Page 1 of 3 123 LastLast
Results 1 to 100 of 253
    Reputation: andrepsz's Avatar
    Jan 2013
    Scott Spark 1x10 lefty 19.20lbs
    LATEST (Feb/2015): 18.98lbs
    FIRST POST OF THIS THREAD:
    Lime bucket to mach. So HERE IT IS!!! 2011 Scott Spark 10 frame Large '69er'...20.9 pounds as pictures, with heavy pedals!
    Initially I got this bike used on ebay, converted to 1x10, did a overall in my garage ... sweet ride! .... but as we know the temptations are huge to go further and pursue our dream bike. I'm fairly cheap, refuse myself to spend stratospheric $$$$ for crazy light parts...so I try to find smart and cheap solutions with what I have in front of me. My goal is to hit 20lbs and you can help me if you have ideas.
    before, opening the UPS box: 23.19lbs
    Upgrades:
    -ZTR crest's 26er and 29er
    -Racing Ralph's TL
    -lefty carbon XLR 90mm 29er XL clamps - now I'm running with 100mm, one spacer out.
    -Project321 lefty adapter
    -Scrub's rotor 160/160 with china red bolts
    -Replaced the caliper's to Juicy Ultimate, had them in my garage in better cosmetic shape than the XX coming with the bike (levers are still XX)
    -Grip shift XX 10 speed on left side
    -Home made chainguide (46g)
    -MRP 36t chainring.
    -pedal boots
    -KMC X10SL Gold chain
    -new pulley set/inner cage
    control center, all controled by left hand (rear susp remote is on right side)
    Scrub's rotor with Juicy ultimate, need to upgrade the caliper bolts
    Seatpost Ritchey 400mm (217.75g) + Fizik saddle (157.9) = 375.65g. I'm considering doing this to save some weight:
    http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=112588" onclick="window.open(this.href);return false;
    new pulleys 14.45g/set
    Homemade chainguide, 46g with clamp and bolt
    Clean cockpit, with twinlock under the handlebar on the right
    And finally, I'm undecided if I print the 21lbs sticker right now, or wait for later and use the 20lbs one.
    ....HAHA, almost forgot, now its ok for you the get jealous, my leg weight is 946g. That's why I still use the Shimano heavy pedals, is the easiest to take my prosthetic off so far...any ideas? Ritchey V5 might be as easy? I would save 123g to Ritchey's.
    Mar 2012
    Very nice setup. Do you think you need the full shoe sole on the prosthetic? Might be able to shave a few grams from that heel! Would love to see some more details on the prosthetic.
    Jan 2013
    that's actually a soft foam, for trails I like having surface area to step on rocks, climbing with the bike on my back....its important to keep it that way. That is a very light leg, no more room for more weight saving but on the bike I still have some more options! thanks
    Reputation: Ramjm_2000's Avatar
    Jan 2005
    Excellent build, well done!
    Awesome. You must be able to spin at high cadence with such a light-weight prosthetic. I think that is the Pistorius Advantage...rotational inertia is greatly reduced....pretty big advantage on a bike. It would be interesting to see if you would be more efficient with higher cadence, because not a lot of people can keep it up. Sorta like the difference between a diesel and a gas motor and engine RPM. Maybe you wouldn't need as many gears because you are like the free revving, lightweight gas engine....like MotoGP.
    Reputation: phlegm's Avatar
    I like the chain guide - looks professional. (Some homebrew stuff looks craptastic.)
    You also get +37.5 points for finding a bucket that matches the color highlights on your bike.
    Jan 2013
    With new stem Ritchey 100mm 17degrees to compensate the angle after the 29er upgrade. Definitely an improvement during my rides.
    Jan 2013
    ... and if we just ...
