Results 1 to 6 of 6
    Ambivalent Luddite
    Reputation: Retro Dude's Avatar
    Jun 2010
    XTR Crank Fixing Bolts for M950/952?
    Does anyone know of a source for these self-extracting bolts or compatible parts?
    Not sure if FSA bolts or Shimano road bolts fit the XTR cranks.
    Any help would be appreciated.
    __________________
    inFATuated
    Nov 2012
    my local shop had one in the spare bits bin in steel, I grabbed it so I could torque down the cranks, then replace with the Al bolt (and re-torque). New replacements I'm not sure of the size, but toronto cycles has Ti and Al crank bolts in several sizes (I'd measure but I'm nowhere near my bike or tools, unfortunately)
    torontocycles.com/Selling/Chainrings_and_Cranks.html
    edit: Road octalink V1 bb are the same (but slightly different width) so I expect the bolts would be the same. BUT, it is shimano and it IS XTR, they like to do it different for engineered obsolescence...
    Ambivalent Luddite
    Jun 2010
    Thanks for the response.
    The Toronto Cycles bolts are $33 shipped...pricey.
    I'll check with the LBS when they open back up after the new year.
    Durace and 105 from the same era should fit fine, the bottom brackets work with the 95x stuff.
    Ambivalent Luddite
    Jun 2010
    Perfect, thanks for the confirmation - just picked up a set of DA bolts.
    __________________
    inFATuated
    Sep 2013
    I've got two of those bolts, NOS, sitting in my loft. I fitted SRP bolts to the crankset when I put my 92 MErlin together (back in 92). I must get that old box down from the loft
  1. XTR m950, WI ENO, and Middleburn weird franken crank question!
    By greenblinker104 in forum Singlespeed
    Last Post: 01-01-2014, 02:27 PM
  2. Shimano XT Crank Arm Fixing Bolt
    By solitone in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-28-2012, 02:12 AM
  3. Crank fixing bolt for LX M572 hollowtech??
    By turner45 in forum Shimano
    Last Post: 06-29-2012, 03:30 PM
  4. Crank bolts................
    By charliethetuna in forum General Discussion
    Last Post: 09-18-2011, 09:55 PM
  5. Titanium Crank Bolts
    By mtrbiker in forum Weight Weenies
    Last Post: 07-30-2011, 11:37 AM
