Results 1 to 22 of 22
    JRA
    JRA is offline
    Reputation: JRA's Avatar
    For the Trailbuilders
    An application for a clinometer to work on a "phone" whose brandname implies it has a small first person complex. Need a 5% climb? No problem ... let me whip out my "phone".
    Reputation: scotteric's Avatar
    Aug 2005
    What is the point of this?
    Using a clino is the "right" way to build sustainable grades. Having one built into your phone would possibly be helpful. As presented in a JRA sort of way.
    JRA
    JRA is offline
    Borneo's right. It works on an iPhone or iPad but anything w/ "i" in front of it bugs me to no end so I sort of inferred. Gee, Scotteric, sorry to have wasted your time. Saw a bit on it in the current Dirt Rag and thought someone might find it useful.
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Theolodite is a very useful, inexpensive clino/survey app for the iPhone / iPad. I used it quite a bit this winter figuring out the angles for the great spacecoaster at duthie. One thing that caused some confusion, it can measure grades in either degrees or percent. My understanding is that percent is the common unit of measure for trail building.
    Aug 2005
    Quote Originally Posted by JRA View Post
    thats cool, just didn't get all the "quotes". Can it help me build a bunker?
    Appears the App is named Theodolite. Cool looking app...might have to buy it.
    Cheers,
    Mike
    i'm schralping yer thread
    I've used Theodolite, too. One of the other cool features is being able to take a photo with the reticule and the data (clino, position, etc.) overlaid. The only real downside over a traditional clino is trying to work with an iphone app in muddy, nasty, pouring-down-rain conditions. Which, of course, is when we usually build.
    FWIW, you can switch between degrees and percent, FM. There may have been some...er....barley-based interference when I was giving you numbers during some of the coaster scouting.
    Just roll it......
    Reputation: ebxtreme's Avatar
    Quote Originally Posted by Borneo View Post
    Beyond being the "right" way, it's really the only way to effectively measure a trails's grade. Folks would be very surprised how far off you usually are when you just "eyeball" an angle. I know I was the first time I did it and then looked at it via a clino.
    Noteworthy, is you really need two people to best measure the angle of the dangle.
    FM
    FM is offline
    Apr 2003
    Quote Originally Posted by GeePhroh View Post
    Yep. Westra thought we were planning to make it 3.6x steeper
    Quote Originally Posted by ebxtreme View Post
    Same reason good baristas reference scales, thermometers and timers.
    Science FTW!
    Yep, this what Froh and I did on the spacecoaster. Having two consistent readings validates the measurement.
    It was very helpful on the coaster, since if you get the angle on wood wrong, you can't fix it with a shovel!
    Justin Vander Pol
    Reputation: juice's Avatar
    This. pros use clinos.
    Quote Originally Posted by FM View Post
    Science FTW!
    Same reason tire pressure gauges win over the thumb gauge when prepping tires.
    cheers,
    Mike
    Jan 2005
    That phone app is really cool. Using a clino is a great educational tool on figuring out which side your dominant eye is.
    Left footed, right handed, left eye dominant, i'm all f'd up.
    ....~|____\
    _____||_________
    .\....FAILBOAT..../
    FM
    FM is offline
    Apr 2003
    Quote Originally Posted by mbcracken View Post
    Agree %100.
    Crashing a lot less since I started using a tire pressure gauge
    Justin Vander Pol
    Agree %100.
    12 psi ftw.
    Reputation: Jimba's Avatar
    I have notice beer and angles don't mix!
    Reputation: shiggy's Avatar
    Dec 1998
    Cheers,
    Mike
    or seeLevel.
    A real clinometer is still going to be more accurate.
    mtbtires.com
    Quote Originally Posted by juice View Post
    12 psi ftw.
    12 psi for FM? If he's racing XC maybe...
    Just roll it......
    True dat, GeePhroh. Juice is totally overestimating!
    FM
    FM is offline
    Apr 2003
    Unsubscribe
    Justin Vander Pol
    Unsubscribe
    You started it ...
    Agree %100.
    32.5 PSI. Nothing less and nothing more!