    Quote Originally Posted by ginsu2k View Post
    Good analogy, my best is going UP ended! bike is light, I am light 147(67KG) but I'd say the rules are the same for us and able body people; the more endurance and athletic skills you have the better you'll perform out there. I don't really see any advantage spinning faster to be honest. I don't really want to bring it up Pistorius case for many reasons...like...I'm over it! its been the only subject every time someone talks to me and I support the idea and believe that he doesn't have advantages. Also.....bad and negative commercial lately! lets talks about my super bike!
    Jan 2013
    Quote Originally Posted by phlegm View Post
    No chain drop at all so far, works really well! bucket was laying around from my daughter, what a destiny hum!? it was made for my bike!
    Reputation: fondoo's Avatar
    Sep 2012
    wow, i am very impressed
    2013 Cannonale Jekyll 3 M
    Stay away from Ritchey V5 pedals and go with Xpedo's - I almost broke my ankle / have had tones of phantom pull outs on my V5's
    If you still want some V5's I have a pair of new ones with only 10 rides on them I'll sell you for 20 bucks + shipping
    Jan 2013
    Jan 2013
    Quote Originally Posted by broadwayline View Post
    WOW...Xpedo's are even lighter than V5?!...that's nice.
    The thing is; on my prosthetic side I NEED to release my leg easily. On my current shima's all I need to do is to spread my knees out and I'm off, I don't need to rotate my ankle as usual (I can't rotate with my prosthetic fast enough in case of panic). Do you believe I can do this with the V5 of Xpedo? I might be interested on your V5's.
    dude... this is too awesome. especially WW on your last component.
    Jan 2013
    Quote Originally Posted by bob13bob View Post
    Jan 2013
    Did some some work lately, 77g shaved on the bike, and 109g on my ' Race day emergency kit' (C02+Tube Race day).
    Here is a list of small jobs:
    -Barend plugs ESI+Scott top cap+bolt (16g) TO all carbon plugs/ top cap with adapter for pump (15g); -1 (pictures below, I liked it!!!)
    -No StarNut; -10
    -Grip change from ESI 'Chunky' (60g) to ESI Racer's Edge" (50g); -10
    -Twinloc(47g)+cable(5.30g)+housing(22.45g)=(75g) to Twinloc (43)+Alligator(14g) and shorter cable (61.3); -13.7
    -XO crankarm drive side sanding; -10
    -XO crankarm non drive side sanding; -10
    -Ritchey stem original boltset (6 total) (23g) to Ti bolts (12g); -11
    -Look bottle cage sanding; -2
    -Ritchey Seatpost bolts (14) to Torx ti bolts pair (5) -9
    TOTAL shaved: 77g
    EMERGENGY KIT RACE DAY
    BEFORE
    -Tube (173g)+Velcros(3g); 176g
    -Big Air 40g Co2+holder/zip ties; 99g
    -Tire levers; 20g
    Total=295g
    AFTER
    -Continental Supersonic Tube 26x1.9-2.1mm (87g) + bag(6g); 93g
    -Innovations Fat20 Co2 20g + rubber cover; 73g
    -Tire levers; 20g
    total=186g
    total shaved: 109g
    new topcap full carbon with American classic tubeless valve cut to thread onto CO2 adapter
    Removing the Star Nut I have full clearance to fit the C02, fitting is perfect!
    For everyday use off race, Topeak Micro Rocket Carbon Pump fits perfect on 1/18 steertube
    Co2 setup is heavier
    New tube much smaller too
    tire levers fits perfect on slot originaly made for the "Fizik plastic logo"
    Since It was very hard to find on-line the Twinloc 'real' weight, here it is.
    I removed the blue lever for the front susp, my lefty is the XLR.
    Plugs Before
    Plugs After
    Tube under the saddle
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    Now that is some true weight weenie action! Where did you shave the crank arms? Will taking out the star nut have any negative effects?
    Jan 2013
    69er Scott Spark <21lbs
    Just took the clear coat out of crank arms, they were used anyways and quite ugly spots. As I have a lefty fork, the upper lefty clamp plus stem bolts are already a solid tight. Star nut is unnecessary
    would an xx1 crank save you any weight? Supposedly with the xx1 rings you wouldnt need the chain guide. Alternately a wolf tooth ring.
