Results 1 to 5 of 5
    jbf
    jbf is offline
    Reputation: jbf's Avatar
    Alum chainring bolts for granny OK ?
    It seems most high end cranks come with Alum outer bolts and steel inner bolts. Can I switch to alum inner bolts or will I have problems here? I am a 160 lb and ride east coast trails, my granny gets lots of use.
    Jag
    Jag is offline
    Reputation: Jag's Avatar
    You should be ok but....
    Quote Originally Posted by jbf
    It seems most high end s come with Alum outer bolts and steel inner bolts. Can I switch to alum inner bolts or will I have problems here? I am a 160 lb and ride east coast trails, my granny gets lots of use.
    I sheared mine on a steep incline while I was out of saddle, so make sure you keep them torqued to the proper spec. (I believe mine may of loosened up a bit when I sheared them). I run one cromoly bolt with the other alloy bolts and now I have more peace of mind.
    Jag
    Dad...isn't the word "abbreviation" being hypocritical being so long.... My 11 year old daughter.
    Jm.
    Jm. is offline
    Reputation: Jm.'s Avatar
    I've had alu granny-ring bolts loosen up on me as well. They are more finnicky also in terms of overtorquing, so you want it to be "just right" and check them occasionally.
    I know in my heart that Ellsworth bikes are more durable by as much as double. AND they are all lighter...Tony Ellsworth
    6x7=Dont Panic!
    Reputation: TheRedMantra's Avatar
    Titanium might be a better choice for granny bolts. I have never had a problem with an alu outer bolt though.
    Herro prease
    AL fine for granny, but use a torque wrench.
    I put at least 7,000 miles over 3 years on some generic AL chainring bolts and haven't had any trouble except for 1 or 2 that cracked from too much torque while installing. Just grease them and torque to ~7-8 Nm and they'll be fine. Torx head are slightly stronger since less material is removed compared to hex head. The ones that cracked did so at the head around the cut-out for the hex key, but that was at ~10 Nm.
  1. MOTD: Make sure your chainring bolts are tight
    By dubjay in forum Singlespeed
    Last Post: 12-13-2004, 05:24 PM
  2. Replies: 9
    Last Post: 11-25-2004, 09:03 AM
  3. washers on chainring bolts
    By dave66 in forum Singlespeed
    Last Post: 10-30-2004, 03:25 PM
  4. Shimano XTR chainring bolts; What material?
    By CODMAN in forum Weight Weenies
    Last Post: 02-10-2004, 01:52 PM
  5. chainring bolts: Al, Ti, mix???
    By FuelForThought in forum Weight Weenies
    Last Post: 01-16-2004, 12:29 PM
