FAT BIKES
WINTER APPAREL
TRAINERS
Page 2 of 2 FirstFirst 1 2
Results 26 to 46 of 46
  1. #26
    rigid fork
  2. #27
    Mar 2012
    get rid of the gears...
  3. #28
    Shoes are a great place to lose weight, it's what I did, but obviously one wouldn't go this route at expense of comfort or traction.
  4. #29
    Reputation: limba's Avatar
    Michael Rasmussen (and a few other guys) have used modified road shoes for racing.
    but I wouldn't recommend that.
  5. #30
    This summer a local racer used unmodified road shoes and road pedals, and he was unpleasantly surprised to find out the weekly mtb practice race was not the usual smooth short-track type course. It was full of hike-a-bike and nasty sections. He crashed alllll night long.
    Quote Originally Posted by limba View Post
  6. #31
    Formerly of Kent
    Reputation: Le Duke's Avatar
    My Mavic Fury shoes are pretty darn light, as MTB shoes go.
    Death from Below.
    RLTW!
  7. #32
    Go SS and rigid and you'll drop multiple pounds.
    MCH Co-Captain
  8. #33
    Formerly of Kent
    SS and rigid are not really practical for going fast around here.
    There's a reason you see very few pro racers on either of those, let alone both.
    Death from Below.
    RLTW!
  9. #34
    Quote Originally Posted by 2002maniac View Post
    X10-sl chain
    ti spindles for your pedals
    weigh your saddle. I bet it's heavier than you think. Try a Speed Needle.
    Woodman ti seatpost clamp will probably save ~20g. Those chinese carbon clamps are pretty heavy.
    Give 1x10 a try. with an 11-36 you might really enjoy it. Mine is 11-34 and I rarely feel like I need more gears.
    Ashima rotors are pretty cheap ($12 at aawyeah.com) and would save about 20g over XX. Even more if you could go with a 140mm rear.
    Other than that I'd say you've maxed it out without spending really big bucks. Good luck!
    This is about the exact same thing I was about to type up. A rational response and all these are pretty cheap.
    While i'm not in the rockies, I've been racing 1x for years and for the courses that I'm on, I rarely long for a big ring and if I needed a granny gear, I'd be faster off the bike. I'm set up with 33 x 12-26 road cassette. If you're running an 11-36, I doubt that you actually need those two chainrings. Pick up a "middle" ring and see what it feels like on the trails. I bet you'll be fine.
  10. #35
    Reputation: sfer1's Avatar
    Frame: FR211 29er
    Fork: SID RCT3 29er
    Wheels: ENVE XC rims w/240s and 28 DT Revolutions per wheel
    QRs: DT RWS 9mm (f)/10mm (r) Extralite Aliens 3
    Tires: Rocket Ron Evo TL 2.25 (f), Renegade 1.95 Control (r)
    Crank: XO 42/28 Race Face Next SL 2x10
    Shifters: XX rear, XO front
    FD: XO
    RD: XX
    Cassette: XX 11-36
    Chain: SRAM 1051 KMC X10SL
    Brakes: XX
    Brake Rotors: XX
    Stem: Ritchey WCS C260 80 x -25d
    Bars: ENVE XC 700mm
    Grips: Specialized foam
    Seatpost: KCNC ProLite Ti
    Saddle: Old Bontrager stripped of leather and padding Yours is probably on the heavy side, but finding the right saddle is a matter of trial and error.
    Seatpost Clamp: chinese carbon, came with bike
    Headset: Neco 1.5"/1.125"
    Top Cap: Slam That Stem
    Cage: Chinese carbon, came with bike
    Pedals: old CB EB SL CB Eggbeater 2 + Ti spindles
    Note: I haven't heard of a single issue with the Extralite HyperHubs. They're very expensive though and you already have a great wheelset.
  11. #36
    Dec 2012
    Carbon Saddle and KMC x10sl chain?
  12. #37
    Sep 2004
    Leave well enough alone, I think some stated the you will sacrifice durability and reliability to save a pound. That one pound will not be cheap.
  13. #38
    Reputation: brentos's Avatar
    Weight savings with no sacrifice in durability...
    Crank:
    Race Face next SL if standard BB.
    Cannondale Hollowgram if BB30.
    Spokes:
    DT Revolutions, DT Aerolites, or Sapim CX Rays.
    Pedals:
    EggBeater 4ti
  14. #39
    Helmetless Crasher
    Reputation: Stumpjumpy's Avatar
    Quote Originally Posted by Le Duke View Post
    Lefty and stem options are out. Lefty would put my bars up too high (small frame size = ~100mm HT). Same thing with the stems.
    Run a carbon Lefty w/ a negative rise stem.
    '95 M2 StumpJumper FS
    '11 Cannondale RZ 120-two
  15. #40
    Formerly of Kent
    I'm running a -25 degree Ritchey WCS C260 stem right now, as is.
    HOWEVER....the new Syntace FlatForce stem has a stack height of only 22mm.
    I know people don't see it done (I've seen it twice, ever) often, but you can run the stem UNDER a lefty top clamp, taking the place of spacers. I might consider using the FlatForce in conjunction with a Lefty, in time.
    Death from Below.
    RLTW!
  16. #41
    -25 degree? Where can we buy?
  17. #42
    If you're going to go through with the idea of buying a Lefty fork you might as well scrap the frame/entire bike and start all over with a Flash. Your frame is "heavy" compared to a Flash, Scott or the new Trek.
  18. #43
    Formerly of Kent
    Quote Originally Posted by patrul View Post
    Ritchey WCS C260 Vorbau 25° 31,8 mm Wet Black
    Death from Below.
    RLTW!
  19. #44
    Formerly of Kent
    Can't ride a Cannondale. 134mm HT plus clamp thickness = HUGE headtube, especially on a 29er. And, I'm on a small. They don't make a Flash carbon in small.
    Trek is out, too. Worked for a Trek dealer between jobs, and I've done enough warranty claims on their carbon frames that I don't want to go that route. I love carbon fiber bikes, but taking 200-300g off of their already frail frames was not the best route, in my opinion.
    The only frame I'd buy is a Scott, or maybe a Niner Air 9 RDO.
    Death from Below.
    RLTW!
  20. #45
    Hmmm, any thought on Scott's 650B Nino bike? Just curious since you're my size or smaller.
    The RDO isn't light. I bet a small is 1200g, give or take a couple. They're on sale online everywhere right now too, just in case you missed it.
  21. #46
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    So how much does the bike weigh with the new mods? What all did you do to it?
    There is not much choice between rotten apples.
Follow MTBR on Facebook
