    There is also RaceFace Turbine SL cranks.
    What is...
    the q factor of the Specialized S-Works cranks? The Lightnings seem ridiculously wide at 175 mm!
    MaL*size=
    Reputation: MaLoL's Avatar
    xtr, or cannondale hollowgram. all the other options are either heavier or with cracking or worse issues.
    They're not overly light though, and nothing like as sexy as the old Deus ones.
    Reputation: dogdaysunrise's Avatar
    RF Next SL.....Hollowgram....all way beyond his budget.
    I don't think there is really anything light in that budget.
    Used XTR,XX, maybe Aerozine and KCNC....
    Maybe some older FSA Carbon cranks, run them double with a Omni Racer BB.
    All others are $500 and up....THM Clavicula, Storck Powerarms, Lightning cranks and above mentioned RF and CD HG.
    ...love is the absence of fear....
    Dec 2008
    Quote Originally Posted by barrows View Post
    My 2011 S-Works cranks have a Q factor of 167mm.
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by dogdaysunrise View Post
    Yeah, many are mucho $ some mentioned are in my budget. I think Id like to stick with Aluminum at this time so Im looking into an XTR setup since it doesn't seem there are other Alm crank arms I can build up in that price range...
    Doesn't look like Ill find any used on Ebay just yet, because someone needs to tell all the people bidding $400 for used/beat 2008-2010 XTR's on Ebay that they can get them NEW for under $400
    Hack Racer
    Quote Originally Posted by hedgeboar View Post
    why not? it has a titanium spindle. The color not to your liking?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    SLX arms are within 10 grams or so, throw some Middleburn rings on em and you have a reasonably priced setup.
    No, I just love all the intricate CNC machining of the older ones, that's all.
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by AZ.MTNS View Post
    Do you mean XT arms? The Weight listed on the SLX triple is showing as 896g's ! I dont see how that large of a difference could be all in Chainrings...
    Reputation: 2002maniac's Avatar
    Nov 2008
    slx has beefy steel rings. the arms alone weigh about the same as xt
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by 2002maniac View Post
    So do either one way close to that of the XTR arms?
    Just trying to figure out if I purchased SLX/XT arms alone could I use a lightning spyder and lightweight rings for the same weight or less of an XTR setup?
    This would be ideal...
    ~Reformed Mechanic~
    Jan 2011
    Ive gotten many recommendations for the XTR Crank to save weight but when I punch the numbers I just dont see the XTR saving me weight.
    Here is the mark according to Price Points "in house measured weights"
    2011 - XTR triple Plus BB = 772 grams + 56 gram Bash - 42t XTR Chainring 60gram?? = 768 gram total
    2011 Stylo Oct triple + BB = 830 grams + 56 gram Bash guard - 85 gram 42t Ring = 801 gram total
    Does 33 grams seem worth a $400 change over to XTR...?
    XTR crank arms are 526g
    + your bash gaurd @ 56g
    + XTR BB 88g
    + 32t chainring 43g
    + 24t chainring 25g
    738g
    Crankset's usually aren't the best place to save weight, unless you spend $$$$. If you really want lighter cranks your best bet would be lightning/specialized, otherwise your going to spend a lot for minimal savings.
    Dec 2008
    Like I mentioned above - XTR cranks with light chain rings. My Extralite 22T = 16 grams.
    Extralite 32T = 28 grams.BBG makes a bashguard thats 47 grams (oval holes) that fits the XTR cranks.I believe FRM rings are even lighter than the Extralites.
    The Sram Stylo OCT is already a great crank that probably offers the best value of any crankset on the planet. You get the same great long lasting rings as the Noir that are incredibly cheap to replace. And you don't have to worry about hurting a carbon crank, if you live in a rocky area like me. The whole crankset can be had for less than $200 at your LBS if they give you a discount. I was paying close to that just to replace my rings annually on my XTR. My 170mm Stylo OCT 3.3 crankset with bottom bracket came in at an even 800g. I've been told that the Noir actually isn't any lighter. I think Sram posts a lighter than actual weight for the Noir and a heavier than actual weight for the OCT to justify spending the extra money for the Noir. There are lots of pretty and expensive carbon cranks out there, but you will mostly be buying the bling factor vs. the Stylo OCT.
    Illuminati
    Reputation: scant's Avatar
    what rings would you want to put on XTR crank arms? when my original M970 rings wore out I tried middleburn chainrings. I spent ages playing with spacers to get the shifting correctly aligned, but they didnt shift anywhere near as well as the original M970 rings.