    Neither are cheap though..
    Jan 2013
    Wolthtooth 36t it's on my 'To Do' list, still not available! It will save 16g from mrp 36t and less 46g from chain guide. But I'm still a little skeptical about the complete drop stop effect, perhaps with a xtr shadow plus rear der would assist the ring?!
    Jan 2013
    69er Scott Spark &lt;21lbs
    I was just now out for a ride test....nasty and rocky down hills,Co2 stayed tight inside, no play.... and I even helped a random guy in need of a pump...solved his problem in 1min and back to the ride!
    Reputation: limba's Avatar
    That's awesome. Great post.
    Reputation: HDTVdevil's Avatar
    Re: 69er Scott Spark &lt;21lbs
    Sent from my GT-I9505 using Tapatalk 2
    Mar 2013
    Love it!
    Mostly I want to know where I can get some cool custom stickers for my ride
    Jan 2013
    ?? totally into the topic! Lol. I like to spend time working on Corel Draw 11 making stickers as well.
    Mar 2013
    Perhaps I can commission you to make me some
    Quote Originally Posted by andrepsz View Post
    Yep, a clutched rear derailleur is req for the Wolf tooth setup. I think they are slightly heavier than non-clutched equivalents, but hadn't searched too much.
    BTW, the stem/steerer storage is brilliant, but you scared the crap out of me when I saw the mention of no star nut! Didn't realize you had the Lefty.
    Jan 2013
    All I know available is the XTR shadow plus long cage (213g) and Sram X0 type 2 medium cage (235g).....both are pretty heavy comparing to my XX long cage(174g). So the change would not affect weight it self...still thinking if it's worth.
    Jan 2013
    Quote Originally Posted by speedneeder View Post
    Tell me what you want!
    Jan 2013
    More saving: -186g total.
    Some Stock bolts to all Ti: -12g
    -2g (there is two more in this pic.
    Lefty Stock Boot (45g) to neoprene chain-stay protector from Scott (20g): -28
    I still need to test ansd see how the neoprene handles.
    Shima pedals to Xpedo's: -146g
    Mar 2013
    Cool, what is total weight now?
    Jan 2013
    Should be at 9217g bike only with a 29er front. Switching to my 26er setup it should tip 9000g sharp
    Mar 2013
    Pretty cool man
    Jan 2013
    Some experiment:
    Mar 2013
    What is it?
    Jan 2013
    What is it?
    Starting to focus on my seatpost, just tried to make a carbon cradle, now need to find the rest of the hardware and test! It looks solid! Final weigh:11g
    Mar 2013
    Interesting!
    Reputation: Fakie1999's Avatar
    Feb 2010
    I have a wolf tooth ring, and I can confirm the "no drop" is true. I use a XT shadow plus. I actually rode once with the clutch turned off (removed rear wheel and forgot to turn it back on) and I still did not have a chain drop. I highly recommend them!
    Jan 2013
    Good info! Thanks
    Re: 69er Scott Spark <21lbs
    That integrated pump think is awesome.
    Jan 2013
    As 26er with pedals:
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    Impressive! I like this thread... Nice work!
    There is not much choice between rotten apples.
    Jan 2013
    Yes!
    Attached Thumbnails Attached Thumbnails 69er Scott Spark &lt;21lbs-imageuploadedbytapatalk-21373756349.803577.jpg
    Jan 2013
    Jan 2013
    Please help me find this part:
    http://reviews.mtbr.com/wp-content/u...7/kcnc_pin.jpg
    I'm venturing myself to build my own Seatpost, I already have pair of Ti bolts/ home made carbon cradle/Carbon tube its in the mail, Yokes I know were to find...but this little guy I just can't find anywhere! perhaps I'm using the wrong therm to search for? is there another name for this? (I'm not originally from the US).
