    Reputation: rcnute's Avatar
    Tires for Colonnade?
    Hi, folks: My office is behind the Colonnade and so I'm going to keep a bike at work for lunch rides, etc. I'm not doing any of the technical stuff. Apparently it's pretty dry; what kind of tires are you running under there? Thanks for any suggestions.
    Ryan
    Reputation: Tarekith's Avatar
    Mar 2005
    Anything built for desert conditions should do fine
    Seriously though, most of the switchback stuff with all the rock retainer walls should be rideable with just about any tire. The dirt by all the jumps has gotten extremely powdery over the years though, what most people call moon dust. I don't change my tires just for Colonnade (Maxxis Ardents), but you definitely want to be aware of how loose things are before you hit some of those corners. A quick walk through and you should be fine.
    Tarekith.com
    '12 RM Slayer70, i9 Torch, Flow EX, XT Brakes, 5050 s3.
    Careful of the rocks and wood on the hillside (easier sections). They were super wet when I was there a couple weeks ago just from seeps. It looked slippery but I still washed out a couple times...
    Thanks for the input guys.
    Ryan
  1. Colonnade
    By Serotta b1kr in forum Washington
    Last Post: 05-17-2014, 10:37 PM
  2. I 5 Colonnade
    By gturnage2002 in forum Washington
    Last Post: 08-05-2013, 04:48 PM
  3. I 5 Colonnade needs your help!
    Last Post: 08-30-2012, 01:01 PM
  4. New at I-5 Colonnade
    By woodway in forum Washington
    Last Post: 11-02-2011, 10:39 AM
  5. Don't forget about Colonnade!
    By Dave_schuldt in forum Washington
    Last Post: 03-05-2011, 03:39 PM