    I've got a spare M970 crankset (with worn out rings) that I'd like to rebuild if I can find suitable lightweight & not overly expensive rings,. that still shift!
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by COLINx86 View Post
    + XTR BB 88g
    + 32t chainring 43g
    + 24t chainring 25g
    738g
    So if the SLX arms are only 10 grams over the XTR's why not just buy the SLX arms use my bash, and some light 22t + 32t Chainrings call it a day for 748grams for $250 or so?
    If SLX arms were only 10g heavier, then there would be no reason to get the XTR's. SLX arms are 75g heavier, though.
    Reputation: 5power's Avatar
    Quote Originally Posted by TTTURNER View Post
    Good to know I have the nior but going Stylo next time
    ~Reformed Mechanic~
    Jan 2011
    I was just quoting post #28 but don't actually know the weights myself...
    ~Reformed Mechanic~
    Jan 2011
    Reminds me of why I got the Stylo Oct in the first place, good post.
    I guess I should have asked first if its worth replacing the stock chainrings with something lighter to get the most weight savings out of my current setup?
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    172.5mm option and lower Q would still be a reason for me..
    Liking my E.13/Hive SS cranks, by the way. And now they have a nice dual ring setup for the single crank.
    Executive User - UK
    Nov 2008
    I picked up a sixc carbon recently really cheap, sold the rings and bb leaving me with cost of circa $150 shipped to my door for new arms. Arms are really stiff and lighter than the old m970xtr I removed, really happy with it. Now race face are back in business not sure any blow out stock is around anymore. Good cranks though.
    ~Reformed Mechanic~
    Jan 2011
    Okay, thanks to everyone's info, got a pretty great info thread going here!
    I think What Ive decided to do is Keep the Stylo Oct Arms but lighten them with a new Superlight Bash and New Chainrings.
    Ive been looking at the below Rings:
    -Strong light Chainrings
    -FRM rings
    -Superlight Rings
    But cant seem to find the above anywhere online for sale in the US... Also, are the light CNC 22/24t rings holding up for you guys?
    This cranckset could be also an option.
    Products 2011 | BOR - Germany
    It is almost the same design as the tune smartfood. Bor(is), did also design the tune crankset.
    Hack Racer
    why do you need a bashguard? Run a XTR 2X10 crank (XTR FC-M980, 26/38). Better chainline. lower-q factor. plug and play. No need to triple source parts for various retailers online. Pay. Ship. Install. Ride.
    Rock and/or Roll
    Reputation: turbogrover's Avatar
    Dec 2005
    Has anyone here tried out the FSA K-Force Light 386 cranks? They are pretty light, carbon fiber arms, ceramic bearing BB, and blowout pricing on ebay.
    Axe
    Axe is offline
    Custom User Title
    Personally , I would not ride a crank without a bash for safety reasons. Those big ring cuts are mighty nasty.
    Reputation: scooter916's Avatar
    I just got a set of Rotor 3D 104bcd cranks, just arms are 556g in 175mm
    Quote Originally Posted by thefuzzbl
    aluminium has a tendency to fail when you need it most. i.e. you end up with a bad day.
    SLX Crank arms only
    Setup Single with Niner chainring:
    adam michigan karate monkey
    ~Reformed Mechanic~
    Jan 2011
    Hey AZ.MTNS, I could have said...
    " Your ignorance of things bicycle related is astounding"
    But that would have kinda made me look like a low life... so I didnt
    AZ
    AZ is offline
    Yeah but, all that anyone has to do is read your threads and your ignorance is apparent.
    No worries about "kinda looking like a low life", your already there.
    ~Reformed Mechanic~
    Jan 2011
    Hey im just reposting your quotes.
    How close did you say the SLX and XRT cranks were again was it 10 grams? And my ignorance is apparent
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by floydlippencott View Post
    Based on?
    AZ.MTS and I quote " Your ignorance of things bicycle related is astounding"
    All I did was post his comment, so if that makes me a low life then I guess your correct
    "You are" should be spelled "you're" and not "your." Even though English is my third Language, my spelling is better than yours. You're both low life losers.
    Now, back to the original topic.
    How about the Tune Bigfoot, nobody tried that one yet ? Seems light at 390g arms only.