    I found on r2bike: AX Lightness Ersatzteil Bolzen für Sattelstütze Europa 9g, 27,50 &eur
    ....but I'm not spending $40 plus on this!
    I'm looking for ebay/cheap parts, 3 days to be at my door (if possible).
    Any clue?
    Any help is much appreciated!
    Reputation: jeremyb's Avatar
    I have one of these 27.2 OTA seatposts - the pin is removable. Looks like the going price on ebay is about $28 from China. I could sell you my seatpost for that. See photo:
    Jan 2013
    Quote Originally Posted by jeremyb View Post
    Thank you for the offer. but its really just the pin that I need! I'm trying with POP (Parts of Passion) to get this. thanks
    Jan 2013
    Tired of searching, made a connector pin myself. Looking good!69er Scott Spark &lt;21lbs-imageuploadedbytapatalk-21374102347.527481.jpg
    Weight so far...
    Waiting for the Yokes now...
    Jan 2013
    Homemade Seatpost looking promising! Plus 12g from yokes = 116g at 12" total length.69er Scott Spark &lt;21lbs-imageuploadedbytapatalk-21374265420.696827.jpg
    Mar 2013
    Cool. I admire your ingenuity!
    Jan 2013
    In what sense?
    Have to try an idea to know the end story!
    Mar 2013
    Exactly - you are learning your own path
    Jan 2013
    If I survive after trying it out be sure I'll be back here to share the end story!
    Mar 2013
    That's a good point, you are assuming some risk doing this.
    Jan 2013
    Homemade seatpost final weight 111g at 11" / 34.9mm.
    99g saved from original Ritchey WCS carbon.
    Jan 2013
    Ritchey post: 210g
    Successful installation...stiff!!!
    Jan 2013
    Some more saving: TOTAL: -140g
    Bike sits at 19.75lns (8960g) as 26er with 2.25 rear /2.40 front RRalph's tires.
    f/ XX rear derail(173g) to XTR shadow plus w/ light pulleys (210g); +37g
    No Chainguide: -48g
    f/ Ritchey seatpost 400m (208g) to homemade seatpost 280mm (111g): -99g
    f/ Rear skewer DT swiss (50) to Rossetti Ti (20): -30g
    Sweet Build...you should ditch the conical washers on the Avids Ultimates, I know they did it themselves for a SL version. Are you running a 140? It looks like the bigger adapter for a 160mm rotor.
    Jan 2013
    I'm running both scrubs 160/160. My xx calipers were looking awful, all scratched up. That's why a replaced by the ultimate's but since was already 160mm, I haven't changed anything...same amount of washers and spacers.
    Jan 2013
    Full carbon caliper mount....and can go even lighter!
    Jul 2013
    Pretty awesome. I've enjoyed your thread
    Jul 2013
    Any updates?
    Jan 2013
    Working on some parts, experimenting some things like removing paint on my XX brakeset to Polished Aluminum finish.
    levers after polishing:
    calipers before polishing:
    Also tuned another seatpost. I started with an original BlackOps seatpost (190g): http://kbcyclewerks.com/wp-content/u...-seatpos11.jpg
    Chopped the head off:
    final weight on seatpost also changing craddle/Yokes/Pin...146g...But this one is going on another Hardtail sub 16lbs project, not ready yet.
    Jul 2013
    Pretty awesome Andre. Your thread has inspired me! Im looking at a new scott spark 910 at 24lbs. I love the idea of a light full suspension bike, as mine currently weighs 33lbs. I could probably get it lower but i think its smarter to start with a better platform
    Jan 2013
    Quote Originally Posted by A DuB View Post
    The new spark 910 is 29er right? at 24lbs is pretty good to start...small jobs here and there and the combination could knock some decent weight later...its fun
    Jul 2013
    Yes 29 carbon.
    I know your bike started pretty light, can you feel the difference, now vs then? Does the bike physically ride worse or better than it did when it was heavier?
