Results 1 to 15 of 15
    Specialized
    Reputation: Seb K's Avatar
    47 grams XC saddle
    This is the (discontinued) Extralite carbon saddle that I have machined down and down and now I don't think it can be machined anymore without weakening it too much . I have also rounded the edges like crazy and also the cut so shouldn't scrape your legs (or manly bits) .
    I have fully tested it on my trail bike at my local trails and stayed seated as much as possible over the tree roots ans it survived . So far so good but like with most niche carbon parts in a crash it will no doubt break easily .
    Attached Thumbnails Attached Thumbnails 47 grams XC saddle-dscn9080%5B1%5D.jpg
    Reputation: phlegm's Avatar
    Wow, and I thought my 70g saddle was light - thanks a lot!
    Specialized
    Well tell a lie I can get it lighter . I saw a saddle that someone made where they narrowed the rails near the shell (only slightly ) . I'm taking a gamble with this one so will be testing later tonight . If all is good then I will post it again . If not then I'll be in hospital while the nurse removes shards of carbon from my a** !!!
    44grams BTW.
    Specialized
    43 grams !!! Well I didn't die . I'm knackered but I'm still alive and the saddle held well .
    chasing simplicity
    Reputation: MattMay's Avatar
    Dec 2013
    Don't know if you guys have seen these MILEBA saddles. 53g. Custom carbon, 16 different surfaces. 3 different widths. Microfibre covers in 32 colors. 16 different rider weight classes. Ordering is a couple weeks because they're made to order...you can even add a custom logo. Not cheap but they look good.
    https://r2-bike.com/Mileba_1
    https://youtu.be/ot5HTAuvZrA
    Specialized
    Mileba are good especially if you like custom . I would go further lightening the shell though .
    Specialized
    You guys need to check my other (updated ) post . The saddle looks more rounded and I have modified the rails .
    Saddle/seatpost/shim = 112grams
    How much do you weight? Aside from expected use, I assume you must be considering this at some point.
    Also, do you have any projects that you've overdone it on, i.e. removed too much material and it cracked? I'd find that interesting as well from a learning standpoint.
    chasing simplicity
    Dec 2013
    Selle Italia's new 47g saddle...
    ...the C59.
    Selle Italia C59 saddle first look - BikeRadar
    Attached Thumbnails Attached Thumbnails 47 grams XC saddle-dscf8572-1483525160621-eo84pl9tmcff-1260-80.jpg
    I know what it's like to be dead. "To Die & Live In LA."
    You won't get any lighter than this:
    Their lightest saddle weights 45gr stock!
    https://www.gelucarboncreation.com/
    Specialized
    42 grams done early last year .
    Mar 2015
    @ Karimian5
    Thanks for sharing that is seariously light.
    I don't really trust manufacturers claimed weights, we need proof on a balance
    Thumper
    Reputation: WickedLite's Avatar
    Dash P3 37.3 grams
    Quote Originally Posted by damond View Post
    karimian5, that is one slick looking saddle you made!
    I had this Dash P3 saddle on my 2013 Fat Bike build. The lack of nose really helped moving around, balancing in the snow with baggy snow pants. Good for 165 lbs of anything but am or dh.
    Dec 2008
    Quote Originally Posted by WickedLite View Post
    You are back Wicked. Have your injuries healed up so you can ride again?
    Specialized
    Cheers man . Those Dahs saddle are amazing .
    Yup you don't really need the nose . If you check my recent updates you will see I removed the nose from the saddle and combined it with the Schmolke TLO post making a custom carbon plug . 74.5grams for the post and saddle @ 350mm length and 31.6mm diameter . I still get the odd comments about it looking uncomfortable etc and it won't work blah blah blah but hey if you haven't tried it then you don't know .
  1. Extralite saddle . From 65 grams to 49 grams
    By Seb K in forum Weight Weenies
    Last Post: 10-14-2015, 12:32 PM
  2. Need to lose 800 grams
    By moxnix in forum Weight Weenies
    Last Post: 04-11-2015, 03:27 PM
  3. Replies: 2
    Last Post: 02-25-2014, 09:03 PM
  4. How noticeable is 200-300 grams in wheels?
    By D93 in forum Weight Weenies
    Last Post: 03-14-2012, 06:51 AM
  5. Replies: 21
    Last Post: 02-24-2011, 03:09 AM
Members who have read this thread: 21
