Results 1 to 9 of 9
    XT threaded headset Ė dust seal?
    Was there a dust seal on threaded XT headset between crown lace and bottom headset cup? Itís the one with loose retainer bearings in it, not the cartridge one. I donít find a seal in my box but it was from years ago Iím not confident if I had it kept all in one package properly. I noticed the grease oozing out after a ride in a hot day, it made me wonder. Thanks in advance.
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    Yes
    I just repacked one over the weekend and there is a seal for the crown race/lower cup.
    Feb 2007
    some company used to make neoprene race socks
    lizard skins?
    yip!:
    http://lizardskins.com/store/product...n/headset-seal
    I'm not sure about the effectiveness of the socks as it drips after riding hard.
    Hey Shayne, was it just a circular rubber seal that or was there a metal base that sits on the race/bearings interface? If so how/where does it sit?
    On a added note, do you know of any "replacement" sealed bearings that can pop into these cups? Doubt it, but these bearings are significantly oversided compared to other loose bearings that I have.
    Thanks guys.
    Quote Originally Posted by hatake
    Thanks guys.
    Its a thin plastic(Ņrubber?) ring that sits on the edge of the race. It looked the same as the seal on the top half of the headset but I wasn't paying all that much attention. I can get a photo of it later.
    That would be wonderful, thank you for that. I just need to know what to look for in my junk box :-)
    While these oversized bearings are super smooth, durable and nice, the headset weighs a ton compared to regular threaded headset.
    Reputation: fat tire trader's Avatar
    The seals are plastic, a good bike shop might be able to order them. I would cut out a 1 inch piece of inner tube and slip it over the bottom cup and over the crown race when the fork is installed, works great.
    chris ioakimedes
    Here is an instruction sheet for the XT headsets which shows the plastic washers
    Wonderful information, thank you, thank you.