  67. #67
    Jan 2013
    First huge difference - fork upgrade; Lefty forks are definitely a go for stiffness and very responsive,
    Almost 4lbs lighter I'd say you can't go worse. Bike is definitely better on climbs and that's my expertize and also why I wanted something light in first place.
    Ridability - as a full suspension bike competing with some 'already light' Hardtails out there on weight, I'd say I'm getting the best from both worlds...I can literally do whatever I want with this one and always be satisfied with performance. I can fully lock all suspensions in case of a ride on the road and Uphills in standing position...I can go Hardtail if I want, I can go FULL on descents, with 2.4 tire up front also improves stability on rocky/sand/soft descents...pretty Sweet!
    I had Hardtails all my life and this was my very first full. To be honest with you I'm currently building a Hardtail for myself, just did a ride test last week but I can't compare at all with the Spark...not even cruising on flat sections...somehow the traction mode on the spark's rear suspension definitively improves the experience, much more control on Flats and even uphill....Spark is Unreal!!! I'm very happy!
  68. #68
    Jan 2013
    Updates:
    Polished Alloy finish on XX levers and calipers. Old paint was awful , I liked to result!
    Tires: Michelin Wild Race'r Ultimate 26x2.10 - 410g/403g
    After weight:19.51lbs as pictured with cateye and bottle cage
    Ready to fly next weekend...XTERRA!!!
  69. #69
    Updates:
    Why do you have mounted cable on rear brake again with this angle(12clock)?
    90 degree to left(9clock) would be better or not?
    Here on scale with direct way:
    Give us a picture with mounted carbon caliper. It's selfmade?
  70. #70
    Nov 2012
    Hey I saw you were doing a HT Flash build with an S-Works crank and were wondering about single direct mount rings for S-Works. I wonder if this would work...? .:: Carbon-Ti - Hi Tech Bicycle Components ::.
  71. #71
    Jan 2013
    Quote Originally Posted by robgall13 View Post
    Would't work without chainguide on my project since I'm using a XX rear derailleur. I found on ebay a XX1 type teeth with 104 BCD for my spyder (from Ukraine) . Worked well so far.
  72. #72
    Jan 2013
    Quote Originally Posted by Scalty View Post
    That's pretty sweet! looks internally? I need to figure it out how to cut my hose, is too long.
  73. #73
    yes internally, you can see more on all pictures:
    Album Scalty - Fotoalbum auf MTB-News.de
    you can cut on brakelever or directly on rear brake with goodridge connector kit or hose kit. first option is normal way to short hoses.
  74. #74
    Jan 2013
    I'm glad you brought this subject. Maybe I'll Lear something new! So here is my question: check this picture. I was able to cut the hose with the Torx end bolt, but the hose next to it, doesn't seem to have a way to unscrew at all, no torx or Allen. I tried pulling with a wrench with no luck.
    What to do??
  75. #75
    What to do??
    normaly you need new end pieces, because these are for one time use. outside part have mechanical deforming and inside part hoking in hose, so you need new ones. other end parts like goodrigde maybe you can use few times...
    also o-rings made new by service.
  76. #76
    Jan 2013
    Big thanks. Man...after looking closely to you bike...very good job running the front brake housing through the Stem/Steerer tube. really clean...actually all the work for all everything internally....! it gave me a potential TO DO list and spend more necessary time in the garage! But for that I'll need some guts to do it!
  77. #77
    Jan 2013
    Chinese saddle 103g (from Fizik 158g). Current weight 19.20lbs without Cateye.
  78. #78
    Jul 2013
    Man thats awesome! Love it!
  79. #79
    Jan 2013
    Thanks! Next..... replace cassette and go under 19lbs
  80. #80
    Jan 2013
    Its been a while without upgrades. latest features are PROTI Fully Forged Bolts, picked gold color to match with some other components:
    For the Lefty fork clamp, perfect fitting!
