Results 1 to 17 of 17
    Reputation: Limon's Avatar
    2.3g headcap plus parts w/pics
    here's the 2g cap & the1g trimed aluminum bolt
    full lenght aluminum bolt 2g
    rear martha brake no bolts no rotor 231g
    front martha brake no bolts no rotor 213g
    stan's aluminum rotors 55g & 58g
    2 caliper ti bolts 1 aluminum clamp bolt 7g
    I'm still looking for ti rotor bolts?
    m2racer seatpost 92g
    96' fisher paola pezzo replica frame "priceless" I mean 1438g
    this fisher is my project light ss what do you guys think?!
    Reputation: VT Mike's Avatar
    Quote Originally Posted by Limon
    It takes a little dremel work, but you can also change the bolts on the Martas that control the lever reach adjust from steel to aluminum. They're only M4 bolts, so it only saves a few grams.
    You can get SRP Ti water bottle bolts from Cambria that work well for rotor bolts
    http://www.cambriabike.com/shopexd.asp?id=3846
    I like the cap ...did you make it or are they available somewhere?
    Reputation: tmaybee's Avatar
    Quote Originally Posted by eurorider
    The cap is really cool!
    purelycustom.com
    purelycustom.com ultralite caps & screws, the more words you put on it the lighter.
    JmZ
    JmZ is offline
    Reformed Lurker
    Reputation: JmZ's Avatar
    Available in the US too
    Check out Purely Custom . They do these. I got a few earlier this year. (Also they can do a custom logo or saying on 'em too.) They advertise cap and screw at 6g, which sounds right. Think mine was a smidgen lighter.
    JmZ
    Quote Originally Posted by tmaybee
    JmZ
    From one flat land to another.
    Advocate as if your ride depends on it...
    dremel work...
    Quote Originally Posted by VT Mike
    I'll try to make the bolts, do you know the difference in weight between carbon levers and aluminum levers?
    thanks
    Max
    Max is offline
    Velodramatic
    Reputation: Max's Avatar
    afaik it's only 3 g.... not really the 100 bucks you gotta pay more for the SL martas
    Skinny guys fight 'til they're burger
    thanks
    The difference is pretty minimal, about 6g per lever. I guess you can't swap the aluminum levers out for the carbon ones though. They won't fit, so that's a decision you have to make before you buy your brakes.
    that's it less than 3-6g each, I'll pass this time.
    thanks
    Quote Originally Posted by JmZ
    JmZ
    That's pretty good, the extralite cap and bolt come in at 9g, and cost twice as much. Too bad they don't have any pin-up girl designs available
    Reputation: Smed's Avatar
    Isn't that with a steel bolt though? My extralite headset came with a hollow steel bolt...
    ti rotor bolts
    I found these:
    ti rotor bolts
    thanks.
    I found these:
    ti rotor bolts
    I found some regular ti bolts that fit the American Classic hub, I'm going to try them.
    Quote Originally Posted by AdamGSmed
    Yep, 6g for the cap, and 3g for the hollow steel bolt. It's a pretty short bolt though. I actually had to trim a few mm off my steerer tube when I got it because the bolt wasn't long enough to reach the star nut. Maybe you could lose another gram with an aluminum bolt.
    You might run into a problem with clearance on the fork leg depending on how tall the bolt heads are. Even the button head bolts I got from racebolts.com didn't clear my fork leg - they do have kind of a tall head for a button head bolt though. But they work fine on the rear.
    good point...
    I'll see what happens tonight when I get home. I was also thinking 3 ti bolts and 3 aluminum bolts. Dead wish or what?
    thanks
  1. road-mtn bike parts interchangeability?
    By mikeee in forum Beginner's Corner
    Last Post: 08-02-2004, 10:35 PM
  2. Replies: 3
    Last Post: 05-08-2004, 01:32 PM
  3. have $500 for replacement parts need advice please.
    By gspin2k1 in forum Clydesdales/Tall Riders
    Last Post: 05-07-2004, 11:34 AM
  4. A few parts in question...
    By Get_Outside_N_Ride in forum Downhill - Freeride
    Last Post: 03-26-2004, 11:41 AM
  5. FS frames, warranties, and parts
    By tube_ee in forum General Discussion
    Last Post: 02-16-2004, 11:34 PM