    Anyone know what XT crank arms weigh? thx
    Tune Bigfoot uses a square tapered BB which means limited choice of bottom brackets and more weight. Not the stiffest crankset from the reviews as well. Looks out of place on most of the bikes besides steel frames. Esthetics aside best aluminum cranks: Cannondale Hollowgram, Shimano XTR. Carbon: THM Clavicula/Lightning.
    Chris.
    Reputation: Davide's Avatar
    Just checked on the Specialized web site and they are out of stock. Any Idea where to find them? Also, I think you fit them on the Mojo SL, do you know if they will fit a standard (2007 non-SL) Mojo? thank you.
    Dec 2008
    Quote Originally Posted by Davide View Post
    Yes they will fit the Mojo, same 68mm BB as the SL. I got the Hive cups to test if this would work, but I would go for the Zipp cups now.
    Only other place I know to get this is Canada, but because the bicycle industry is a screwed up joke up here you'll have to pay $800.00 for the exact same thing thats $300.00 in the USA with are money on par.
    Anyone got a picture of just the crankarms on a scale, like the SLX and XT already here?
    Feb 2010
    I found only this foto,but I'm not 100% sure are you talking about thais crank.
    moi at scale in Kanata, Ontario, Canada - photo by willy94 - Pinkbike.com
    How come no one mentioned the Sram X0 crank?
    Sram X0 788g with BB - $366
    Im looking to upgrade to a Next SL crank so mine will be up for sale with less than 50miles on it shortly...
    www.garabaghi.com
    more photos
    www.tripxamerica.com
    Reviews by riders.
    Hifi => Ex 9. Thank you warranty.
  67. #67
    The Next SL is way out of the OP price range though...
    www.garabaghi.com
    more photos
    Reviews by riders.
  68. #68
    Executive User - UK
    Nov 2008
    Thread is called "best lightweight crank" and you say you are "upgrading" to another so therefore it can't be "the best"
    They look pretty decent actually.
    Quote Originally Posted by PimpinD View Post
  69. #69
    Reputation: G-Choro's Avatar
    Double or triple? Color? Lemme know!
  70. #70
    Quote Originally Posted by G-Choro View Post
    X0 GXP 2.2 10-SPEED CRANKSET / TRV138 175 39/26
    pm if you are seriously interested with an offer.
    www.garabaghi.com
    more photos
    Reviews by riders.
  71. #71
    Reputation: B.Trimble's Avatar
    Oct 2011
  72. #72
    Ax-Lightness Engage
  73. #73
    Cannot say it's best as you have not tried it, have you? If so I would like to hear the thoughts. It's close to my Claviculas as far as the weight goes.
    Chris.
  74. #74
    Hack Racer
    i still say xtr m985
    they are on sale for 415 at online retailers
  75. #75
    I recently ran across these Extralite home page
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
  76. #76
    bike rider
    Reputation: mattkock's Avatar
    If you can find these they are Light, Stiff and COOL!!! Every time I see a set for sale I buy them. I have 4 sets.
    Attached Thumbnails Attached Thumbnails Best Lightweight Crank?-img_4641.jpg
    My Bikes Kick Ass!!!
  77. #77
    Feb 2010
    Kooka????
  78. #78
    Reputation: BubbleGum's Avatar
    Dec 2011
    E.Thirteen XC cranks seem to be really good. They are way less expensive that XTR or XX, but weight roughly the same.
  79. #79
    0ps
  80. #80
    Quote Originally Posted by spartan23 View Post
    Just for into: what is the weight of the Hollowgrams? Are they lighter than Lightning (at 440 with spider + BB) or Rotor 3d+ that come at claimed 493 without BB?
    Attached Thumbnails Attached Thumbnails Best Lightweight Crank?-rotor_3dplus_crankset.jpg
  81. #81
    Axe
    Axe is offline
    Custom User Title
    Quote Originally Posted by BubbleGum View Post
    They now came out with a cool double ring set to be used on their single speed cranks (it also can take a light bashguard) - with granny attached to the middle ring.
    Not the lightest, but price/performance is good. 667g with BB without rings. Double ring set is ~120g for 22/36. So a bit more then XTR - but noticeably cheaper, even with ~$90 for the rings. They are nice looking.
  82. #82
    Reputation: signalMTB's Avatar
    I run XX on my 29er and Caramba Double Barrels on my SS. The Carambas come in around 650g I believe. I've got my SS to fly just under the 20lb radar, and that's with some heavy arse Kenda Nevegals.
    ti Nuke Proof SS
    ti Moots Mooto X YBB
  83. #83
    I went with XTs when I did my hard tail. They seemed cheap enough and light enough with out breaking the bank.
