Results 1 to 5 of 5
Thread: 3T Seatposts
    Reputation: Major Clanger's Avatar
    Feb 2012
    3T Seatposts
    Do any of you have any experience of 3T carbon seatposts, in particular the Doric and Dorico models? I currently use Easton but it's an ancient CT2 and I'm contemplating 3T products for a new XC bike.
    Using yesterday's technology, to create tomorrow's problems, today.
    Dec 2005
    I've had one on my 29er for a couple years. Not a problem with it. Light, strong, and easy to adjust.
    With regards to the Doric:
    They work OK. The finish/paint is of very poor quality and will be marked up badly after installation. That may or may not be a big deal to you.
    Also, the front bolt is hard to get to without scratching the finish on the post while adjusting. The cradle is a bit wide, limiting adjustment (not an issue if you don't run at the extremes of your rails).
    But they are well built, fairly light, and good looking.
    Feb 2012
    Thanks both for the input, appreciated. I'll have a ponder.... Not too worried about quality of the finishing as long as it's strong enough for XC and gentle AM.
    Durability has been fine for me. Although, if I were going to be riding more aggressive stuff I would likely go for a Thomson Masterpiece. They are just as light, yet much stronger. Particularly I think the bolts on the 3T are a bit of a weak point. Fairly long and relatively unsupported. Most likely you'd be fine.
Hot Deals
Contests
Latest Mountain Bike Articles