    Also some on the frame and shock
    Bottle cage bolts, pretty sweet
    Stem
  81. #81
    Looks great!
  82. #82
    Jan 2013
    Started a new and apparently long project...I decided to strip the paint off my spark frame, after running the blade for the first time...I realized how long this task will be! Paint was old and a couple of scratches so it will worth the work. Meanwhile I put this bike together so I have a bike to ride....on a nice and classic carbon flash FR frame. Obviously I would pick some other components and colors to go with this frame, also the fork doesn't have to be XL clamp. End result is still great...and light!!! 17lbs.
  83. #83
    Jan 2013
    Thinking about internal housing (internal cable routing...fixed by phlegm)...
  84. #84
    ^^ Are you talking about internal cable routing?
  85. #85
    Jan 2013
    Yep...
  86. #86
    Jan 2013
    Bare carbon finish is getting along...but got to say....it's as HELL of a job...deep respect for others venturing to do this.
  87. #87
    Jan 2013
    Work is done finally... a hell of a job is my feedback...but was still fun and always good to learn something new. 82g was the total saving without the paint and a well deserved "I have a new bike!!!" feeling!
    I'm a little disappointed to see the poor quality on the bonding process, I've found so many irregular and ugly areas that I might consider a black coating, I'll also add some Scott custom stickers, also thinking about a color touch on small areas, thanks to LEGO to help me pick the colors!
  88. #88
    Wow, I'm surprised the paint would add that much.
  89. #89
    Jan 2013
    After doing some research that is the average saving. I've seen people saving 90g, 75g...depending on frame. One thing I've learned, from factory they add so many layers and the white was by far the hardest to remove.
  90. #90
    Jan 2013
    Paint job
  91. #91
    Kitty! Kitty! Kitty!
    Reputation: GelatiCruiser's Avatar
    Oct 2012
    Where'd you get the Chinese saddle? And how much?
  92. #92
    Jan 2013
    Quote Originally Posted by GelatiCruiser View Post
    Full Carbon Road Bike Bicycle MTB Saddle Seat | eBay
  93. #93
    Oct 2012
    Jan 2013
    Decided to give it a go with Fox CTD
    Rotor 4130 BB the be paired with swork crank...
    Two major weight saving here. I'm shooting for 70g save on crank setup (from gpx BB and XO to rotor 3140 and s-work) + 77g from (f/ scott nude with remote shock to Fox CTD). total 147g. If I go spiderless in the future it will save around 95g additionally.
  95. #95
    Jan 2013
  96. #96
    Feb 2010
    That's looking great. Perhaps paint the linkage black? The white really stands out.
  97. #97
    Quote Originally Posted by TigWorld View Post
    Agreed, looking good. Maybe the linkage could be one of the colors on the stripe.
  98. #98
    Jan 2013
    I almost painted but decided to keep it white to match with the stem and lefty clamps both also white. I'll see how it looks later! Thanks
  99. #99
    Jan 2013
    With sun light:
  100. #100
    Jan 2013
    FYI
    Standard rear shifting cable after cut:
    Power cordz uncut:
    Hope this works! Any feedback from powercordZ users on rear?
  1. Scott spark 950 vs Scott spark 29 elite
    By Davidg531 in forum 29er Bikes
    Last Post: 09-17-2014, 08:24 PM
  2. Replies: 8
    Last Post: 03-24-2013, 07:04 PM
  3. Scott Spark or Scott Genius 2012 wanted...
    By LiquidSpin in forum Virginia, WV, Maryland, DC, Delaware
    Last Post: 06-12-2012, 03:04 PM
  4. Scott Spark 24 - used or new?
    By bugger in forum Families and Riding with Kids
    Last Post: 04-05-2011, 03:55 PM
  5. Scott Spark 35 vs. 40
    By iancl in forum Scott Sports
    Last Post: 12-30-2010, 09:41 AM
Members who have read this thread: 16