  84. #84
    Man I wish that someone would try their hand at producing an updated version of the sweetwings
    Quote Originally Posted by mattkock View Post
  85. #85
    Quote Originally Posted by Goinslo View Post
    If I understand correctly, that would be these,
    http://www.bikerumor.com/wp-content/...eetwings-1.jpg
  86. #86
    Looks like they are a road version, but its awesome to see that someone is working on putting v 1.2 out there. Fingers crossed
  87. #87
    Reputation: willymcd's Avatar
    on my scale
    xtr m970 arms 537.8g
    raceface deuce xc 550g
  88. #88
    Feb 2010
    Whats the weight of Xtr 960 cranck arms??
  89. #89
    This thread got me looking for SWorks cranks. Man EBay is a crazy place. I know they're not in stock right now, but some SWork takes off went for $512 on Ebay vs. $300 new.
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
  90. #90
    Dec 2008
    Quote Originally Posted by TwoTone View Post
    I wonder if the Bidders were from outside the US. Specialized USA won't sell these cranks to anyone out the USA, you have to have USA mailing address & credit card billing address.These same cranks in Canada are $800.00
  91. #91
    Reputation: The Boz's Avatar
    Hey I'd just like to ask what you guys think of the SRAM XX crankset, and how it stacks up against some of these other suggestions. I'm also looking at the FSA K-Force Light. Looking for a 2x10 for a 29er FS build, it will be mostly SRAM XX components, but I'm not sure about the crankset. Thanks.
  92. #92
    Quote Originally Posted by The Boz View Post
    Look at the MTBR crankset reviews. There is often much more useful and specific info on the product reviews. The XX is a top rated editors choice.
  93. #93
    Low Rep Count
    Reputation: 1SPD's Avatar
    Ok, mine are set up as an SS but these particular crank arms weigh in at 466g for the arms alone w/ no hardware in a 170mm length. You can run them as a double if you so desire as the small ring mounts are still intact.
    XTR M960. My XT bb weighs in at 94g and my 32t ring (HBC) weighs 31g I picked them up on ebay for $125, sold the two rings that were on them for $45 and then sent them to ceramikoat.com to get milled down and ceramic coated for another $150. So I guess the cranks basically cost me about $230 and the new ring cost me another $35. Not a bad deal really.
    Attached Thumbnails Attached Thumbnails Best Lightweight Crank?-dsc_0552.jpg
  94. #94
    Low Rep Count
    Sorry, here is a picture of it at Crazy8's shop after he recoated them for me a week ago.
  95. #95
    Feb 2010
    1SPD is this chainring have standard shimano size??
  96. #96
    Low Rep Count
    The M960 crank uses a 102 bcd bolt pattern. I think other Shimano cranks are 104. I got it from Home Brewed Components who also makes them in other sizes and colors.
  97. #97
    the air is thin up here..
    Reputation: noot's Avatar
    Just weighed my XO cranks.
    460grams for the arms
    Pics here:
    Sram Truvativ XO Carbon Crank actual weight mngnt
    2017 Transmission Smuggler
    2015 Kona Paddy Wagon
    www.mngnt.com
  98. #98
    XO cranks
    194g + 282g + 178g = 654g (780g with GXP BB)
  99. #99
    Oct 2011
    Quote Originally Posted by 1SPD View Post
    Lovely finish on those. You must be very happy with them
    As there are lots of pictures of light weight cranks here are mine. 490 with 44/30 chain rings
  100. #100
    Quote Originally Posted by sfer1 View Post
    XO cranks
    ...snip...
    Impressive. Wish they weren't so expensive =(
    TBH I'm surprised the XO cranks don't weigh less. It'd be interesting to see a flex/strength comparison vs other carbon cranks.
    www.mngnt.com
  1. Replies: 16
    Last Post: 10-13-2011, 07:09 PM
  2. Inexpensive Lightweight Crank Options
    By Crackhead_Willy in forum Weight Weenies
    Last Post: 07-29-2010, 07:25 PM
  3. Lightweight ISIS Crank Bolts?
    By DavidR1 in forum Weight Weenies
    Last Post: 03-19-2010, 11:09 AM
  4. Lightweight double crank for race bike?
    By robdamanii in forum Weight Weenies
    Last Post: 11-28-2007, 01:31 PM
  5. lightweight & durable BB/crank sugestions?
    By schussfahrt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-31-2004, 03:12 AM
Members who have read this thread: 19
